Old 23rd February 2009, 22:52   #1
sunil.nv's Avatar
Thanked: 7 Times
Default Hot air vents out under the dash of my alto! please help
Hello Everyone,
I am new to Team BHP and this is my first post. For me its been like a virtual "Dargah" where almost all queries about a car gets answered. This unique site has helped me zero down on my options fitting in to my first car and thats an Indica Vista. And exactly 2 days before i could go and book it! my father in law drops a bomb. He wants to leave his Alto with me for the next 5 months till he is away on an international trip and shattered all my plans.. atleast some of them. Parking is an issue for me and hence i have to wait for my vista.. But my problem is not that.. He got the alto serviced and i was all set for a trip to Guruvayoor this coming weekend and i realised that as soon as i power in the car hot air seems to vent out underneath the dashboard. I checked if the AC unit was switched on but no it wasnt. But I havent tried switching it on either.. the car is 5 years old but has only done 11K kms.. any suggestions?
Please Help.
SN
sunil.nv is offline   Reply With Quote
Old 24th February 2009, 03:20   #2
Thanked: 146 Times
Some more basic checks:
A/c unit is off, but did you check if the blowers are off?
Also, did you check the setting on the blower vent (the one which direct the flow to dash, windscreen or foot)?
HappyWheels is offline   Reply With Quote
Old 24th February 2009, 09:43   #3
tamojoym's Avatar
Thanked: 26 Times
I had similar kind of problems in my Esteem .The culprit being the rubber stopper that holds the wires going in from inside the car to the engine bay area .Once that was fixed .Problem was sorted out .
tamojoym is offline   Reply With Quote
Old 24th February 2009, 10:17   #4
wanderernomad's Avatar
Thanked: 806 Times
Check for gaps and plug holes between the wall separating the engine bay from the paasenger cabin.
wanderernomad is offline   Reply With Quote
Old 24th February 2009, 10:20   #5
Jaggu's Avatar
Thanked: 8,694 Times
Move the air flow knob from footwell to the dash and you will be fine. Move the AC temp knob to max cool and see if the hot is turning to cold in few secs.
Old 24th February 2009, 12:44   #6
dushmish's Avatar
Thanked: 76 Times
Hey Sunil! Refer to the manual of your car. The aircon/heater has some amazing functions. Very few people use any of them. You can actually set the aircon such that the vent on dash will throw cool air and the ones facing in footwell will blow out hot air. This helps manage temp in car the way a climate control does. If you have little babies or elderly people who are sensitive to extreme temps, knowing the functions on aircon can come very handy specially during change of season.
dushmish is offline   Reply With Quote
Old 24th February 2009, 22:01   #7
Thanked: 44 Times
first check if the temp setting on the blower is set to hot. If it is not, then the culprit is the linkage between the lever on the dash and the actual vent. In other words it remains open, allowing hot air from the heater core to enter the car. A mechanic should be able to fix this in 30 seconds.
had this problem on my escort, just after it was given for servicing.
filcord is offline   Reply With Quote
Old 26th February 2009, 10:54   #8
sunil.nv's Avatar
Thanked: 7 Times
Default Thank you folks!
I want to thank each one of you for your time and patience.. And you were right Jaggu the knob was set for the inflow of air .. i turned it back to the circulation mode and now its fine.. I just hope the alto holds on to the trip to guruvayoor :-)
cheers!
SN
Air-con: Center vents throwing out warmer air than side vents? 90Horses Technical Stuff 82 7th July 2015 16:03
DIY: Rear Air-Con Vents wanderernomad DIY - Do it yourself 73 23rd February 2015 10:17
Odd sound from Air-con vents mvaidy Technical Stuff 15 19th January 2015 07:45
Scorpio - Poor air flow from AC vents sashb Technical Stuff 15 30th December 2008 13:37
Air vents on the hood: a perf mod? agentsmith Modifications & Accessories 20 6th September 2006 03:50
