Old 16th December 2014, 21:07   #1351
petroguzzler's Avatar
Thanked: 187 Times
Default Re: Indica Vista - list of Known problems
Originally Posted by mercedised View Post
A bad turbo has nothing todo with oil leak. Oil leak can be due to busted oil seal, leaking hoses. When a turbo is at fault you will hear pronounced turbo whistle (as is the case with my Safari), poor pick-up, heavy smoke, harsh engine. If none of this is happening then donot replace turbo instead find the cause of leak (busted oil seal, loose hoses etc.) and rectify it. You might have to take it to outside mechanic (you can ask any car taxi guy about good diesel mechanics in your region, this is how I found my mechanic and have been visiting him since last 8 years).
The turbo is functioning properly. There is a lot of smoke under hard acceleration, but that was present from day 1. The pick-up and the harshness are all normal. I am going to get the oil seals and the hoses checked.
petroguzzler is offline   Reply With Quote
Old 17th December 2014, 00:52   #1352
gauravdgr8's Avatar
Thanked: 372 Times
If your RPM goes beyong 2500 in gear 2nd, 3rd or 4th, black smoke is sure to be seen. It has nothing to do with the any malfunctioning. Very evident on my Vista from day 1. No worries.
gauravdgr8 is offline   Reply With Quote
Old 22nd December 2014, 13:00   #1353
man_of_steel's Avatar
Thanked: 1,085 Times
Guys, have a small query here.
Anybody know where the headlight adjusters for the Bright beam bulb is located? I am now able to locate and adjust only the dim beam and could not find the vertical and horizontal adjusters for the bright.
Thanks in advance!
man_of_steel is offline   Reply With Quote
Old 30th December 2014, 13:25   #1354
narayan's Avatar
Thanked: 1,341 Times
Guys
I had reported earlier the problem of bounciness at low speeds in my Vista which got solved by replacing the front struts. Now I am seeing a major bounciness at low speeds from the rear right side. 2 of my tyres do have a bulge. I tried putting a different tyre without a bulge on the rear right side but still have the bounciness. Could this be due to a worn out rear strut ? My car has just about done 43k.
narayan is online now   Reply With Quote
Old 18th January 2015, 22:01   #1355
haria's Avatar
Thanked: 315 Times
Folks, I need some info.
This is specifically aimed at Tata car owners in Bangalore. Any suggestions on which is good service station in Bangalore? Near my office I have
1. Concorde Motoros (near Silkboard)
2. Prerena Motors (near Kudulu Gate)
Any suggestions?
If you know any specific service adviser/contact in these service stations who does a good job, I would appreciate if you can PM me the details.
Browsing through comments about these two service centres, both are having their share of bad reviews.
Any good private garage/mechanic who specializes in Tata Vista - especially Quadrajet? Please suggest.
I have picked up a used Vista VX (2012) model. I want to service it and after hearing the horror stories of various people here, I'm a little doubtful on which service station to go for.
Mod Note : Please make an attempt to reply with full sentences and proper punctuation.
haria is offline   Reply With Quote
Old 18th January 2015, 22:46   #1356
Thanked: 389 Times
Originally Posted by haria View Post
any good private garage/mechanic who specializes in Tata Vista - especially quadrajet ? please suggest
We used Indica V2 for a good 6-7 years almost. After the free services , we used to get it maintained by Sigma motors at Kanakpura road. I am guessing that's a bit far for you.The owner is a mechanic himself and has a decent setup. Quite a knowledgeable guy in fact. If you want to try I can search for his details , I must be having his business card with me .
girimajiananth is offline   (1) Thanks Reply With Quote
Old 19th January 2015, 10:19   #1357
rkg
Thanked: 543 Times
Any suggestions on which is good service station in Bangalore ? near my office
1. concorde motoros (near silkboard)
Concorde, Hosur road. I got my Vista all services done here till 92K. In bangalore most of the private garages too charge almost same as authorized ones. So better stick to authorized.
Quote for changing clutch was 1.5 to 2K in all the garages refereed here in Team-Bhp with full day.
Got is done @ concorde for 1150+ tax, in 3 hours including paid service with year warranty on labour and spares
rkg is offline   (1) Thanks Reply With Quote
Old 19th January 2015, 11:14   #1358
Did you mean the clutch plates? I am also looking forward for replacing them.
Old 19th January 2015, 12:52   #1359
rkg
Thanked: 543 Times
Yes. Labor charges for clutch overhaul is 1150+tax and same only CRB(clutch release bearing) change or both CRB and clutch plates.
In my case CRB is making noise and has to changed. As the car has already clocked 84K mileage, i have changed clutch plates also.( otherwise the mechanic said it has around another 5-10K)
Advantage of getting it done with TASS, is warranty of one year on both parts and labor.
I do not think outside garages offer this
Old 19th January 2015, 16:16   #1360
haria's Avatar
Thanked: 315 Times
Thanks girimajiananth. Please give me the details. I'm having one of Suresh of Sejal Motors, but would like to have this also.
Thanks Rkg. Is it the concorde motors near silk board ? Any specific SA with whom you interacted ? or each service was done by different people ?
Old 19th January 2015, 16:20   #1361
rkg
Thanked: 543 Times
It is the one opposite Christ college near dairy circle.
Initially each service was done by different guys. But last two services @ 80K and 90K done by same guy.
Old 19th January 2015, 16:24   #1362
haria's Avatar
Thanked: 315 Times
Thanks RKG.
Could you please give me the SA name/number ? Maybe thru PM if sharing this info violates any of the forum rules.
I had some pretty weird experience with some SAs in mandovi & Suraksha. (this was for my Maruti Alto) And from the past some years, I specifically ask for the SA whom I have interacted with.. Generally found that this works out better - he also will know the car better.
Old 19th January 2015, 16:45   #1363
Thanked: 389 Times
I have lost his card , got this number from Just dial.
080 - 26324446, 9341234561. Please ask for Mr Chandra Mohan.
Old 25th January 2015, 09:21   #1364
narayan's Avatar
Default Urgent Clutch Pedal Issue!!
Guys
today morning on my way back from shopping when I started the car and depressed the clutch pedal, it just went in flat without any resistance. I checked underneath at the ABC pedal area and noticed that the clutch pedal is connected to a rod with a spring load. To me it looked like that rod had snapped somewhere near the spring mount. Is this possible ?
To give you guys a background, my clutch had hardened almost 15k kms earlier and wondering if all that pressure finally resulted in the rod giving up ?
or is it something to do with the clutch plates ?
I am 80% sure the rod looked broken
Old 25th January 2015, 13:08   #1365
Thanked: 14,600 Times
Check the spring linkage near the rod area as you mentioned. That could have snapped mostly. The pedal has not returned to normal position, Right?!
Clutch, I doubt for it to go flat.
a4anurag is online now   (1) Thanks Reply With Quote
Fiat Palio MJD - Known Problems Ice Technical Stuff 304 23rd October 2016 13:31
Help Required Indica Vista Safire or Indica Vista TDI Logical Hatchbacks 63 30th October 2011 08:57
