Old 29th April 2005, 09:39   #1
Default Wind noise or Aerodynamic noise
Not too sure whether i named the topic correctly.. please do correct.. if required after reading the content....
I am referring to the noise of the gushing wind outside the car when i am driving at speeds of 70+ kmph.... in a crude manner i would call it "aerodynamic noise".... it effectively is the noise of the car cutting thru the wind.... somethin like "WHOOOOOOSSSSSSSSSHHHHHHHHHHHHHHHHHHHHHHHHH"
and yes.. this is inspite of all windows being rolled up
I used to get the is noise while driving my zen, but i thot.. its coz its an old car..... so maybe.... but i now face the same in my baleno too....
I hope i have been able to put across my thoughts clearly.... if so... do you guys hear such a noise while driving....
or is that this is standard.. will be there types....
Expert opinion please.....
vivaid is offline   Reply With Quote
Old 29th April 2005, 09:52   #2
iceman91's Avatar
Thanked: 22 Times
roll the windows up!!!
yes vivaid it is the turbulance caused by the vehicle...same as in all other vehicles!!
it is standard
iceman91 is offline   Reply With Quote
Old 29th April 2005, 10:05   #3
Thanked: 9 Times
yes it is noise your car makes while cutting thru the air...
my car has more of tyre noise though...particularly when I'm on abbrasive road patch..
Abhay is offline   Reply With Quote
Old 29th April 2005, 10:19   #4
cheatingdeath's Avatar
definately its going against wind resistance ... will have to make some noise
yes the noise is reduced in cars such as the camry and accord due to lower drag co-eff fer example the camry has a drag co-eff of 0.29 that is because of its body design and hence it can carry through the speed with minimum loss due to resistance
well drag co-eff has no units since its a co-eff
cheatingdeath is offline   Reply With Quote
Old 29th April 2005, 10:59   #5
Thanked: 7 Times
Default Noise
I Baleno there are considerable rolling noises,which i have read due to bad rear suspension design.These were also present in Old Honda City due to same rear suspension design.I have also heard that Honda has changed the design completely in New Honda City.
abhi1881 is offline   Reply With Quote
Old 29th April 2005, 14:43   #6
Thanked: 64 Times
@Ice, he says he is getting this noise inspite of having all windows rolled up. To me, that is bit strange. I don't think at 70 kmph, there should be so much noise with windows rolled up.
@vivid, can you explain more about your problem?
RX135 is offline   Reply With Quote
Old 29th April 2005, 18:20   #7
well rx.. 70 was more off-the-cuff... never observed it so particluarly.. but u cud say 70-100....
rgds
Old 30th April 2005, 11:19   #8
iceman91's Avatar
Thanked: 22 Times
at 70-100...getting a whooosh noise ????
well check if the windows are up all the way as in there is no gap also check it you dont have faulty window lining...
Old 2nd July 2006, 10:15   #9
vigsom's Avatar
Thanked: 603 Times
I have also experienced noise in cars fitted with luggage carriers.
vigsom is online now   Reply With Quote
Old 2nd July 2006, 10:56   #10
R32_GTR's Avatar
Thanked: 184 Times
Hi mate...
loved the way you desribed the sound..
here are some things you might wanna check...
  1. check you wiper blades...most common noise makers...
  2. your wind screen lining...check for leaks..
  3. any aftermarket stuff you might have added on the outside like an antenna, spoilers, lips, spliters, an aftermarket front bar/bumber etc..also common.
This should solve the problem if its not a factory defect.
note: please check your radio as well !!!
On the flip side: if the noise still persists, TURN THE RADIO UP!!! (should overpower the wooooosshshhsh sound!!)
Drag is one #@$%##$....(EVERYONE hates it - in relation to cars that is...or SPEED) can be solved...but requires a lot of resources......
Good luck...
R32_GTR is offline   Reply With Quote
Old 2nd July 2006, 11:52   #11
rks
rks's Avatar
I can hear a lot of wind noise in my Santro at high speeds. Sometimes at 140 kmph or higher, the right rear-view mirror closes slightly. When I roll down my window and try to put my hand out to make the adjustment, the winds on the Expressway are so strong that they sometimes push my hand back!! Have to use some muscle power -- I don't feel very safe doing this operation and fear that I might even lose control.
Old 2nd July 2006, 12:32   #12
2fast4u's Avatar
check the rubber lining / beading along the door and windscreen frame
2fast4u is offline   Reply With Quote
Old 2nd July 2006, 12:45   #13
2fast4u's Avatar
first dont do something u feel u may get into out of control.
try to get some twine (plastic fishing thread) and get pulled into the thin bottom area swivel of mirror movement. this will arrest the mirror movement to some extent.
Old 2nd July 2006, 13:47   #14
rks
rks's Avatar
Thanks for the info. Will try that. Actually I get the side mirror tightened every service, but this doesn't seem to work for very long.
Old 2nd July 2006, 14:03   #15
2fast4u's Avatar
use Teflon tape or Threadseal when u plan to get it tightened next time alternatively if u know how to open it diy.
Eliminating Wind Noise Seacat Technical Stuff 12 31st July 2014 13:51
An aerodynamic Rolls Royce. v12 The International Automotive Scene 17 6th December 2008 23:02
Wind Noise in Safari Ramkumar Technical Stuff 2 13th August 2007 17:58
Survey on Aerodynamic Body Kits Vulken Auto Modifications & Accessories 52 4th August 2005 14:30
