Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 10th February 2009, 19:51   #1 (permalink)
Default Weird problem - Ikon
Hi all,
Ive been facing a weird problem with my car for the past week or so. Have been lazy to take it to the Ford authorised service centers, its first on my list tomorrow.
heres what happens :
Irrespective of the engine temperature, the car does not rev beyond 2000RPM. this is with the clutch and throttle fully depressed. this happens only when the car is moving.
when the car is stationary, the engine hesitates slightly at 2000RPM and the proceeds to the redline. no problems there whatsoever.
to add to the complexity, this started only after my engine swap - from a 1.6 to a 1.3
anyone experience this?
thanks,
Madhu.
madhunm is offline   Reply With Quote
Old 10th February 2009, 22:58   #2 (permalink)
Astleviz's Avatar
Did you also change the ECU, the oxygen/lambda sensors and the gearbox along with the engine?
__________________
And all you touch and all you see
Is all your life will ever be...
Astleviz is offline   Reply With Quote
Old 10th February 2009, 23:14   #3 (permalink)
Hi Astleviz,
No. the ECU is from the 1.6, so are the O2 sensors and gearbox. I called Ford after posting, they said that those should not matter.
They said, that over the phone, they suspected the TPS(throttle position sensor), throttle body, MAT(a hybrid MAP and IAT sensor) and the crank sensor.
well, any idea where i can get these sensors here in Bangalore?
thanks,
Madhu.
Old 11th February 2009, 01:27   #4 (permalink)
SirAlec's Avatar
1.6 to 1.3, now why on earth do you do that??
most of here always thinks of doing the other way round.
__________________
Still! Living Life a quarter mile at a time.....post being Dad.
Old 11th February 2009, 01:34   #5 (permalink)
Well, to cut a long story short, all 4 cylinders seized and are scored badly. picked up this 1.3 engine for a bargain, and had a daily driver for a while.
now, no driver. :(
say, does anyone know if Race Dynamics has an ECU for the Ikon?
~M
Old 11th February 2009, 01:37   #6 (permalink)
sammyboy's Avatar
Plus 1 to that. I have had a 1.3 for 3.5 years and would kill for a 1.6. Why the downgrade. Where did you get that done from? Are you sure the transplant was perfectly done?
__________________
Honk your Head off. I will NOT jump the red light
sammyboy is offline   Reply With Quote
Old 11th February 2009, 02:30   #7 (permalink)
Astleviz's Avatar
Originally Posted by madhunm View Post
Hi Astleviz,
thanks,
Madhu.
Even if you were able to get the TPS, throttle body and the MAT, I doubt if your ikon will run perfectly. For one, the 1.6 has a shorter gear box (gear ratios are closer) as compared to the 1.3. Also I'm not sure if the 1.3 and the 1.6 share the same ecu.
The only place you can get the sensors is from the Ford dealers, I don't think these are available in the market.
__________________
Old 12th February 2009, 19:23   #8 (permalink)
Hi all,
got some updates. I swapped out the TPS, MAP, and Crank sensor, no difference. While i was swapping out these, had the intake manifold and throttlebody cleaned.
I took the her to Metro Ford, who, after a long drawn process of making me wait, agreed to run diags.
The technecian who ran the test was more focussed at hiding the results from me rather than tell me the results. I managed to sneak in and look over his shoulder, there were a lot of DTC error codes.
There were two which caught my attention, one said that 'Circuit A of ignition circuit failing' and the other was that the 'VSS reported intermittent failure'
I know now that the problem is with the wiring, shall fix it and let you guys know.
Regarding the 'downgrade', the 1.3 engine is running just till i get the 1.6 engine modded as per my desires/needs.
Thanks,
Madhu.
Old 12th February 2009, 23:25   #9 (permalink)
Astleviz's Avatar
It may be just a wiring issue but more likely it's an ECU issue, 1.6 and 1.3 have a different ECU, I'm not sure how an ECU that has the maps for a 1.6 L engine can work just as fine for a 1.3 L engine without any tweaks/changes. Even the gear ratios are different for both these cars.
__________________
Old 13th February 2009, 01:58   #10 (permalink)
Hi Astleviz,
Both the 1.6 and the 1.3 have the EEC-V ECU, although made by different vendors. Over the years, the vendors have gone from Visteon to Bosch to now, Siemens.
Even the countries of manufacture has changed. Notwithstanding that, i dont think the maps make the engine to cutout at 2000RPM.
Gear ratios will come into picture only when the engine runs well. this one does not go past 2000RPM.
Old 15th February 2009, 18:58   #11 (permalink)
As far as I know, Ford has standardised the ECM`s to EEC V.
I did a lot of research on this when my ECM blew off and had to be replaced. I was told at that time that the Fiesta also has the same ECM ????
One more thing - the ECM`s are imported from Brazil ( they were in 2006).
dashoin is offline   Reply With Quote
Old 15th February 2009, 21:55   #12 (permalink)
Astleviz's Avatar
Have you managed to figure out what the problem is? Did rewiring help? Keep us posted on this peculiar issue.
__________________
Thread Tools
Weird temperature problem teknophobia Technical Stuff 4 26th August 2008 23:52
Weird iPod problem madbullram Gadgets, Computers & Software 3 27th July 2008 01:29
Weird problem...Palio Iknowthisguy Technical Stuff 16 31st August 2006 09:58
Weird computer bootup problem adya33 Gadgets, Computers & Software 7 28th March 2006 23:50
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
