Old 14th February 2009, 01:50   #16
Tool's Avatar
WOW !!!
Thank you soo much sir ajmat !! . Talk about knowing a Vrs inside out.
This thread has put my fears to rest actually. !! Im hoping to get one very very soon myself and this thread is invaluable !!
If one does preventive maintenance ever 40 K km then one should be more than ok . no problems with that .
i really dont mind the timing belt/coils/water pump problems. Have no issues whatsoever in spending 30-35K ever 40,000 Km that i driver her.
Its the least i can do for a engine that puts out that kind of power it does and has to deal with crappy indian roads and crappy fuel .
Heck every service of my esteem cost me atleast 12-15 K anyways . so i dont find this bad at all. I know 12-15K service sounds a lot for a maruti. but thats the only way i ever felt satisfied with my car !!
Synthetic oil , K&N oil filter , injector cleaning , TB clean , Carbon clean Wheel Alignment Brakes Reset . New pads and Discs and brake flluid etc are all done every 10,000 Km maximum on my esteem and new iridium plugs every 20,000 km . Heck i change my Gear oil ever 3000-5000 Km just cause i can feel a difference . Some people call me stupid.. some call me anal.. but thats me
Cheers sir and Thank you very very Much.
Now more than ever im determined to go get me a VRS.. PLEASE HELP
Its good to be back !
Tool is offline   Reply With Quote
Old 14th February 2009, 02:19   #17
JayD's Avatar
Thanked: 2,007 Times
Gawd that's a lotta work for a new-ish car. I guess this is why one ca find that most used RS's in the market have done around 50K. I guess the original owners sell them before the trouble starts!
Old 14th February 2009, 06:19   #18
muneemmk's Avatar
Thanked: 17 Times
Ajamt's been through hell and back, is this a problem commonly associated with the VRs or did Ajmat's S(K)oda come with Lemon ? The cost of the parts are unbelievable at usual Skoda A S S.
Last day a person I know changed his Drive shaft in his Laura for 16K,he imported this part from dubai, the A S S's part price for the same was around 30K , after this his A/C compressor conked off Cost 1.25 Lakh ,he's gonna import that too, The Sanden 507 compressor usually fitted on Ambys cost around 9K I wonder weather this could be fitted on the Laura .
Now how are people driving around in Skodas with Power upgrades of 200+BHP doing ? The more heat the more power, more electronics, More problems ?
muneemmk is offline   Reply With Quote
Old 14th February 2009, 08:15   #19
aaggoswami's Avatar
Thanked: 1,526 Times
Very well structured posts. The costs are mind numbing, may be mind numbing is too mild a word. These failures in car that costs above Rs. 10-12 lakh happen only in India and Skoda can get away with impunity.
Write this to Skoda and give link of this thread.
What surprised me is that the 1.8T is also an interference engine. I now want to list down the cars with interference engines. I knew about Skoda Octavia diesel and Ford Feista, diesel or petrol I dont remember.
Skoda should have offered chain instead of belt and that too enclosed. This is I think second incidence of timing belt failure after Jalsa777's Skoda Octavia diesel that took hit from another vehicle and the belt snapped.
More and more threads are coming up for bad skoda quality.
Had skoda being into below Rs. 10 lakh segment from the begenning, they would have packed up. The only reason they are surviving in India is beacuse of their pseudo " premium " image.
aaggoswami is offline   Reply With Quote
Old 14th February 2009, 13:44   #20
iraghava's Avatar
Thanked: 156 Times
Why? - Timing belt snapped
What is THE damage? Officially Rs 150000 for a head rebuild, a lot less if done by a good independent
It costed us approx. 50k since we got it done outside. Finding the Genuine Timing Belt for the vRS (150 grooves) was a pain though. Had to be sourced from outside India.
Old 14th February 2009, 13:46   #21
Thanked: 101,982 Times
Invaluable information for RS owners (current & potential).
Ajmat, miss the Japs?
Old 14th February 2009, 15:56   #22
siddartha's Avatar
Thanked: 23 Times
VW and Audi 1.8T Engine Coil Problems
details regarding coil packs, 2003 onwards may not have this problem
siddartha is offline   Reply With Quote
Old 14th February 2009, 16:37   #23
mura's Avatar
Thanked: 18 Times
IIRC Toyotas and most Japanese cars with timing belts only need replacement of the same every 1lac kms, and mostly are non interference engines.
I had a 1998 Subaru Legacy in which the Tbelt failed after 270000km. I bought the car assuming it had clocked only 70000km as the ODO was clocked back but the guy left the log book indicating the true milage in the car.
Thank god it was a non interference engine. Rs.1500 later it was running again.
You certainly can't beat the japs for reliablity.
mura is offline   Reply With Quote
Old 14th February 2009, 20:30   #24
R2D2's Avatar
Thanked: 1,828 Times
How do I know? - Engine may not turn or makes expensive noises when turned
What is the damage? Pistons hammered the valves, if they are waving at you when you lift the engine, ouch
I am horribly shocked. Shoddy dealers, high maintenance costs, horrendously expensive spares and low reliability .
And people still find a reason to buy a Skoda? No wonder Europeans treat Skoda like you know what. We should learn from them. German QUALITY my foot.
Rgds,
Old 14th February 2009, 20:53   #25
SS-Traveller's Avatar
Thanked: 11,592 Times
Even Hyundai recommends a TBelt change at 100k km, though I've changed mine on the Accent Viva CRDi at 87.5k km. Not sure if it's a non-interference engine.
Old 14th February 2009, 22:43   #26
Gasolinejunkie's Avatar
Yup, you couldnít be more on the money. Vdubs, Audis and Skodas are great cars when everything is working well but can be real lemons when they start playing up. And with the electricals you sometimes get intermittent issues that are really hard to diagnose.
Iíve seen issues with the coil pack on the Passat, and when they were replaced it still didnít purr because the valves were leaky. And that was on a 100,000 (give & take) engine. But what shocks me is water pump and timing belt issues at 40,000km. On a car that new I wonít even bother changing the transmission fluid. With the stabilizer bar link-pin bushes, replace them with urethane bushes. They last a lot longer.
Gasolinejunkie is offline   Reply With Quote
Old 14th February 2009, 22:54   #27
flipsyde's Avatar
Thanked: 62 Times
I think the biggest Achilles Heels for the vRS is the fact that its a SKODA!! Skoda has been getting undeserved attention and credit it never deserved. Neither did they make properly built cars nor did they help their customers take care of it. All they did was help themselves to the customers wallet.
That said, I would love to drive a vRS but to live with everyday I'd be happier with an Accord!!
@Tool : Hats off to you!! I would re-think my decision to buy a vRS after so many major issues discussed here. Shows your really smitten. Good luck with your find!!
flipsyde is offline   Reply With Quote
Old 15th February 2009, 02:19   #28
Tool's Avatar
I would be lying if i said that this post didnt scare me .
But yes i am totally smitten !! madly in love id say hehehe.
Umm sirs ajmat and normally_crazy.. cant thank you enough !!
The amount you guys know is absolutely RIDIC !!
Now sirs if i did pick up a Vrs then what would you suggest i do to it instantly after i pick it up so that i dont have to worry about some of the minor niggles?
I will definately change the water pump and coils and timing belt/pulley on any Vrs or Tpi that i get , but is there anything else that one should pay critical attention to when buying a used Vrs ?
Will also make it a point get fuse box checked as well as the fan control unit . Anything else that i should be careful about sirs ?
Thank you very much for all the help and for starting this thread.. totally invaluable !!
Boom
Old 15th February 2009, 11:00   #29
Thanked: 10,812 Times
If the car has done 45-50 K , yes, otherwise watch and wait.
Lift the battery cover off and you will see it.
Old 15th February 2009, 11:49   #30
Ravveendrra's Avatar
Thanked: 405 Times
Rgds,
It is true that Europeans treat Skoda like we know what, but that is only half the story.
The Europeans don't even look at the Asian imports (yes, they exist but are almost invisible - exceptions being Greece and other 'poorer' nations). Taxis are mostly Mercs (even in Greece). Their week-end drives are the likes of Ferrari and Porsche, their exec commutes are Jaguars, BMWs, etc. Even their small cars are mostly European. Skoda in Europe is treated slightly better than the Japanese and Korean vehicles. Most Asian cars there are the very small ones and Asians are almost totally absent in the mid size segment upwards. There are however a few Superbs to be seen (mostly fleet cars, I presume).
Cheers,
Ravveendrra is offline   Reply With Quote
Dil Mange More in OCTY vRS! evo In-Car Entertainment 29 23rd August 2011 19:00
225/50/16 Yoko`s for OCTY vRS? evo Tyre & Alloy wheel Section 23 24th June 2011 10:17
Poor Mileage in Octy Vrs diven_b Technical Stuff 10 10th June 2009 21:43
New Skoda Octy for India??? DRC The Indian Car Scene 9 13th September 2005 21:29
Help - Octy RS air bag, EPC, ABS, etc.... navin Technical Stuff 12 4th August 2005 18:26
