Old 25th March 2010, 17:08   #91
siddartha's Avatar
Thanked: 21 Times
If its a dual mass flywheel, then it is recommended that the flywheel be changed along with the new clutch assy, like in the diesel octy.
The dual mass flywheel has some springs/bushes which provide the damping action that get worn out.( also the wear is accelarated if the car is modded for more power /higher boost /bigger turbo)
The life of the clutch and these bushes/springs of the flywheel is more or less the same. These bushes/springs are not serviceable and so it is recommended that flywheel be changed.
Also the new clutch may damage the old flywheel and vice versa.
But the petrol engine has a normal flywheel, it is not really recommended unless the the surface of the flywheel has any scoring/grooving caused by the worn out cluth plate.
Also depending upon the extent of damage the normal flywheel can reconditioned before going in for a replacement. ( dont know if the authourised service centers do this )
my car has done 63k kms. not considering a clutch assy change upto 75-80k kms. lets see!
siddartha is offline   Reply With Quote
Old 25th March 2010, 17:11   #92
Shan2nu's Avatar
Thanked: 81 Times
Why does flywheel needs to get replaced along with clutch?
Infact, what wear and tear a flywheel suffers really?
Its not mandatory to replace the flywheel with the clutch, but since the clutch is a friction plate which presses against the flywheel to create frictional resistance, the flywheel could wear out as well.
The decision to replace the flywheel should be done only after a thorough inspection.
Shan2nu
Old 25th March 2010, 20:29   #93
Thanked: 23 Times
Default after read this all post i beleive dealer is a damager here
hi
i read of high maintance cost of skoda
in india i feel the dealer here are making 500% margin
for example somebody i heard for oil change and oil filter change they charge 6000 rupees
now now i spend in china i have skoda octavia same as laura in china 1.8 tsi engine
for oil change only 700 rmb which come 700x6.7 = 4600 ruppes
mind this i use wruth oil 5w40 which made in germany and imported from germany to china
which cost me 600 rmb if use normal oil like shell ultra cost are only 500 rmb or castrol active 5w40 cost same 500 rmb
i put oil filter made in german so cost 100 rmb
if use made in china good quality cost is 60 rmb
so u can see how much skoda service centre is charging also
i fail understand why people donot use outside service centre to service the car
a cheap obd2 device can buy bought as cheap as 5000 ruppees
i have used my skoda for 40k killometer
never speand more than 4k ruppes in servicing
so i am shock to read how much rip off the service centres are doing
narry
narry is offline   (1) Thanks Reply With Quote
Old 25th March 2010, 20:48   #94
Thanked: 8,956 Times
A dual mass flywheel alhough it handles torque better, is more fragile.
In the case of the diesel, the torque hits at low RPM hence the torque stresses are higher during a gear change. This means the DMF flywheel needs a change. In the case of a petrol, the torque is at higher RPM's hence less stress so replacement not always necessary.
My supervisor told me that the flywheel was fine although he initially told me to replace it when ordering the parts.
Old 25th March 2010, 21:48   #95
ImmortalZ's Avatar
Thanked: 137 Times
Skoda (and all VAG) cars use dual mass flywheels. They are complex and suffer internal wear and tear. They are expensive and need replacement with the clutch.
Old 25th March 2010, 21:59   #96
Mpower's Avatar
Thanked: 1,674 Times
Hmm....and what happens if you dont?
Old 25th March 2010, 22:11   #97
ImmortalZ's Avatar
Thanked: 137 Times
Err, I can only imagine big things go boom and you'll hear lots of expensive sounding crunches before the car grinds to a halt. Then you see the bill and die of cardiac arrest. :P
Old 26th March 2010, 01:04   #98
Mpower's Avatar
LOL, you have a pretty vivid imagination, but car parts are not designed to fail catastrophically without gving symptoms.
You can expect plenty of gear rattle, idle shake and starter engagement issues before it gives up.
Old 26th March 2010, 09:32   #99
Symptoms will be a lot of judder, esecially when reversing on an incline, loss of power and a kind of chugging noise
Old 25th June 2012, 08:48   #100
Default Engine running rich
Why ? - Temeprature sendor fails. It is well documented that the factory fitted one fail or become defective
How do I know ? - Strong petrol fumes from exhaust. Gruff engine note on start up. Temperature needle takes time to reach normal temprature. Check engine light eventually comes on. Exhaust might be boomy on a cold start.
What is the damage : Excess fuel consumption, check engine light might force limp home mode. You can offset this by disconnecting battery.
What is THE damage? - Go to the stealer - It will cost Rs 8000 and 5 hours of your time
Do it yourself, it wil cost Rs 4000 + 20 min of your time + cost of flat nosed plier and a screwdriver. Procedure is here
When can this happen? - any time from 25000 km onwards
What else can it be ? MAF sensor sending wrong signals
Note - I have sold my car - this will be the last post from me unless I get third hand information worth sharing
ajmat is offline   (3) Thanks Reply With Quote
Old 8th January 2013, 23:59   #101
prithwi-81's Avatar
Thanked: 983 Times
Default Re: Octy vRS Achilles Heels
You dont have to change the flywheel but its definately advisable to Resurface it when you put a new clutch on. I had an STI with 350-400 whp with stock flywheel+aftermarket clutch. Worked brilliantly. I would advise against changing the flywheel for anything other than stock, unless ur building a racing engine.
prithwi-81 is offline   Reply With Quote
Old 9th January 2013, 09:09   #102
aditbelw's Avatar
Thanked: 40 Times
*News*
On a recent visit to the Vinayaka Service center for a general checkup before I took my car on a 2000 Km trip down south, I was pleasantly surprised when I was told that all my Ignition coils were changed free of cost under warranty. Though I could not understand the " under warranty" stuff, but it was clearly mentioned on the bill. Has anyone had a chance to get anything free from Skoda, after warranty expiration?
aditbelw is offline   Reply With Quote
Old 9th January 2013, 09:21   #103
If the clutch is worn below 40000, you do not need to change flywheel, unless you have been dumping the clutch big time. If the clutch needs to be replaced around the 50-60 km mark, I would recommend changing the flywheel at the same time
Old 9th January 2013, 11:25   #104
rxpaul's Avatar
Thanked: 85 Times
My 2009 TPI has done just about 40000 km. The car runs well and i have changed only the clutch slave cylinder so far (Rs 3700 + 1500 fitting charges).
Do i need to change the water pump impeller, Timing belt and ignition coils now ? Is it better to import these, rather than buy locally ?
rxpaul is offline   Reply With Quote
Old 23rd April 2013, 11:09   #105
Thanked: 62 Times
Default Re: Engine running rich
thanks a lot ajmat sir for the quick scanning and evaluating the car for me, now i feel complete and happy about my purchase. Really appreciate the time you have taken off for me from your busy schedule.
TwinHead is offline   Reply With Quote
Dil Mange More in OCTY vRS! evo In-Car Entertainment 29 23rd August 2011 19:00
225/50/16 Yoko`s for OCTY vRS? evo Tyre & Alloy wheel Section 23 24th June 2011 10:17
Poor Mileage in Octy Vrs diven_b Technical Stuff 10 10th June 2009 21:43
New Skoda Octy for India??? DRC The Indian Car Scene 9 13th September 2005 21:29
Help - Octy RS air bag, EPC, ABS, etc.... navin Technical Stuff 12 4th August 2005 18:26
