Old 30th May 2014, 06:23   #1321
bigben's Avatar
Thanked: 136 Times
Default Re: Indica Vista - list of Known problems
Originally Posted by anilagdr View Post
I already rummaged through the manual, but can't locate it. Can anyone help me out
Let me check if I can help you out here. I will go through the settings and let you know. But if it is really dull I hope you will be able to guide your way through the settings?
bigben is offline   Reply With Quote
Old 30th May 2014, 09:11   #1322
anilagdr's Avatar
Thanked: 59 Times
Thanks, the display is really dull but I guess I can manage to do it at night in total darkness
anilagdr is offline   Reply With Quote
Old 30th May 2014, 09:44   #1323
bigben's Avatar
Thanked: 136 Times
Bad news. I was checking the settings and could not find anything on the music player display. Have you tried increasing the brightness of the display on the speedometer? Maybe that might help.
Old 30th May 2014, 10:31   #1324
Thanked: 237 Times
Originally Posted by narayan View Post
Its done 39500kms so far
thats too early, I have done 1,10,000 kms on the original clutch and there is no sign of slippage as of now.
Generally it depends on how do you drive.
sushantr5 is offline   Reply With Quote
Old 30th May 2014, 23:06   #1325
anilagdr's Avatar
Thanked: 59 Times
I doubt it. Anyway thanks for trying, maybe I'll live with it
Old 31st May 2014, 06:44   #1326
ajay_satpute's Avatar
Thanked: 1,380 Times
Agreed. Increasing brightness of the speedo does not help indeed. I don't think its possible to adjust brightness of the stock music system.
ajay_satpute is online now   Reply With Quote
Old 12th June 2014, 12:34   #1327
Arunshek's Avatar
Thanked: 37 Times
Hi guys,
There is an option.
1. Switch on the Player.
2. Press "Menu" button once. you'll see 3 tabs ( Syst. Audio, Tuner). Pic 1.
3. Press the left scroll button to go to Syst Tab. Pic 2.
4. Press Up scroll button till you reach "Dis Ilum". Pic 3
5. Press "OK" to enter the Menu. and the use Left/Right to Decrease/increase the brightness. Pic 4 is at level 3 & Pic 4 at level 16.
There are other options also in Syst Menu, which you can experiment.
Hope it helps.
Arunshek is offline   Reply With Quote
Old 12th June 2014, 14:03   #1328
bigben's Avatar
Thanked: 136 Times
Originally Posted by Arunshek View Post
Hi guys,
There is an option.
Hope it helps.
Thanks buddy. However, some of us were not privileged to get Blaupunkt. Ours is the old Clarion unit. This unit does not have brightness control or at least I have not been able to find this option.
So, if there is anybody with a clarion unit who has been able to increase the brightness on the HU, please let us know by posting the steps on the forum.
Thanks.
Old 12th June 2014, 16:24   #1329
anilagdr's Avatar
Thanked: 59 Times
Thanks Arunshek. Like bigben said I too have the old Clarion HU. So far no luck in adjusting the brightness.
Old 25th June 2014, 13:12   #1330
Arun.K's Avatar
Thanked: 47 Times
Our Vista's body parts are ageing faster, as first signs of corrosion show up in both the cars. Really shocked to see them within 6 years.
Just above the rear left door window sill in 2008 Vista.
Bottom of front right door in 2009 Vista.
Arun.K is offline   Reply With Quote
Old 21st August 2014, 20:33   #1331
asbalaji's Avatar
Vista QJD - 2009 model - Clutch replacement.
My Vista was due for service and she clocked 45K so far - from the day 1 suffering with hard clutch and its time for replacement. Took it to Ignite, ECR Chennai (Raghav) who had suggested to replace with Fiat Punto clutches as it is compatible.. This has made a big difference - the clutch now behaves like petrol car and I have to adjust myself as I have been driving this Tata truck for long...
Amazing experience with Raghav - a no nonsense guy and pro customer in terms of saving some bucks.
BTW, am looking for replacing the tyres.. zeroed in on Bridgestone - Any suggestion whether to go for AR20 or B290 ?..Bit confused..
asbalaji is offline   Reply With Quote
Old 25th October 2014, 15:44   #1332
smrtdvl's Avatar
Thanked: 68 Times
My 2011 Vista got one of its glow plugs replaced under warranty a couple of months back and today I can see the engine malfunction indicator come up permanently and the heating coil indicator blink a few times once I crank up the engine. Need to visit the ASC next week to check on the glow plug again and moreover the left side fog lamp has some moisture left in it after I had to go thru a pool of water during last week rains. Is the fog lamp covered in extended warranty too?
smrtdvl is offline   Reply With Quote
Old 4th November 2014, 14:49   #1333
narayan's Avatar
Thanked: 1,346 Times
Balaji - I have the same problem. What was the total cost ? My front shocks also seem to be leaking and might have to replace that also
narayan is offline   Reply With Quote
Old 4th November 2014, 15:43   #1334
I also got the clutch replaced on my Vista at 50k KMs. The cost was approximately 7,000/- INR.
Regarding tyres, go for Bridgestone B290. I replaced 4 tyres on my Vista just 2 days ago. The total cost for 4 tyres with weights, new valves, balancing and alignment came out to be 15,600/- INR. It makes a world of difference driving with brand new tyres. The car just glides over the road.
Old 4th November 2014, 15:45   #1335
narayan's Avatar
Thanks Ajay - Does this cover the entire clutch assembly including the hydraulics ? ( master/slave cylinder etc ? ) When was it done ( approx date ? )
My FNG is quoting around 10k for the same job !
Fiat Palio MJD - Known Problems Ice Technical Stuff 304 23rd October 2016 13:31
Help Required Indica Vista Safire or Indica Vista TDI Logical Hatchbacks 63 30th October 2011 08:57
