| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Last week, it was time for the 5th service of my car (which is a Maruti baleno). The guy called me to inform that there are symptoms of brake fluid leakage from brake cylinder in one of the rear wheels (which are drum-type). He insisted on changing the cylinder itself, but I was not convinced since I haven't noticed any drop in fluid level over past 3 years. It was never replaced all these years, and it still remained above the max level. He tried to scare me (I thought so, but could be genuine as well ) reminding me that braking is such an important thing which should not be taken chance with. But since the cost was not negligible (Rs. 2K), I didn't trust him blindly. He also told me that the fluid should have been replaced during the last service itself (2 years/20K Km) as per the schedule, blaming the service center where it was done. I asked him to change the fluid, but leave the cylinder as is. He told me that after the fluid replacement, the leakage will be more for sure (100% saar!). But I told him that I will keep watching the level on a daily basis, and in case I see it dropping I would get back. He agreed on that, though reluctantly. I also checked that brake warning light and the float sensor is working properly. I do check the fluid level and the light every time I use the car. It has been over 5 days and guess what- there is absolutely no drop in the fluid level that I could notice! So, I have following questions in mind-1. They showed me the leakage in order to convince me, the moment they opened a rubber cap on the brake cylinder, it was all wet inside and also a couple of drops spilled around. Whereas the cylinder on the other side was quite dry. But given that the whole system contains only half a liter of fluid, in spite of that level hardly dropped over good 3 years period, and I had never experienced any problems with braking, I dared not to get it fixed thinking it must be a very minor leak, if at all. I also heard one mechanic telling the other something like this (though I couldn't understand their language well)- It is just some "bleeding", thats it!. I wanted to know what others have to say. Does it look like a serious problem? 2. Does Maruti cover replacement of brake cylinders under warranty (extended-warranty for that matter)? I referred to the extended warranty booklet, but it seemed confusing, a lot left to interpretation! It says- cylinder is covered, but "regular wear" components inside are not covered. It also mentions that such parts, if replaced under scheduled servicing, are not covered! Please help me understand them better!! |
| | #4 (permalink) |
| Senior - BHPian | If braking is fine you need not worry! But on second thought, do the following. Put the car on ramp or jackup. open the rear drum. start the engine and pump the brakes few times. Watch any sign of leakage or brake oil spray at these spot. Its very easy to figure. ![]()
__________________ Still! Living Life a quarter mile at a time.....post being Dad. |
| | #5 (permalink) |
| BHPian | When the mechanic showed it to me, there weren't any visible signs of leakage on the cylinder or surrounding area. Traces of oil were seen only when one of the rubber caps (pointed by red arrows in the image you posted) was removed. Jacking up and removing the wheel is fine, but I don't think I would be comfortable removing the drum altogether (moreover, I don't have required tools)! If you think just keeping a watch on fluid level (say daily for a month or so) would be safe enough, then I would avoid the rest. |
| | #7 (permalink) |
| Senior - BHPian Join Date: Dec 2007 Location: Kanpur
| If there is any trace of fluid unless due to the initial installation (very unlikely) you have a problem brewing. If as you say you have not used up any fluid then you may be Ok but keep a cautious eye. However, brake fluid in the reservoir does tend to get lower esp. as disc pads wear. Brakes are vital to safety and I will tend to go with the advisor and change the cylinder. If you are at two years (which is what I think you are) then brake fluid should be changed in any case.
__________________ Life is short, do not make it shorter! Accent GLS 2002 Santro Automatic 2005 |
| | #9 (permalink) |
| BHPian | The car is a little over 3 years old, but mileage is much on the lower side in spite of being regularly used (almost daily). If I compare actual mileage against maximum time period and mileage allowed before each service in the maintenance schedule, then it has been roughly half the specified figures. As of now it has clocked just about 16-17K Km. Regarding usual wear and tear, I consider myself a sane driver (rather insane driving is impossible in Bangalore city!). Heavy braking is limited to rare occasions of high speed driving on highways. @sgiitk, brake fluid has been already replaced during recent 3-years service. As I mentioned earlier, it was supposed to be done in the previous (2 years) service itself, but those guys missed it. I am aware of expected drop in level due to wear, all I can say is that it was negligible so far, in the sense it never came below the MAX mark. It is possible that they might have topped it up in the previous service. But then I have been watching all fluid levels once in a while, so anything considerably below MAX level would have gotten my immediate attention. Therefore possibility of topping up last time is very unlikely, and it must have been a small quantity if at all. Last edited by santosh.s : 10th February 2009 at 14:18. |
| | #10 (permalink) | |
| BHPian Join Date: Oct 2008 Location: Bangalore
| Quote:
So, checking the fluid level and the indicator regularly, is a must under the circumstances. I would still recommend a second opinion - i.e. take the car to another reputed garage and get the cylinder inspected.
__________________ Safari Dicor 2.2 [2007] / Zen [2001] | |
| | #11 (permalink) |
| Rubber brake parts fail more on age than driving. Three years is a bit early for a brake overhaul (more like 5-6 years) but one never knows. If you keep a daily watch (I hope you actually follow your pious intentions) and get the cylinder attended to at the first sign of trouble you should be Ok. Please keep (say) 100-250ml of brake fluid in the car for an emergency. However, I will be inclined to take care of cylinder at the first convenient opportunity.
| | #12 (permalink) |
| BHPian | Thank you guys for all the gyan! @ak-47, I completely read the thread you mentioned (I had to )Also, went through the braking system chapter of baleno's service manual. I felt greatly relieved when I came to know that because of primary/secondary arrangement of circuits, entire braking system can not fail at once, even if one circuit gets completely drained out due to a leakage. Each hydraulic circuit takes care of two wheels, one front and one rear which are diagonally opposite. It is true that leakage in any one circuit will eventually drain out fluid from reservoir. But before the other circuit fails, I would expect to get ample indications to notice it and time to get it fixed. Any one of the following can warn you ahead of potential danger- - Excessive brake pedal movement. - May be lesser braking effectiveness as braking is applied to only two wheels. - Empty fluid reservoir. If you have a habit of checking engine compartment once in a while, you should catch it in advance (unless leakage is abrupt). - Brake failure warning light. - Stains around wheels, parking area. I believe when you unfortunately experienced a complete failure, it must have failed partially first and above symptoms must have gone unnoticed. Also, I strongly feel (based on my understanding) that even when one of the circuits as well as the reservoir is entirely drained out, the other circuit should be effective for quite some time.... until you wait for another leakage to develop in it OR brake pads wear out enough to eventually let air bubbles creep into it, causing "spongy" pedal first followed by gradual failure. Am I getting it right?? PS: don't get me wrong, I am not trying to justify further delay in my repair, I will get it done soon anyway. Arguments above are just to understand how exactly braking system works, and more importantly what to look for in case of problems! |
| | #13 (permalink) | ||
| Quote:
BTW, since your brake-fluid indicator is fine, why not just keep some spare brake fluid in the car. You can top up at the first instance of the low-level indication, and that should give you enough time to reach the nearest garage - if and when you face a brake-leak situation.
__________________ Safari Dicor 2.2 [2007] / Zen [2001] | ||
| | #14 (permalink) | |
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
| Quote:
Leakage in one wheel's piping can drain half of the system, but the other half stays fully functional. | |
| | #15 (permalink) | |||
| BHPian | Quote:
That said, the piston separating primary and secondary master cylinder compartments seems to be almost redundant under normal condition. It has a role to play only when one of the circuits fails! As this would be very rare and something that nobody would like to test, it may be very difficult to know if that piston is free of leaks. Quote:
(It is not clear from figures/description in the service manual, as to how exactly each master-cylinder draws fluid from the reservoir) Quote:
| Thread Tools | |
Similar Threads | ||||
| Brake Fluid Replacement - IMPORTANT | vigsom | Technical Stuff | 37 | 16th October 2009 02:29 |
| Brake Fluid Help! | rohanarthur | 4x4 Technical | 4 | 6th July 2009 11:21 |
| Anyone using DOT 5.1 brake fluid?? | Shan2nu | Technical Stuff | 17 | 30th March 2009 11:01 |
| Brakes Catch Fire / Brake Bed in procedure / Brake Shudder : Solved | Indian1979 | Technical Stuff | 25 | 4th March 2009 13:37 |
| Brake fluid/Parking Brake Indicator light- Is this a problem? | santosh.s | Technical Stuff | 7 | 12th November 2008 00:05 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
