Old 7th March 2009, 10:42   #31
Tejas@perioimpl's Avatar
Thanked: 5,479 Times
Originally Posted by Ali G View Post
Same here.
I often feel the OHC wheels in the rear get locked during emergency braking and the car spins out. I also feel they are weaker when compared to a car of the same era; eg: baleno.
Aren't you contradicting yourself? You say the brakes are weak and also they lock! So what will happen if you put discs at the back?
In my opinion, a stock, or even rather a street stock modified OHC does not need any brake changes. Just a good brake service &/or upgradation of brake pad quality is fine.
Tejas@perioimpl is offline   Reply With Quote
Old 7th March 2009, 13:28   #32
toiingg's Avatar
Thanked: 85 Times
Even I got my Front Pads changed today.
Replaced with O/E Nissin. Braking has changed, i feel its got a little less bite than it used to have, but thats just an impression in Mid-day traffic, on a 2km drive home. Haven't got a chance to bed them in yet. Braking should improve once that is done.
Pads cost me 950/- and total came up to 1400. That includes skimming the discs + slight welding job on my exhaust.
Btw, stock lasted me 100770 KMS. And by the looks of things, still had plenty to go. No screeching no fade no loss of braking. Just changed them, cause I came across this thread and thought heck, everyone's doin it, I might as well get it done also. Don't want my baby to feel neglected.
toiingg is offline   Reply With Quote
Old 7th March 2009, 13:39   #33
Don't sudden (jam-in) brake for approx 20kms. Let the pads run in. Then feel the difference.
Old 8th March 2009, 05:00   #34
Ali G's Avatar
I said the wheels not brakes in the rear lock during emergency braking.. Didnt say the brakes were a cause.. If they were i believe the discs in the front would lock first in a fwd car because of the bias present. I projected a seperate observation by using the phrase ' i also feel' they are weaker 'when' compared to a car of the same era. Which means they fail to do the job in a fruitful manner when compared with another machine of the same time and caliber. It wasnt one statement like you said,' they are weak and they lock too' nor in that order. Just thought something could be wrong with the wheels or the braking or suspension or because of any other synchronized mechanism in the rear that is causing it to lock and sometimes also initiate a drift. Or is it the lack of ABS on it..
Thank you for your opinion on the braking pads upgrade. I appreciate it.
Ali G is offline   Reply With Quote
Old 8th July 2009, 12:05   #35
sushrutha's Avatar
Thanked: 325 Times
Need to change my OHC brake pads. Whitefield Honda quoted almost 4K for brake pads+labour. Need to know which is the OE (manufacturer, part number) for OHC & also approx price for the brake pads & availability in Bangalore
Old 8th July 2009, 14:50   #36
ankitahuja's Avatar
Thanked: 46 Times
Nissin is OE for Honda City
Old 8th July 2009, 15:18   #37
sushrutha's Avatar
Thanked: 325 Times
Thanks ankit, shall check out in some automobile shops in JC road.whatz the price of the brakepad set ?
Old 8th July 2009, 18:11   #38
ankitahuja's Avatar
Thanked: 46 Times
Umm, I'm sorry, I just can't recall. I bought a set once for about 400-500. Then I bought another set later for 1.6k. Don't remember which was which :(
Old 8th July 2009, 18:50   #39
ssjr0498's Avatar
Thanked: 120 Times
AFAIK you will not get pads with NISSIN written on the box. They are sold as Honda OE and should cost you around 2200/-
The box has the Honda sticker on it and also mentions the part number. Its only when you open the box and check you will see Nissin engraved on the outer side of the pads.
Not all shops in JC road have these pads as they are expensive when compared to some malaysian/local stuff (which cost around 600-800).
Shrey
ssjr0498 is offline   Reply With Quote
Old 9th July 2009, 10:48   #40
sushrutha's Avatar
Thanked: 325 Times
Shrey
Shrey,I had been to JC Road bylanes. I have found 2 shops having brake pads for OHC, one shop has original NISSIN brake pads with NISSIN written on the box, this is original, price quoted 1750Rs. Another shop has Honda sticker box with part number, with Nissin brake pads in it, Price quoted 1750 Rs... So confused as to go with which one, I may probably go with the Original NISSIN brake pads.Yep Local OHC brake pads start with 500 Rs.Strage to hear that toiing got OE Honda - Nissin brake pads for 950 Rs
Even I got my Front Pads changed today. Replaced with O/E Nissin. Braking has changed, Pads cost me 950/
Old 9th July 2009, 17:50   #41
ankitahuja's Avatar
Thanked: 46 Times
True. All Honda OE parts come in the Honda Sticker packed boxes.
That's quite a FIX there! I'd buy the Honda Sticker Box (at least you can be sure this part if for the Honda City). Also, see that the box just doesn't have 4 brake pads, but also some extra stuff as well (I think mine had some special sand paper kind of thing, etc)
Old 9th July 2009, 21:14   #42
Thanked: 45 Times
Rs.3500 for brake pads for OHC seems high, but it seems OE spare is high.
I have skimmed my 2 front discs of my lancer yesterday
brake disc skimming for Rs.200
TNG ceramic brake pads for Rs.650
labour Rs.150
Labour includes changing tie rod ends costed about Rs.700/set of sona make.
OE sumitomo brake pads cost Rs.2200...But i gone for TNG , some taiwan make i think. But it does its job good
rajivanoj is offline   Reply With Quote
DIY: Skoda Fabia Brake Disc / Rotor Change & 4th Service too! aayushnair DIY - Do it yourself 23 28th November 2015 13:26
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 8 25th October 2011 17:18
Disk Brake to normal brake change? ramki067 Motorbikes 10 7th August 2008 14:19
Palio Mods (TC, ECM, & Rear Disc Brake Conversion) sbfx Modifications & Accessories 37 25th May 2007 20:11
disc brake lock up in OHC narayan Technical Stuff 10 27th January 2007 10:50
