Old 30th November 2009, 09:11   #331
faridsahmed's Avatar
Thanked: 9 Times
Same here - my Vista QJD has done 4800 kms in 5 months and the FE is around 18. The driving is city + highway with 100% AC. The problem, I feel, is because of the traffic conditions bumper to bumper. Otherwise its a pleasure to drive on expressways - You can feel the power.
The only irritant I have is - squeaking noise from Right Rear Spring when anyone gets in or get out of the rear seat.
faridsahmed is offline   Reply With Quote
Old 30th November 2009, 18:06   #332
amit_purohit20's Avatar
Thanked: 486 Times
Default My Indica Vista TDI 1st Problem :(
Yesterday I had gone to B.U.Bhandari Pune to get solved my 1st problem with Indica Vista TDI.
Driver side front power window not operating.When I used to press the Power Window switch there used to come a click sound from the glove box side. Later I found out that the controller for the switches is located there. I thought the fault was a small one with the switches but later realised that the controller was getting the current from the switch. The reply from the mechanic was"Humne motor direct karke bhi dekhi chalni to chahiye" so they replaced it with a new Power window motor and voila its working fine now. On requesting 2-3 times they agreed to give the car a wash and that too only top wash in which they just put some water on the car body thats it.No underbody wash nothing.I was not sure whether I am entitled for a underbody wash too in such a case so just kept mum.
They didnt charge me so I kept quiet. The work was done fast but the courtesy was not there and there was a chaos going out there.When enquired about the ECU upgrade for the less efficiency of the AC they told they were not aware then one of the service engineer told he was aware but they didnot had the software update and also said it would reduce the fuel efficiency as the cut off temp of thermostat is lowered. Also Vista power window switches as spares are still in shortage.
Just wanted to share this with you all might be of help to some Vista TDI owners
amit_purohit20 is offline   Reply With Quote
Old 1st December 2009, 11:26   #333
Thanked: 9 Times
hi amit_purohit20
thanks for the update.
I bought my Vista from pratham motors, near balewadi stadium, Pune and my car is due for 2nd service. The thing is I got my first service done from pratham itself but now it seems that they have closed the dealership. Can any TATA Vista owners point me a good Service center in Pune ?
Old 1st December 2009, 12:17   #334
Thanked: 242 Times
Originally Posted by faridsahmed View Post
hi amit_purohit20
I have a very good experience with B.U.Bhandari Wakad. I have done all my servicings and accident work over there.
sushantr5 is offline   Reply With Quote
Old 1st December 2009, 12:20   #335
Thanked: 9 Times
Do I have to go to the center which is on the B'lore-Mumbai Highway opp to Hotel Sayaji ?
Old 1st December 2009, 16:02   #336
Thanked: 242 Times
Yes you are right. It is opposite to Sayaji.
Old 1st December 2009, 17:29   #337
DieselAddikt's Avatar
Thanked: 374 Times
I have a query. My Vista QJD is due for second service. I remember the Service Advisor telling me that second service would cost about 4K. That is a 2K for engine oil replacement and another 2K for a new filter. I feel that 2K is on the higher side for a filter. Am i missing anything here ? Or is the price correct ? Any experiences and advices would be of great help.
DieselAddikt is offline   Reply With Quote
Old 1st December 2009, 18:44   #338
trrk's Avatar
Thanked: 13 Times
The expensive filter that you mention would be the fuel filter. In the Quadrajet (as well as in all other common rail diesel engines) it needs a more expenisve filter to take off water / moisture in the diesel and hence the higher cost.
By 2nd service, I am not sure about the kilometres involved, so please check your service booklet as to what all have to be replaced in that service.
trrk is offline   Reply With Quote
Old 1st December 2009, 20:45   #339
rkg
Thanked: 543 Times
Second service is @ 5000 km. No need for engine oil replacement. Oil to be replaced @10K as per manual.
My second service costed me Rs70/- for topping up various liquids. that is what concorde banglore told me.
III service 1300/ ( engine oil @900/ odd + fuel filter @350/- )
http://www.team-bhp.com/forum/long-t...w-26925km.html (tata indica vista long term ownership review at 26925km)
http://www.team-bhp.com/forum/long-t...km-report.html (Indica Vista Qjet Aura- 10000 Km report)
the service adviser is wrong.
rkg is offline   Reply With Quote
Old 2nd December 2009, 11:33   #340
trrk's Avatar
Thanked: 13 Times
Hi rkg,
The above filter would be the oil filter and not the fuel filter. Please check.
Old 2nd December 2009, 12:48   #341
rkg
Thanked: 543 Times
Originally Posted by trrk View Post
Hi rkg,
It is Oil filter only.
Old 2nd December 2009, 16:11   #342
By the way, friends, what is HVAC? What does H & V stand for?
I regret for the stupidous query.
adilip is offline   Reply With Quote
Old 2nd December 2009, 16:28   #343
Thanked: 9 Times
HVAC - Heating Ventilating & Air Conditioning
Old 3rd December 2009, 10:58   #344
Thanked: 374 Times
Thanks rkg. The SA was wrong.
I dont understand what was there in his mind when he said that. And BTW, that SA is not working there anymore. But since he said there is an oil change at 5K, I did not change it during first service like fellow BHPians advice. So i would like to do it this time. Which is the best brand to go for ? And what would be the actuial cost ? What will be the quandity required ?
Note: I dont know whether this is the right place to ask this question.
Old 3rd December 2009, 11:05   #345
Thanked: 374 Times
@trrk.
Thanks for the quick response. It would be the fuel filter that he was mentioning. The problem is that I am not able to find the Service Manual anywhere. I kept it somewhere at home and forgot about it. So have to go forward based on BHPians inputs till I find the manual. Thankfully, the service coupons were kept in another pouch which i still have.
Fiat Palio MJD - Known Problems Ice Technical Stuff 304 23rd October 2016 13:31
Help Required Indica Vista Safire or Indica Vista TDI Logical Hatchbacks 63 30th October 2011 08:57
