Old 15th July 2011, 16:15   #811
dhanushs's Avatar
Thanked: 4,504 Times
Default Re: Indica Vista - list of Known problems
Originally Posted by Maverick1977 View Post
Here are the pics of the rusted areas, they might not be that much right now but rusting is a disease which spreads on the entire surface.
Now that is some serious rust Maverick. Very bad steel quality/paint job from TATA.
Get it sorted ASAP. Also, check for rust, on suspension mountings, running board and on the joints in the mudguard. Get it sorted out, if any.
Old 4th August 2011, 01:14   #812
smrtdvl's Avatar
Thanked: 68 Times
Guys Is there a possibility to get the central locking to lock itself after a certain amount of time once the key is taken off in a Vista? This was possible in my Esteem which had a after market xenon remote.
I have left the car open couple of times last week. Thank god both times it was inside locked car park
smrtdvl is offline   Reply With Quote
Old 4th August 2011, 07:13   #813
Thanked: 338 Times
I don't think it locks automatically. If there is any setup for that even i would love to have that.
On the other hand if you unlock the doors and do not open them within a stipulated time it does get locked again.
amitwlele is offline   Reply With Quote
Old 5th August 2011, 11:30   #814
Arun.K's Avatar
Thanked: 47 Times
My Vistaí Qjet strains in second gear when it crosses 2000rpm. It had clocked ~20100 KMs. The pick-up drops and finds hard to pull after 2000 RPM. Moreover, I could feel the engine becoming rough and noise getting increased. This happens only in second gear. As a result overtaking in slow moving city traffic becomes a pain. There is no problem in 3rd, 4th, 5th gear and pick-up is very good even after crossing 2000 RPM. We do have another Vista QJet, which doesnít have this issue in 2nd gear. It zooms after 2000 RPM and reaches 3000+ RPM with ease in second gear. But TASC people say they donít find any problem with my car and do not find any error codes. They say I feel it because of the increased engine noise audible inside the cabin. But Iím not convinced with their answer. BTW, nowadays the engine noise is more audible than before inside the cabin while idling and moderate speed, but goes silent and smooth after 80 KM/H. Again, itís more silent inside the cabin of our other Vista which has done ~71500 KMs irrespective of the RPM.
What could be the reason? Does anyone have this problem in Vista QJet?
Arun.K is offline   Reply With Quote
Old 15th August 2011, 17:48   #815
I moved to Bangalore now.
My car suddenly got a problem with engine start. It was fine until yesterday evening. In the next morning, When I tried to start the car, the engine started but slowly the engine slow down and stopped. This happened all the time --- engine started and after few second the engine is stopped.
I tried to reset the fuel cutover switch located under the driver seat but no luck.
I have no clue what happened over night?
My car has completed 2+ years and 32000+ KM.
Could you people please suggest a good TATA service center in Bangalore where I can get the ECU reprogrammed for AC improvement + Front suspension squeeking sound.
How good is Prerna Motors @ CV Raman nagar? Its very near to my place.
vijay_01 is offline   Reply With Quote
Old 16th August 2011, 02:28   #816
dhanushs's Avatar
Is it a petrol or a diesel?. In any case, I guess its a fuel supply issue. Assuming there is enough fuel in tank, I would suspect the Fuel Pump and a clogged Fuel Filter.
Old 16th August 2011, 08:06   #817
Thanked: 481 Times
My 11 month Vista (D) has a new problem. The co-drivers window rolls down from the drivers side, but doesn't roll up. The next servicing is 7 months way. I guess I'll have to live with it for a while!
@Chaand is offline   Reply With Quote
Old 16th August 2011, 18:39   #818
Question Re: Indica Vista - list of Known problems
I am sorry for not providing enough info.
My car is vista quadrajet (Diesel). and ofcourse there is enogh fuel in the tank and for this reason i tried to reset the fuel cutoff switch multiple times.
Folks, could you please provide any input for good service center around CV raman nagar.
And as my car is more than two years old (but i have extended warranty) if i call the service center people to repair the car at my place, what would they charge?
Old 22nd August 2011, 11:09   #819
gurudutt's Avatar
Thanked: 128 Times
You can reach out to the Prerana motors service center on old madras road (next to big bazar), thats the place i got to and they do put in efforts to sort out your problems. Please meet Mr. Ravindra over there, he is the works manager and a good person who will listen to you .
gurudutt is offline   (1) Thanks Reply With Quote
Old 22nd August 2011, 13:07   #820
Thanked: 237 Times
This happens due rusting in power window button circuitry.
If you press up button do you hear click sound of relay or not. If not then it is for sure is problem with button. Here is DIY guide how to fix this problem.
http://www.team-bhp.com/forum/long-t...ml#post2166541 (Indica Vista Quadrajet : An Ownership Log)
I had this problem two times and it can be done in 10 minutes.
sushantr5 is offline   Reply With Quote
Old 30th August 2011, 15:43   #821
Sam.k's Avatar
Thanked: 37 Times
My third freeservice bill is Rs.1800/-.I am being tol that only labour is free.I have been charged on engine oil(mineral),oil filter and some misc...Is this normal.
The SA was on my back to switch to full synthetic engine oil.I didnt wanna spend(truth is that i couldnt afford at this time of the month) that much.Is there a noticeable difference in the performance and NVH levels?In other words is it worth the money?
Sam.K
Sam.k is offline   Reply With Quote
Old 30th August 2011, 15:47   #822
Thanked: 481 Times
Third Free service corresponds to 10k service.
Oil filter change is not required.
Engine oil should not take more than 1300 bucks.
Whats the misc that you are referring to?
Old 30th August 2011, 16:18   #823
dhanushs's Avatar
Yes, if you can afford it every 10k kms, then synthetics are worth the money.
Please change the Oil Filter whenever you change oil.
Old 12th September 2011, 13:46   #824
rahul4640's Avatar
Thanked: 308 Times
I agree fully. It is always recommended to change your engine oil filter, with each change of engine oil.
rahul4640 is offline   Reply With Quote
Old 12th September 2011, 14:55   #825
k_nitin_r's Avatar
Thanked: 74 Times
My third free service bill is Rs.1800/-. I am being told that only labour is free. I have been charged on engine oil (mineral), oil filter, and some misc. Is this normal?
The SA was on my back to switch to full synthetic engine oil.I didnt wanna spend (truth is that i couldnt afford at this time of the month) that much. Is there a noticeable difference in the performance and NVH levels? In other words is it worth the money?
It is normal for the service station to charge you for the parts while providing free labor for the free service - it was the same when I went into the Varun Motors Maruti Authorized Service Station for the free service. The free service bills were always below INR.2,000/-. You do not really need synthetic engine oil as long as you stick to the recommended oil change intervals.
k_nitin_r is offline   Reply With Quote
Fiat Palio MJD - Known Problems Ice Technical Stuff 304 23rd October 2016 13:31
Help Required Indica Vista Safire or Indica Vista TDI Logical Hatchbacks 63 30th October 2011 08:57
