Old 31st October 2011, 12:50   #856
smrtdvl's Avatar
Thanked: 68 Times
Default Re: Indica Vista - list of Known problems
Originally Posted by Arun.K View Post
smrtdvl, what were the OE tyres?
BRIDGESTONE's - No upgrades done
For the next ques I need to look below the car after the rains cos its too muddy out there. But I can certainly say there is a noticeable difference in tyre noise inside the cabin.
smrtdvl is offline   Reply With Quote
Old 31st October 2011, 15:41   #857
Arun.K's Avatar
Thanked: 47 Times
That's the primary reason for less tyre noise inside the cabin. My Vista got Goodyears as OE.
Arun.K is offline   Reply With Quote
Old 1st November 2011, 11:17   #858
Arun.K's Avatar
Thanked: 47 Times
Sam.K, happy to see another CBE T-BHPian. The same Autozone people say it's marching noise but getting generated from gear box. Seems like it cannot be stopped once it comes up. As you said, even I feel "Marching Noise" had become a common term for them. I have taken up the issue to TATA Motors and waiting for their reply.
I received the following unconvincing reply with the same term from TASC in written, for the complaint registered through the web form of TATA Motor's customer care website.
"We have observed that the above noise (Marching Noise) is normal in all the vehicles which we have explained to you..."
It seems like the details posted in the web form just get forwarded to the respective service center for action. I'm going to escalate the complaint with TATA Motors.
Old 4th November 2011, 15:55   #859
Sam.k's Avatar
Thanked: 37 Times
I have been directed to get in touch with Tyre care @ Ramnagar who happens to be the primary Good year dealer in Coimbatore.
Now my steering wheel is wobbling due to this tyre issue.We checked this by chanding the front tyre to Bridgestone and the wobbling vanished.The excuse now given to me by Autozone is"This always happens with Goodyear tyres".Let me see what happens next.
Sam.k is offline   Reply With Quote
Old 4th November 2011, 16:14   #860
Thanked: 7 Times
Even mine have Goodyear tyres ae OE. At the second service I got the front wheels aligment checked and corrected (car was drifting to the left), and now I notice that the tyre noise also has reduced noticeably. That's a revelation for me! (I took delivery of my Vista Quadrajet Aura in April and have done something over 5K Kms till date).
car_da_mum is offline   Reply With Quote
Old 5th November 2011, 11:49   #861
Arun.K's Avatar
Thanked: 47 Times
Sam, I think it is City Tyre Care @ Ramnagar, because Tyre Care is in Avinashi Road (after Lakshmi Mills Jn. towards Peelamedu). I was about to suggest Tyre Care to you. They solved the wobbling issue completely and tyre noise significantly in my Vista with the same Goodyear. They did an alignment, swapped the rear tyres with front and did balancing for the front tyres alone. Earlier, Autozone people said that the problem could only be solved, if Goodyears are changed.
Old 5th November 2011, 13:07   #862
Sam.k's Avatar
Thanked: 37 Times
Arun-You got it fixed from city tyre care or tyre care?I went to city tyre care,ramnagar and they have done a decent job.However i was told that one of the front rims had taken a beating and is slightly bent in one place.That might be the reason for steering wobble.
I have had this issue right from the 1st service and it has not been solved.They should have noticed the rim bend,may be it was deffective right from day one..who knows?its is negligence from TASC.So i am going to write an email to tata customer care regarding the same.High time i did this.
Old 6th November 2011, 13:04   #863
Arun.K's Avatar
Thanked: 47 Times
Sam, I got it fixed from Tyre Care, Avinashi Rd. Hope City Tyre Care people solved the issues. If not, try to get an opinion from Tyre Care regarding the wobbling problem. I feel they will do a better job. If a running rim is bent, replace it with the spare tyre and check whether wobbling still persists.
Was there any wheel alignment/balancing/rotation done during 1st service or after @ Autozone? Because even in my Vista, the wobbling and tyre noise issue started after their alignment, balancing and rotation.
Out of my experience, nowadays I see a slight drop-off in TML Customer Care's action towards the customer's complaints. Sometimes, even the regular TML feedback call after a service is missing.
Old 11th November 2011, 11:56   #864
ajay_satpute's Avatar
Thanked: 1,380 Times
Indica Vista PETROL owners
I want to do a engine flush and add synthetic oil this time. Any idea, which is the recommended synthetic oil for Vista petrol?
ajay_satpute is offline   Reply With Quote
Old 11th November 2011, 18:23   #865
infotech58's Avatar
Thanked: 217 Times
not sure which one is the recommended synthetic oil for Vista but a friend of mine used Shell Helix Ultra 5w-40 in his Petrol Vista and has had no problems so far.
infotech58 is offline   Reply With Quote
Old 14th November 2011, 14:22   #866
Thanked: 481 Times
I tried to play a DVD-R on the Vista (2010 model) today. It simply refused to work.
Anyone tried this? Does it work?
@Chaand is offline   Reply With Quote
Old 14th November 2011, 18:11   #867
Guys,
I have been facing problem with my Indica vista (quadra )clutch for some time now.
a) Its very smooth and light when I start the car and becomes very sluggish and hard after 10-15 kms.I have given it to the TASC and they do something and its ok for a few days and again the problem starts
b) Recently I had a big shock when I noticed that when I from 3rd to 4th,clutch got stuck in the middle(ie neither engaged nor free) .I had to use my toe to go under the clutch and get it out .When clutch was half on,the gear was not working.This has happened atleast 10 times in the last 2 months.However TASC is not willing to fix it as they say that they are not able to reproduce the problem when they drive
What should I do to fix/change the clutch/gearbox.
My car is still in extended warranty
Hari.
hdi_pro is offline   Reply With Quote
Old 21st November 2011, 18:39   #868
rahul4640's Avatar
Thanked: 308 Times
Although I use a petrol car, it is an Indigo and not an Indica. And am really no expert here. But please allow me to add that there are lots of synthetic engine oils available in the market and almost all of them are good. But I have personally used Castrol edge (5W-40), which is cheaper than some other synthetic oils brands and am very much satisfied with it. In the month of June this year I purchased one 4 liter tin for Rs 3100/- in Calcutta.
If you are willing to get the best product available in the market, please go for Mobil1 (0W-40). One 4 liter can of it is now being quoted at Rs 4000/- in my locality.
Edit:- Forgot to add that with Mobil1 oils, Tata recommends an extended drain interval of 15000 KM.
rahul4640 is offline   Reply With Quote
Old 24th November 2011, 19:12   #869
faridsahmed's Avatar
Thanked: 9 Times
Problem cropped up - AC vent selector knob not working. (see attached image)
when I try to rotate the knob to redirect the air from HVAC unit - the knob simply makes noise and seems it is just slipping !!!!!
worried .. took to the TASC in Chennai (OMR checkpoint) - advisor says "SAAR your vent selector unit has gone ! Not covered in warranty. Need to replace and will cost approx 4000/-"
Has any one faced a similar problem ?
Details :
VISTA QJD AURA
July 2009
kms : 28400
warranty : 2+2 (extended)
faridsahmed is offline   Reply With Quote
Old 25th November 2011, 11:41   #870
Thanked: 237 Times
Details :
VISTA QJD AURA
July 2009
kms : 28400
It might be case of bad plastic quality inside. There is cable attached to this unit from behind. When you rotate the switch the cable is also pulled. Just check whether that cable holder is in place or not. And the price quoted by dealer is too high. I do not see any reason to be priced over Rs.800 to 1000. Just check whether this part is available with Spare Parts shop.
sushantr5 is offline   Reply With Quote
Fiat Palio MJD - Known Problems Ice Technical Stuff 304 23rd October 2016 13:31
Help Required Indica Vista Safire or Indica Vista TDI Logical Hatchbacks 63 30th October 2011 08:57
