Old 2nd May 2005, 11:36   #1
Samurai's Avatar
Thanked: 15,767 Times
Default Short throw in low beam
After getting my new Baleno I had replaced the front headlamps into 90/100 watt. Didn't have any problems with the light throw at low beam, it was atleast 120ft. After a long drive to my native town, I noticed that the light throw had reduced considerably. Now it illimunates only 30-40 ft or so, it is absolutely dark after that. I always drive in low beam, now this problem forced me to travel in high beam yeaterday, that too on NH-17 and I was getting all kind of headlight signals from the oncoming vehicles.
What could cause this problem, I checked the lights once I reached home. The lights are working in both low-beam and high-beam mode. How could the low beam suddenly decide to lower it's range?
Old 2nd May 2005, 11:53   #2
z klasse's Avatar
The reflectors probably dull out when new. Original Bulbs are 55w if im not mistaken and if you put a higher rating when the reflectors are new then they do get affected. Typically after a considerable period of use, say around 100 hrs plus of 55 w bulbs they recommend to change if at all required. That also affects reflectors but not that much when they are new. So if you want then use the regular bulbs for a while and after a few months change to the 90w bulbs.
Z
z klasse is offline   Reply With Quote
Old 2nd May 2005, 11:53   #3
Revvhead's Avatar
Umm Samurai, i dont mean to sound condescending,
But you have not mentioned as to if you have used the headlight beam adjuster control
for your info on the baleno there is a setting by which you can change the level of throw,
Its on a small roller wheel, placed next to the (on the right) switch for the sidewiev mirror adjustment, its numbered till 4, and you can have a large adjustment range.
Check that, i think zero is the longest throw. Should fix yr prob immediately
(that is in case you have missed on that switch)
Revvhead is offline   Reply With Quote
Old 2nd May 2005, 12:13   #4
Samurai's Avatar
Holy cow! You nailed it. Thanks dude. BTW, why is that condescending
I saw my son messing around some dial on the dash board. I thought it changes the dash light intensity. I still haven't spent any time reading the manual.
After driving too many cars one tends to stop reading car manuals or trying to understand each control. And this is my eighth car and I have probably driven more than 50 different cars. Still I think I should spend some time reading the manuals for the cars I do own.
Old 2nd May 2005, 12:21   #5
Revvhead's Avatar
Hey no prob Samurai,
glad to be of help.
The beam adjuster nis just a lovely toy & damn helpful
Old 2nd May 2005, 15:19   #6
iceman91's Avatar
Thanked: 22 Times
sorry samurai i think i am to blame for it too...did not set it that day when you came to collect the car. should heve explained it to you!!!
iceman91 is offline   Reply With Quote
Old 2nd May 2005, 15:26   #7
Samurai's Avatar
No iceman, I don't think so. I had driven at night in Bangalore after that, didn't have that problem. Example, driving back from the TGIF party. This mess up happened after that. Therefore I absolve you completely .
Old 2nd May 2005, 15:29   #8
iceman91's Avatar
Thanked: 22 Times
thanks!!! thats a nice function pity the older balenos dint come with it.
Old 2nd May 2005, 16:20   #9
Jaggu's Avatar
Thanked: 8,685 Times
brings a question to mind, hwo many of us religiously read the owners manual... i love reading it inside out...
best ever read merc e class :P wonder how big the S class will be
Old 3rd May 2005, 10:58   #10
iceman91's Avatar
Thanked: 22 Times
haha jaggu imagine reading psycho's conti manual!!!
p.s. sorry psycho could not stop that
Old 3rd May 2005, 11:13   #11
Stratos's Avatar
Thanked: 1,217 Times
TopGear said the manual for the S Class is nearly 1000 Pages
Btw.. I have read my Indicas` and Indigos` manual inside out!
Stratos is offline   Reply With Quote
Old 6th October 2008, 16:33   #12
johnda's Avatar
Thanked: 11 Times
Default OHC low beam
My OHC has a very short throw on the low beam and the High beam will Blind and maybe even kill all on coming traffic.
Want to know if there is a way to sort this out.
johnda is offline   Reply With Quote
Old 6th October 2008, 22:31   #13
SLK
SLK's Avatar
Thanked: 192 Times
Assuming you don't have that 1-2-3 level adjuster thing in your OHC.... there is normally a manual adjustment option available in the headlights. Its like a screw either on the headlight or besides it.
Just look for it... or try searching in the manual.
Then all you need to do is.. tighten or loosen it with a screw driver and you can change the level of the low beam.
Park the car in front of a wall so that you can see the level.
If your car has had any kind of frontal accident/impact... this adjustment might not be able to raise the level enough for you.
SLK is offline   Reply With Quote
Old 6th October 2008, 23:02   #14
johnda's Avatar
Thanked: 11 Times
Thank you SLK, i'm gonna try this, i hope i do it right?
Old 6th October 2008, 23:47   #15
iraghava's Avatar
Thanked: 156 Times
It has to be manually adjusted, no model of the OHC ever had the in-cabin adjusters.
Adjust Projector focus for Low-Beam on Fortuner? UPDATE: Projectors in Fog Lamps! sushrutha Modifications & Accessories 18 5th October 2016 15:57
Low Beam not working ghpk Technical Stuff 19 29th November 2014 16:00
Projector Lamps(Low Beam) as Fog Lamps for Ritz LDI alexpaul Modifications & Accessories 17 13th September 2012 20:23
Pulsar 220 F 2010 - Low beam leveling issue kingofmyworld Motorbikes 13 31st August 2010 00:16
How To : Tell the oncoming vehicle to use low beam headlight!! racingmachine Street Experiences 62 9th December 2009 22:56
