Old 20th February 2009, 12:33   #31
condor's Avatar
Thanked: 4,908 Times
rippergeo : It is such a lot of fun shutting the door on an over revving petrol :-)
Tell me about it !
watashi75 : Contrary to popular belief, lugging may not always give best fuel efficiency.
@Watashi, thanks for that. While the example is a little simplified, I hope people are getting the idea.
lower throttle + more power (lower gear) + better combustion >> higher throttle + less power (rem it is in a higher gear) + un-burnt fuel
Old 20th February 2009, 13:39   #32
Thanked: 253 Times
Originally Posted by watashi75 View Post
Contrary to popular belief, lugging may not always give best fuel efficiency. Let us assume for simplicity that fuel consumed is approximately RPM times throttle width.
First example, for a car lugging uphill in 3rd gear at 1500 RPM at full throttle,
Amount of fuel consumed = 1500 * 1 = 1500 units
If it is possible to do the same in 2nd gear at 2250 RPM (Swift gear ratio) at half throttle,
Amount of fuel consumed = 2250 * 0.5 = 1125 units
Second example, if a car is moving in 5th gear at 3000 RPM at full throttle
Amount of fuel consumed = 3000 * 1 = 3000 units
If it is possible to maintain this speed in 4th gear at 3850 RPM with even 3/4 throttle,
Amount of fuel consumed = 3850 * 0.75 = 2887.5 units
In fact lugging will never give the best fuel efficiency, but it might give the best fuel economy!
I could not understand the examples you have posted. Further they seem to over simplify the whole case.
I cannot imagine being in 5th gear at 3000 rpm on hill roads!
I think what you mean is that there is a difference in fuel efficient operation of an engine and the fuel economy. I can run an engine at an inefficient point of operation but I might be saving fuel for a specific journey. The price I would be paying is in terms of the longer time I would take to complete the journey; and the fact that the engine would not be feeling very happy!
If we are looking for the best/complete utilization of fuel used, the engine should be run in the zone of bhp where it's specific fuel consumption is the lowest.
Old 20th February 2009, 13:50   #33
esteem_lover's Avatar
Thanked: 451 Times
I cannot lug my car, only a car with good low end torque (mostly diesels) can be lugged.
Whenever I try to lug my car, I am greeted with a band of classical musicians from my dashboard, totally out of sync that I would have to down shift immediately.
Old 20th February 2009, 13:55   #34
Thanked: 253 Times
LOL, you are lucky enough to know what 'the band' is trying to tell you!
There are those who do not understand till the car stalls!!
That's when 'the band' from behind you starts! Honk honk honk...!!
Old 20th February 2009, 14:46   #35
Thanked: 103,714 Times
Most common form of lugging : Being in too high a gear at too low a speed. Even other types of lugging / labouring (going up a steep hill in 5th, towing a heavy load in 6th etc. etc.) revolve around using a high gear, at a time when a lower ratio would be better suited & drop the rpm back in optimum range.
Nope, I love my cars too much to let the engine labour. Have seen too many people lug their engines in the interests of fuel economy. Truth is : the engine probably isn't at its most efficient when lugging.
P.S. : The only work I make my engine do is at the other end of the revv-band
Old 20th February 2009, 15:11   #36
Thanked: 451 Times
As long as the band from the back does not play 'Thud Bang Thud Screech Thud', its fine.
Old 20th February 2009, 15:12   #37
condor's Avatar
esteem_lover : I cannot lug my car, only a car with good low end torque (mostly diesels) can be lugged.
It only appear so - lugging will be seen differently in petrols, cant do a direct comparison.
anupmathur : That's when 'the band' from behind you starts! Honk honk honk...!!
Band Bhaja diya !
Old 20th February 2009, 15:35   #38
quicksilver's Avatar
You also have the issue of knocking in Petrol engines, making it hard to not notice. Unfortunately, it is the petrol cars that get lugged/laboured most, given the differential fuel price.
quicksilver is offline   Reply With Quote
Old 20th February 2009, 15:44   #39
watashi75's Avatar
The second example is on plain roads not on hill. It is just an example to highlight loads at high speeds, which in this case is the aerodynamic load. The first example is to highlight loads at low speeds.
Of course, there is no point in talking about lugging unless there is a load in the first place! Lugging is about being in a higher gear at a lower RPM when the power delivered by the engine is not optimal.
My understanding is that fuel efficiency leads to fuel economy.
The example is simplified but it is not far from truth either. This is the torque graph for Swift taken from one of the threads here.
The power delivered by the engine at 1500 RPM is almost half the power delivered at 2500 RPM and the power delivered at 3000 RPM is nearly 3/4 of the power delivered at 4000 RPM. So the net result is that fuel consumed might actually be less if the engine is at a higher power band during load conditions.
Without load conditions of course lugging is more fuel efficient.
watashi75 is online now   Reply With Quote
Old 20th February 2009, 15:59   #40
Shan2nu's Avatar
Thanked: 89 Times
This will be true only if you're calculating FE wrt to time and not distance covered.
Like i have mentioned in my eg in a previous post.
A car doing 80kmph@2200rpm in 5th might be consuming only 3.6ltr an hr compared to the 4.3ltr/hr for 100kmph@2700rpm but when you consider the distance covered by the vehicle at those specific rpms, you realise that even though the engine is consuming less fuel at 2200rpm in an hr, it is also covering a smaller distance in that time frame.
So when you look at FE from a "kmpl" perspective, you can't rely only on engine rpm and forget about vehicle speed.
Shan2nu
Old 20th February 2009, 16:26   #41
watashi75's Avatar
I should have added that this is only for a particular speed. 1500 RPM in 3rd gear and 2250 RPM in 2nd gear both translate to the same speed for Swift.
Old 20th February 2009, 16:45   #42
Shan2nu's Avatar
Thanked: 89 Times
Yup, since the distance covered in an hour remains the same in both gears, the only deciding factor here would be the fuel consumed by the engine in an hour (ltr/hr), which would be lesser at 1500rpm in 3rd.
Shan2nu
Old 20th February 2009, 16:55   #43
watashi75's Avatar
On the contrary, I am saying 1500 RPM is 3rd will consume more fuel. I hope you agree that fuel consumed is *not* same when you are at 1500 RPM and hardly pressing accelerator as compared to the scenario when you are at 1500 RPM and fully pressing the accelerator (full throttle). I would call the first situation as "cruising" and the second as "lugging".
Old 20th February 2009, 17:59   #44
Shan2nu's Avatar
Thanked: 89 Times
I was refering to your statement below :
"Without load conditions of course lugging is more fuel efficient."
Without load, 1500 in 3rd would be more FE.
Shan2nu
Old 20th February 2009, 18:21   #45
Spitfire's Avatar
Thanked: 707 Times
Lugging what lugging? I drive a diesel
Spitfire is offline   Reply With Quote
Caution! Rusted wheel lug nuts ece2k2 Tyre & Alloy wheel Section 48 24th June 2015 18:41
Forged Aluminium Lug Nuts - are they safe? Chewbacca Tyre & Alloy wheel Section 13 5th February 2013 13:53
Lug nuts - How many do you really need? McLaren Rulez Technical Stuff 21 24th September 2012 15:34
Adapter for Weird Lug Nuts Tassem Tyre & Alloy wheel Section 14 18th January 2012 10:18
Alternate Tread Lug Wear Android Tyre & Alloy wheel Section 3 26th September 2008 21:46
