Old 8th January 2013, 11:24   #1096
kartikk's Avatar
Thanked: 45 Times
Default Re: Indica Vista - list of Known problems
Originally Posted by narayan View Post
Could you guys confirm whether there is any ECU fix for this ?any other thoughts ?
Are you facing issues with the AC? if not then why fix something that isn't broken ?? If you are then a regular A/C cleaning is where you can start, costs about Rs150, TASS also offers chemical cleaning which is about Rs450/- I've done the later and found it pretty good. The car feels fresh.
Originally Posted by foby.sebastian View Post
The service advisor tod that for QJD s the tyre wear is more the max life is 40,000 kms is that correct ?
Do you feel wobbling, reduced braking distance? in that case even within 30K you might need to change. I've covered 55K on stock and don't feel the need, but I'm a sedate driver.
kartikk is offline   Reply With Quote
Old 8th January 2013, 11:34   #1097
narayan's Avatar
Thanked: 1,340 Times
Kartik
Yes. The effect of the ac is poor. My i10 ac is far more quicker. Hence wondering whether its just a case of gas pressure or whether there is any ecu upgrade ? But the car has just done 25k hence was not sure whether gas would have leaked so fast
narayan is offline   Reply With Quote
Old 8th January 2013, 11:49   #1098
kartikk's Avatar
Thanked: 45 Times
Kartik
i10 is also much smaller than the Vista and that might aid the better AC performance/feel, my only submission is first check for any blocked/clogged vents, ask TASS to use the thermometer to check exact temperature, before/after parking in the sun and if you genuinely feel there is a problem then go for a gas fill. The ECU does control the cut-off etc.. but first check for any error codes if it is showing something. All this needs to be done at TASS and since its more of a diagnosis, the overloaded TASS might just give you lots of funny reasons why the AC is actually working/perfect/etc...
Old 8th January 2013, 11:52   #1099
foby.sebastian's Avatar
Thanked: 1,105 Times
I had some wobbling and side pulling issues till 10,000 kms which was rectified eventually.
I usually take my vista on drives to my native and back work on week ends which is approximately 800 kilometers up and down, in which 300 kms will be non stop drive on highway with 4 adults @ night. Guess those non stop drives are eating up more thread.
Also about the lights, since its a dual barrel headlight my electrician advised me not to change the bulb to Philips (more powered SINGE bulb with dim/bright mechanism) with ceramic holders as for trucks.
Have any one tried a pair or Hellas/LF/Bosch running lights on vista ? I am not interested in HID
foby.sebastian is offline   Reply With Quote
Old 8th January 2013, 15:36   #1100
Maverick1977's Avatar
Thanked: 284 Times
You can change the bulbs to Philips Xtreme Vision, you can replace either the High or Low or both beams with them. Its H1 and H7 bulbs that are replaced. These are yellow light and hence no issues with cops. The bulbs are 55W and hence require no relay/cut out. My car was under Xtended warranty when I had done the replacement and had confirmed with the TASS that warranty would not be affected in any way since there would be no touching the original system.
The light has been good, but I had observed that they used to be a slight drain on my old battery. Its been more than a year now and no complaints.
Maverick1977 is online now   (1) Thanks Reply With Quote
Old 8th January 2013, 19:47   #1101
Thanked: 49 Times
I am having a typical problem with the vista - everyday in the morning when i start, the check engine light comes up and the engine rpm goes up, and I can hear a whining sound, like the turbo kicking in. The rpm goes from the normal of 800-900 to about 1200-1400.
The check engine vanishes after 5 minutes drive and does not return for the whole day. The same repeats the next day morning again. Seems like a cold start is what is making this happen.
Took it to TASC and they say they cant get the error code unless the engine is light is on when they plug their computer. They say the error codes are not saved and can only be read instantaneously when it happens. Now the engine light comes up only in morning and am not able to replicate at their service center.
Can anyone throw some light on what the problem might be.
vista_qjd is offline   Reply With Quote
Old 9th January 2013, 13:12   #1102
Arun.K's Avatar
Thanked: 47 Times
Dear Vista owners
I recall reading in one of the threads that the initial lot of Vistas came with a "weak a/c " and there is an ECU fix for this ? Is that correct ? Because my 2009 Dec Vista multi jet does have a weak a/c and when i checked with TASS, they mentioned there is no ECU fix and they need to check the gas pressure and if thats alright check for other issues. Could you guys confirm whether there is any ECU fix for this ?any other thoughts ?
narayan
There was an ECU firmware update for fixing up of weak AC performance in Sep '09. It was done directly under the supervision of TATA Motors executive. After the update there was some increase in cooling. Have look at this post. (Indica Vista - list of Known problems) Since yours is DEC '09 manufactured Vista, ECU update may not be required. A clogged AC filter might be a reason for the weak AC performance. Ask the TASC guys to check and clean the AC filter. Just give a try, it's only a 10 mins work.
Fellow QJD (old/refresh/new) owners whats your tyre milage ?
foby.sebastian
For the first Vista, OE Goodyear GT3 was changed at 55000KMs with Apollo Acelere. Aceleres have done 51000KMs till now and probably they may do another 2000-3000KMs.
The second Vista still runs with OE GT3s at 34000 KMs and I feel two of them will do another 10000 KMs and the other two around 3000KMs. Since they are almost 4 years old, tyre noise has increased. Moreover, tyre rotation cannot be done, as wobbling starts once the placement is changed.
Arun.K is offline   (1) Thanks Reply With Quote
Old 10th January 2013, 12:49   #1103
Thanked: 338 Times
Folks,
For the last couple of days i have seen that i need atleast 2 tries to crank up the engine. Being winter season it is a very cold start but then this has started happening only recently and did not experience this in December month.
So i wonder is this the Battery giving me signals? I am using the stock battery which i got 3.5 years back and i have done 71K Kms as of now.
Do i need to change the battery? Any other points that can be checked?
amitwlele is offline   Reply With Quote
Old 11th January 2013, 13:07   #1104
asbalaji's Avatar
Originally Posted by amitwlele View Post
Folks,
Possibly yes.. I had changed my stock battery 4 months back and it was 2009. In my case, its not even cranking the engine one fine day.
You can also check the battery terminal voltage.. It should be above 12V under fully charged condition.. Anything below 12V means atleast one of the cells dying or weak.
asbalaji is offline   (1) Thanks Reply With Quote
Old 11th January 2013, 17:10   #1105
Sam.k's Avatar
Thanked: 37 Times
I have replaced my high beam bulbs to Philips Essential vision 100w without any mods and its been working fine for the last 1 year and the difference in high beams is outstanding.Moreover the bulbs cost me only Rs.260/pair.
You need to change the relay etc... only if you want to upgrade both high and low beams.
Sam.k is offline   (1) Thanks Reply With Quote
Old 12th January 2013, 14:43   #1106
narayan's Avatar
[quote=Arun.K;3011111 A clogged AC filter might be a reason for the weak AC performance. Ask the TASC guys to check and clean the AC filter. Just give a try, it's only a 10 mins work.
[/QUOTE]
Arun - can the ac filter cleaning be done DIY ? Is it accessible easily ? Thanks
Old 13th January 2013, 13:25   #1107
Arun.K's Avatar
Thanked: 47 Times
narayan, AC filter is located behind the glove box. It is easily accessible, but I doubt whether it can be removed at ease, as I havenít tried yet. But TASC guys quickly do the cleaning.
Arun.K is offline   Reply With Quote
Old 13th January 2013, 23:00   #1108
asbalaji's Avatar
Hello Narayan,
You can DIY..However bit of patience required.. These pictures will help to identify the area and how to remove/refix. Its below the glove box.
asbalaji is offline   Reply With Quote
Old 15th January 2013, 10:42   #1109
Thanked: 481 Times
Is anyone in this forum aware if the stepper motor (aka recirculation motor) which controls the fresh air input for the cabin is covered in Extended Warranty or not? TASC mentions that its not covered and the cost to fix the same is Rs. 1700.
@Chaand is offline   Reply With Quote
Old 15th January 2013, 13:13   #1110
Thanked: 175 Times
You can check exact parts coverage in link below:
http://customercare.tatamotors.com/e...mustKnow.asp#6
amit1234singla is offline   (1) Thanks Reply With Quote
Fiat Palio MJD - Known Problems Ice Technical Stuff 304 23rd October 2016 13:31
Help Required Indica Vista Safire or Indica Vista TDI Logical Hatchbacks 63 30th October 2011 08:57
