Old 16th February 2009, 12:28   #16
weejai's Avatar
I guess I paid quite a bit, well its over now. I hope to find a good workshop somewhere around Andheri like the one you have mentioned KSM & get parts from better shops (may be one from the list in the link down below)
Most of the 'garages' around here are where the mechanic stays in the shed with his family and no bay, no ramp for under body inspection, nothing more than few sets of spanners and jacks. For a 'quick-fix' they might be good, not sure otherwise.
Also, this might be a repeat, but I found the below link that lists down either the manufacturers or authorised dealers/suppliers of various automotive spares in different cities. Looks interesting:
Indiacar Mall - Automotive Spare Parts, Local Parts Dealers, Buy Car Parts, Buy Two wheeler Spares
weejai is offline   Reply With Quote
Old 17th February 2009, 11:22   #17
ankitahuja's Avatar
Thanked: 46 Times
I recently got disk facing / polish done. This included a change in brake pads and brake shoes, including a change of all cylinders. Basically, a full brake overhauling.
Went to Jaipur 3 days back and can tell you that the braking was FANTASTIC.
The rear wheel drum brakes were set very properly and carefully when the handbrake were not working (after the brake shoe change), this made a huge difference in the overall braking. The car was stopping so quick, which would otherwise have ended in a wheel lock situation or delayed braking.
Arush / Autopsyche has done an excellent job on this.
Old 3rd March 2009, 16:21   #18
narayan's Avatar
Thanked: 1,356 Times
Default brake noise from front and rear brakes
revivivng this thread with a a problem I am facing for last 1 month
on the right side of the car, both the front and rear wheels make a "kuch kuch " sound when i jack up the car and rotate the wheels.
this sound comes only when the wheel is rotating past a particular point. its not a regular continuous sound while rotating..
after noticing this i got the below done
1) got the front disc skimmed and brake serviced completely
2) rear drums also skimmed ( not sure how that is done but was told that has been done ) and the brakes were serviced
even after doing the above, i still get the same sound
do you guys know what this could be because of ??
i need some urgent advice so that i can get this fixed. thanks
narayan is offline   Reply With Quote
Old 4th March 2009, 10:47   #19
narayan's Avatar
guys
i know brakes etc is among the most boring of technical issues. .. but i need some views from u on what the above could be due to ..
pls share ur thoughts so that i can explain to the mechanic accordingly.
thanks
Old 4th March 2009, 11:12   #20
Thanked: 12 Times
brakes and boring? whoever said that?? show me something that beats the sheer sight of manhole cover sized rotors and orange callipers.
could your problem be because the wheel isnt perfectly mounted and 'swings' as it rotates, touching something along the way?
also, I plan to convert my OHC's rear brakes to discs at some point in time. comments? suggestions? experiences?
blacmagic is offline   Reply With Quote
Old 4th March 2009, 14:39   #21
nitrous's Avatar
Thanked: 285 Times
thalaivaa, who diagnosed it to the brakes?
if the brakes were serviced and the noise hasn't gone, then its a case of clear mis diagnosis.
Please check for a worn driveshaft.
Old 4th March 2009, 15:10   #22
narayan's Avatar
Diagnosis given by a "reputed" workshop here sir..
so i guess it was a mere coincidence that both the right side front and rear drive shaft are worn out ??!!
are the shafts on left and right similar so that i can do some testing before buying new shafts ? ( i am guessing in the front, the right side shaft is smaller ? )
Old 4th March 2009, 22:09   #23
KSM-Vtec's Avatar
Thanked: 440 Times
Agree with that for sure.
Originally Posted by pranavt View Post
Drilling brakes will cause micro-fractures in the rotor. Not advised by some respected tuners here. Getting better pads and ventilation should be enough to give much better braking.
Check for the wheel bearing also. there is a remote possibility of something being wrong there because you would have got a constant rumble if there was something wrong with the bearing. but you never know.
Be sure that the wheel/rubber is not touching something..
well its not necessary that its a coincidence. they could have gone because of a bad hit that you have had on the right side.
KSM-Vtec is offline   Reply With Quote
Old 4th March 2009, 23:25   #24
iraghava's Avatar
Thanked: 156 Times
There's no rear drive shaft in an OHC Narayan, it's a FWD. And no, both side Driveshafts are unequal length.
Old 5th March 2009, 13:52   #25
narayan's Avatar
true buddy !! basics na ! i jacked up the car today and realised that!
but the front wheels are hardly rotating freely while jacked up - as if there is some friction
i hope its just the brakes and not some driveshaft/bearing issue !
have been driving this car so so carefully - even slow down for small pebbles on the road
Old 5th March 2009, 14:55   #26
iraghava's Avatar
Thanked: 156 Times
Get the Bearings checked first followed by the calipers. Make sure the sliding pins on the calipers are greased properly and that they have smooth movement.
Old 5th March 2009, 14:59   #27
nitrous's Avatar
Thanked: 285 Times
Have they checked the wheel cylinders ?
They shouldn't be leaky or jammed.
Have a look at the wheel bearings as suggested by others too.
Old 5th March 2009, 15:00   #28
narayan's Avatar
Ishan anyway of checking the bearings separately whether they are worn out ? can they be removed and rotated with hand to know this ? will get this checked this weekend..
@Nitrous - yes i suppose the wheel cylinders are checked becos i got the entire brake assembly serviced last week
Old 7th March 2009, 02:44   #29
Ali G's Avatar
@narayan: please get the rubber bushes in the suspension also checked. They might slit out due to a harsh driving style or wear out eventually.
Just my 2 cents
Same here.
I often feel the OHC wheels in the rear get locked during emergency braking and the car spins out. I also feel they are weaker when compared to a car of the same era; eg: baleno.
Tech Gurus help
Ali G is offline   Reply With Quote
Old 7th March 2009, 03:18   #30
That's because you pull the handbrake Drift King!!
Indian1979 is offline   Reply With Quote
DIY: Skoda Fabia Brake Disc / Rotor Change & 4th Service too! aayushnair DIY - Do it yourself 23 28th November 2015 13:26
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 8 25th October 2011 17:18
Disk Brake to normal brake change? ramki067 Motorbikes 10 7th August 2008 14:19
Palio Mods (TC, ECM, & Rear Disc Brake Conversion) sbfx Modifications & Accessories 37 25th May 2007 20:11
disc brake lock up in OHC narayan Technical Stuff 10 27th January 2007 10:50
