Old 16th February 2009, 00:49   #1
Akshay1234's Avatar
Thanked: 7,243 Times
Default cant identify sound in my innova
there is a tak-tak sound from the left side of the car. it sounds a bit like plastic hitting something. it increases as the speed of the car increases. the sound is barely audible with the windows up. i checked the wheels and found no stones. i also had a good look at them and nothing looks out of place. any idea what this could be? it seems to have started only yesterday after my driver had to emergency brake to avoid some fool who suddenly took a u-turn. could it possible be a stone stuck somewhere?
edit - also forgot to mention there is no perceptible difference in the driving behavior of the car. it is just the same.
Old 16th February 2009, 08:52   #2
cooldude1988765's Avatar
Thanked: 108 Times
We had a similar tak tak sound in our innova (right side); turns out the mud flap (??) was loose and was hitting the inner part of the wheel arch. Check out the inner part of the wheel arches and see if anything is loose.
cooldude1988765 is offline   Reply With Quote
Old 16th February 2009, 10:11   #3
Thanked: 58 Times
Only possibility is with tools got loose. Look at the tools bag is it missing something?
sam003 is offline   Reply With Quote
Old 16th February 2009, 12:27   #4
Akshay1234's Avatar
nono its none of those. its definintely not a tool sound. and the mudflaps are fine.
any other ideas guys? i remember reading a thread where a stone stuck in the rotor was causing a sound like this.
Old 16th February 2009, 14:02   #5
Thanked: 65 Times
Weird. I have the same kind of sound coming from the left-rear of my Civic. Not the tools, not loose mud-flaps, and almost inaudible. Driving me mad. Can't hear it on very smooth roads. What could this be?
lawdgawd is offline   Reply With Quote
Old 16th February 2009, 17:20   #6
Thanked: 65 Times
Ah, I think I got it.
One of the rear windows were not fully closed, a few millimeters remaining. That solved my problem.
Old 16th February 2009, 18:54   #7
V-16's Avatar
Thanked: 862 Times
check mudflaps and the V belt
V-16 is offline   Reply With Quote
Old 16th February 2009, 22:19   #8
Akshay1234's Avatar
hahaha.
i think ive solved it. again checked the tyres and made the driver go slowly in front with the car. found a stone in the tread. it probably wasnt visible the first time i checked the tyres. *runs away out of embarassment*
Old 17th February 2009, 12:52   #9
Thanked: 245 Times
hahaha.
I was just about to suggest this.
Old 17th February 2009, 13:05   #10
BenjiRoss's Avatar
Thanked: 163 Times
So a 'stoned' Innova was the culprit.
Anyway - as long as the driver is not 'stoned' things should be smooth from now on!
BenjiRoss is offline   Reply With Quote
Old 22nd May 2009, 19:20   #11
Thanked: 7 Times
speaking of sounds in Innova: I have been having a different kind of problem with my Innova purchased in 2007 Aug, as the speed increases at about 1800 RPMs there is a slight ringing sound like the one you hear when a knife is getting sharpened at the grinding wheel, lot less audible ofcourse, from the under chassis or engine bay, it disappears if speed (RPM) decreases or increases, happens in all the gears, since this is the perfect cruising RPM it can get annoying, will be audible only if the windows are down & no music running, complained at Ravindu toyota & even demonstrated to the technician, but they said it was mud flaps & had fixed it, well itís still there, I case anyone has had similar problem please share it with me.
drkumarmp is offline   Reply With Quote
Old 22nd May 2009, 22:12   #12
mmmjgm's Avatar
Thanked: 21 Times
the knocking sound can also come if the bonnet hold-up lever (which holds up the bonnet/hood when open) is loose and not fastened.
cheers
M
mmmjgm is offline   Reply With Quote
Old 22nd May 2009, 23:52   #13
Akshay1234's Avatar
it resonates at that point. its normal. btw i suggest cruising at 2000-2200 rpm. you will get better mileage since the turbo is running at full boost.
Old 23rd May 2009, 00:00   #14
genesis's Avatar
Thanked: 309 Times
The other tak tak noise in an innova is the passenger side seatbelt corner hitting the pillars when there is no passenger. Drove me nuts until I figured out what was happening
genesis is offline   Reply With Quote
Old 23rd May 2009, 00:09   #15
Akshay1234's Avatar
lol now im getting a rattle from the roof. something to do with the dual ac. if i keep my hand pressed towards the roof it stops. this is from the rear. will have to get it checked out.
Audi's Sound Concept cabin defines auditory excess: 62 speaker surround-sound ! dar3dev|l In-Car Entertainment 10 22nd June 2010 15:23
Cant identify this transfer case whicked wheels 4x4 Technical 4 6th June 2010 23:14
Why Cant We Get 250 Horses Under 7 Lakh Inr Vulken Auto The Indian Car Scene 70 28th April 2009 00:12
Sound from Engine Bay of Swift VDI (DDIS) - what would be the cause of this sound? DieselFan Technical Stuff 4 25th January 2008 18:31
Cant afford a Turbo? Buy JUST the sound GTO Modifications & Accessories 15 7th January 2006 17:03
