Old 18th February 2009, 11:15   #1
Default Drive shaft for Baleno
Am a slight Rookie to Car mechanics..
REcently I faced a problem where I had to replace my Drive shaft of the Baleno. the entire gear inside of the drive shaft was smoothened out and caused the assemble to slip.
Need to do an RCA..
What could have caused this gears to moothen out so much? HAd a Santro for 6 years and nothing like this had happened?
Would the problem be replicated on the Left Drive shaft too?
As per the Maruti Service the left Drive is OK.. But I guess this is very non committal as there is an opportunity for more buiness later.
Any valued Advice would be appreciated.
Sunil
sundabs is offline   Reply With Quote
Old 18th February 2009, 12:25   #2
Jaggu's Avatar
Thanked: 8,696 Times
Gear inside drive shaft? are you talking about the bearings and joints? OR the end which goes inside the gear box?
Old 19th February 2009, 07:23   #3
I think he means that the splines (or threads) at the driveshaft end are all stripped, so they probably couldn't attach it to the CV joint and the wheel hub assembly properly.
One of the reasons it might happen is due to the CV joint wearing out, but I'm not sure about your specific case.
sujaylahiri is offline   Reply With Quote
Old 23rd February 2009, 14:12   #4
Sujay, you are right, it is the Splines/threads which got worn out.
From the look of the shaft it was wear and tear. But my concern is what if the left drive shaft is also giving way, due to some misalignment/Wrong style of driving/any other reason.
Old 23rd February 2009, 15:39   #5
Jaggu's Avatar
Thats very strange, should be defective part or as you said badly fitted/aligned one.
Accent Crdi Drive Shaft Problem!! kphilip Technical Stuff 22 25th October 2010 23:26
Ritz - Drive Shaft recall bruns The Indian Car Scene 16 23rd May 2010 00:44
Drive shaft sound-how long will it last now? deetee Technical Stuff 8 7th February 2008 21:11
Indica Drive shaft problem dinar Technical Stuff 3 7th August 2007 00:34
Drive shaft noise - Need help girishab Technical Stuff 15 18th April 2005 19:29
