Closed Thread
Old 20th May 2009, 21:15   #16
karthik247's Avatar
Thanked: 16 Times
Idling for a minute or so is always better after starting the car and before turning it off at the end of the day. Also don't turn on the AC immediately after starting the car. Wait for about 10mins or so..
BTW, aint there other threads on this topic?
karthik247 is offline
Old 20th May 2009, 21:49   #17
sharma_sanjeevi's Avatar
Thanked: 62 Times
I do Idle my Carbed Maruti-800 / Swift Dzire before starting off on the road & find the Engine is a lot more smoother as compared to straight away switching on the engine & starting off on the road.
I have following queries in this regard to the experts:
1. In the MPFI Engines (Swift Dzire), can we Switch ON the AC as soon as we start the engine when the engine is warming up ?
2. Will it have adverse effect on the longevity of the Engine ?
3. By Normal practice i Switch ON the AC after the car has run 1 to 2 Kms & the engine is at optimum operating temparature, is it right?
sharma_sanjeevi is offline
Old 21st May 2009, 02:31   #18
varun911's Avatar
Do search around here on TBHP, and you will find if it is necessary. But what is necessary is to search before you post ! There is a wealth of information here.
Check out the below link where this has been discussed already, it is pretty informative
http://www.team-bhp.com/forum/techni...cts-added.html (10 Engine Idling "did you knows" EDIT: Myths & Facts added!)
varun911 is offline
Old 21st May 2009, 02:37   #19
motionfreak's Avatar
Thanked: 54 Times
^^ It is OKay to switch on the AC as soon as u start the engine in MPFI cars. but it's found to be more effective if u switch it on after driving 1 KM with windows rooled down so that the hot air can get out. (only if cabin's internal temp is higher than the outside)
motionfreak is offline
Old 21st May 2009, 10:54   #20
gpa
gpa's Avatar
Thanked: 273 Times
This is a good technique to follow, remember for the AC to work effectively, the engine must be warmed up for the heat exchange to take place. Switching on the AC 2 or 3 minutes after start up is recommended.
Cheers,
gpa
gpa is offline
Old 21st May 2009, 11:05   #21
Thanked: 62 Times
Cheers,
gpa
@motionfreak & gpa,
Thanks for sharing the views, that is the exact practice i am following with regards to Switching ON the AC only after the engine is at optimum operating temparature with windows rolled down for letting the hot air out, as pointed out by motionfreak as around 9 to 9:30am is the time when i usually take out the car & it is directly under the sun & is hot, as we dont have stilt parking in our society.
Wanted to confirm this with you guys that am i following the correct procedure or not.
Old 21st May 2009, 11:48   #22
dilipkumar7278's Avatar
Thanked: 23 Times
I relegiously idle my cars for 3 to 4 minutes before starting off in the mornings. This has been my practice ever since I started driving. Also I switch on the AC only after the nearest BP pump which is 1km away from my home. Though not an expert, I think it will be better for the engine in the long run.
Dilip Kumar
dilipkumar7278 is offline
Old 21st May 2009, 16:50   #23
Thanked: 27 Times
The link that you gave pretty definitively says Idling is not required. Well, my car is Turbo IC Indica. Do I need to idle or not?
Normally, I don't. I just start and move off. And I just stop and switch off. I even switch off-on if traffic light will keep me in red for 30 sec or more. What is the verdict? I'm confused.
Moreover, what does idling at stopping mean? does it mean keeping the engine running for some time even after the car comes to a standstill before turning off?
Some mechanics advised me to throttle high for a few seconds before turning off, apparently this charges the battery. I don't do this as well.
GenuineOptimist is offline
Old 21st May 2009, 18:55   #24
Idling before turing the engine off is a good practice. It is done so that the turbo can stop spooling. No need to rev up your indica before switching off the engine. As you're again pumping up more oil into the turbo so you will need to wait extra 1 min or so before switching off the engine.
Idling for a diesel engine at start and stop is a must. Before starting off, it lets the oil rotate in the whole engine and also allows oil to reach engine and turbo so that it reaches optimum level of operation. In modern diesels, 1 min of idling at start and stop will be good.
911turbo is offline
Old 21st May 2009, 19:16   #25
asr245's Avatar
Thanked: 360 Times
On cold start , the engine starts rev'ving from about 1700rpm in my mpfi WagonR. I usually wait till it drops below the 1000 mark before i start off or turn on the AC and drive it easy (usually below 2500rpm) till it reaches the operating temperature. I don't let it idle while turning it off.
asr245 is offline
Old 21st May 2009, 19:21   #26
beejay's Avatar
Thanked: 109 Times
I usually idle turbo diesels before and after as this helps in the oil to reach and drain from the turbo.
However for petrol engines I hardly do this, especially on stopping.
beejay is offline
Old 21st May 2009, 19:33   #27
theodore_ftw's Avatar
I had read somewhere that you should roll up your windows and switch on the AC to improve FE any time you travel at speeds more than 60kmph as the drag increases significantly above 60kmph. I do let my car idle for about 30 seconds while i am putting on the seat belt etc and then switch on the AC once the temperature gauge shows some activity.
theodore_ftw is offline
Old 21st May 2009, 21:49   #28
Raj1008's Avatar
Thanked: 12 Times
Yeh I read that too, so when on the highway I shut the windows and sunroof. Same with idle, though I idle for about a min or so.
Raj1008 is offline
Old 22nd May 2009, 00:15   #29
TRAUMASURG's Avatar
Modern cars do not need idling for warm up that is true for fuel injected cars.That said do i idle the car.I do when the outside temp is below freezing.I wait till the tach needle comes down at idle below 750 rpm otherwis i dont do it on any of my benzs.but i do wait for a while on my f430 sp.My f430 when i turn on the key it goes through diagnostics and then it will flask OK in the speedo gauge ,then i press teh starter ,i wait for few seconds may be 10-15 second then i drive slowly till engine is warmed and then i let it loose
TRAUMASURG is offline
Old 23rd May 2009, 13:02   #30
mithun's Avatar
Thanked: 49 Times
Another thread : http://www.team-bhp.com/forum/techni...-vehicles.html (Idling Time during Morning Start for MPFI Vehicles)
mithun is offline
Closed Thread
Global Warming - Guilty/Not guilty theMAG Shifting gears 23 26th July 2017 10:52
Do all Turbos require idling before shut-off? GTO Technical Stuff 117 24th October 2012 20:10
Inconsistent idling and engine shut off problem DCEite Technical Stuff 17 18th May 2012 22:37
Global warming..to the point of no return111 rajshenoy Shifting gears 0 3rd April 2007 17:36
Idling the Turbo engines before switching off.. Could this be a solution? DRC Technical Stuff 14 5th April 2006 21:19
