Old 4th May 2005, 02:14   #1
X-Machine's Avatar
Thanked: 12 Times
Default Car battery!
Hey guys,
Well the car's battery plays a very pivotal role,as far as the electricals are concerned.Heck,the car would not even start without a good battery.
This is one of those things which always gets me into a fix.I always fail to understand how to judge a proper battery for the car.So can someone please throw some light on it.
Thanks.
X-Machine is offline   Reply With Quote
Old 4th May 2005, 09:57   #2
c10
c10's Avatar
Exclamation
Hi X-machine...
its true batter is very important in a car, and even more if its a diesel engine...i drive a Diesel contessa and i have Amaron Battery...i've heard ppl say diesel vehicles need to started every day atleast once but believe me, at times i dont start her for nearly 5 to 6 days and when i start her she dosent hesitate...all i wanna convey is Amaron Battery has been doin favourably with my diesel contee since 3years with me...
if you are dirving a petrol then she would do even better for you...
c10
c10 is offline   Reply With Quote
Old 4th May 2005, 10:20   #3
cheatingdeath's Avatar
go wih the brand names ... something like amaron or excel..... will the important point here is to keep the gravity under check .. as its a reversible reaction charging and discharging is done under on roof ... and amaron also comes with a lighting system when the battery turns dead the light changes to red or else it is green through out
cheatingdeath is offline   Reply With Quote
Old 4th May 2005, 11:14   #4
go for an good brand like amaron or exide etc. make sure it suits your car. go regular check ups, atleast once in 2 months.
ravi_28_8 is offline   Reply With Quote
Old 4th May 2005, 11:27   #5
vahss_11's Avatar
i am having exide, which is 18 months old,, charged last week,, i think it was due to hi-fi deck,,,,,so do check tell the dealer your requirements,
vahss_11 is offline   Reply With Quote
Old 4th May 2005, 11:35   #6
amitoj's Avatar
Thanked: 1,691 Times
Say, is it possible to "upgrade" your battery as well? I mean, if the car has add ons like fog lamps, bulbs of higher wattage, 4 huge speakers, a horn that goes AWOOGA AWOOGA etc etc... can one go for an "upgraded" battery? I am not even sure of what exactly an "upgrade of a battery" means... so any clues anyone?
Amitoj
amitoj is online now   Reply With Quote
Old 4th May 2005, 11:38   #7
Psycho's Avatar
Thanked: 95 Times
Suggest that you go for a hassle free battery, also please check your electrical needs before you choose a battery, any addition electricals like upgraded halogens, extra spots, amplifiers etc do add load to the battery hence you will need to pick up the right AH rating for your car.
Eg: For my car a contessa the company battery is a 45 AH, whereas I have added on 4 - 90/100 halogens, 2- 50 spots, 1 amplifier and hence upgraded to a 75 AH, havent run into problems since as 10 AH of the battery is not being currently used.
Old 4th May 2005, 11:41   #8
amitoj's Avatar
Psycho, did u need to make any changes to the alternator as well?
Old 4th May 2005, 11:51   #9
Psycho's Avatar
Thanked: 95 Times
No changes to the alternator are required as long as the voltage and the charge specifications for that battery are met, luckily the Amaron series are highly interchangable. The one I got happens to be an LCV battery and it has never run down on me till date.
However this is not true in the cases of older cars with Dynamo's on them, they would need to be reset to give a higher charge amperage.
Old 4th May 2005, 11:53   #10
Domnic's Avatar
What they mean is basically getting a higher rated battery. Rating goes upon AH (Amp Hours). which shows the amount of amperes it can supply for an hour.
an example take a 75ah battery... if there is a draw of 10amps the battery will last to about 7.5 hours with that load without the alternator charging it . You can decide on load by dividing the watt rating by volts. w/v=i , v X i = w.
Dom
Domnic is offline   Reply With Quote
Old 4th May 2005, 12:51   #11
hey if you have a lot of goodies on your car go for two batteries ... i know ford ikon with all neons heavily loaded deck and killer lights which jump with some sound of music .... he has two batteries
Old 4th May 2005, 13:04   #12
Thanked: 1,642 Times
Curious - if a car comes with a specified battery, isnt the alternator also designed to recharge batteries of that specification? So if you plonk in a bigger battery would it receive sufficient charge, and would it put an additional load on the alternator?
Changing/upgrading batteries were much easier on earlier cars (I wont call them older/outdated because I belive they are more flexible and hence more desirable), especially the older diesels. With the newer cars, EVERYTHING has to be EXACTLY as specified by the manufacturer, or else you will run into some sort of trouble which will take ages to figure out. And it would void the warranty. Hell(a?), I cant upgrade the headlamps on my car!!!
Steeroid is offline   Reply With Quote
Old 4th May 2005, 18:04   #13
[quote=Steeroid]Curious - if a car comes with a specified battery, isnt the alternator also designed to recharge batteries of that specification? So if you plonk in a bigger battery would it receive sufficient charge, and would it put an additional load on the alternator?
QUOTE]
Usually the manufacters overdesign the alternators, so if a put in a battery with a slightly higher AH rating (maybe 10 AH, am guessing), it should be OK.. However a bigger battery does need a higher current alternator.. If you do not upgrade it, you are risking overheating or burning of the alternator
nitinbhag is offline   Reply With Quote
Old 5th May 2005, 02:49   #14
X-Machine's Avatar
Thanked: 12 Times
Thanks for all your replies.
Now,the thing is that i am not changing the battery of my car.That was'nt my querry.
I wanted to know that how does a battery really work.It has 6-8 cells,which one has to charge when the battery is low.So how does that affect the performance of the car?? Also,once my mechanic inserted this device into this acid and water mix in the cell(pardon my ignorance).All he said he is testing the power of the battery and plates of the cell.What is this acid and plates thing in the battery for???
X
Old 5th May 2005, 04:02   #15
adya33's Avatar
Thanked: 97 Times
X
these following links will help you
how batteries work
http://science.howstuffworks.com/battery.htm
What is the difference between a normal lead-acid car battery and a deep cycle battery?
http://auto.howstuffworks.com/question219.htm
CAR AND DEEP CYCLE BATTERY FAQ
http://www.uuhome.de/william.darden/
hope this will help
p.s. : i don't think battery will make any difference in performance of car
adya33 is offline   Reply With Quote
Car battery life - How long did your battery last? shuvc Technical Stuff 918 18th July 2018 11:56
Battery dealer installs 3-wheeler battery in my car!! Now what? Soumyajit9 Technical Stuff 29 19th December 2016 11:06
PICS: SF Sonic Battery Factory. Detailed report on the making of a Car Battery S2!!! Technical Stuff 29 16th April 2016 11:39
Battery question - Can I use Indica Spec Battery in Scorpio, or other such swaps? shekharlele Technical Stuff 18 7th September 2010 09:05
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
