Old 4th May 2005, 22:50   #31
Mpower's Avatar
Thanked: 1,687 Times
Originally Posted by iceman91
well an esteem box will not go on a baleno...need to do a close ratio box..using closer gears
I thought Baleno and Esteem have the same box except for the ratios. Saw it in ACI/OD? where there was a feature on MRF rally Balenos vs Citys. The rally Balenos were apparently failing transmissions for this reason. Can somone dig up the issue?
Old 8th May 2005, 12:16   #32
Rehaan's Avatar
Thanked: 25,037 Times
Originally Posted by kooldude
its silly to ask u but what is a carb engine and my car is not a mpfi engine.
To answer your question -
Do MPFI engines have Carbs ? (DO MPFI cars have CARB's)
Quite a cute name for a thread
cya
R
Old 11th May 2005, 08:49   #33
kooldude's Avatar
thanks rehaan now i got to know everything abt the carb and mpfi engine. thanks to all you guys i learn all the new terms otherwise i was a total dumbo in cars before but after joining this site i am learning more and more about cars
kooldude is offline   Reply With Quote
Innova Purchase Query + Query on Price Increase by Toyota SanMan SUVs, MUVs & 4x4s 7 30th April 2008 13:13
The Best Batsman in the World - ur pick normally_crazy Shifting gears 23 1st July 2006 13:38
Monster Pick Up amit The International Automotive Scene 2 18th September 2004 19:20
if you were to buy, which one would you pick _Crazi4Speed_ The International Automotive Scene 4 3rd March 2004 06:41
