Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 24th February 2009, 21:23   #1 (permalink)
Default Suspension for Optra Royale
Hi -
I'd need some suggestion:
1. I've been informed by 1st Choice guys that some oil is leaking from the front shockers of my car (Optra Royale). Due to that issue, shockers have to be replaced. I'm not sure about that. They've quoted expense of 5-6k for both the front shockers. They also informed me that my car has hydraulic shockers. Need some tips to save that amount?
2. I was giving it a thought to raise my car from back equivalent to SX4 (just to improve ground clearance to some extent) How can that be done & with how much cost?
3. I also want to change the horn of car. When pressed, at times it honks & at times it doesn't. So thought of changing it too. My car has dual tone horn (default). Suggest me some good dual-tone honk (how about Skoda's horn) & what price tag?
PS: I'm in Hyderabad. Suggest me good place where I can buy it from.
rendezvous is offline   Reply With Quote
Old 26th February 2009, 18:10   #2 (permalink)
Any suggestions? I've been waiting to hear from someone on this.
Old 5th March 2009, 18:06   #3 (permalink)
Ice
Ice's Avatar
Originally Posted by rendezvous View Post
Hi -
1. I've been informed by 1st Choice guys that some oil is leaking from the front shockers of my car (Optra Royale). Due to that issue, shockers have to be replaced. I'm not sure about that. They've quoted expense of 5-6k for both the front shockers. They also informed me that my car has hydraulic shockers. Need some tips to save that amount? How many km has your car run? Shocks normally don't start wearing out before 40K, unless its being driven very hard over very bad roads. Have you seen the oil yourself? Is there any squeaking/Thud-Thud sound from the shocks?
If the shocks are leaking oil, then the faulty piece is normally the rubber seals on the edges. It could also be a cracked shock. If the shocks are indeed leaking oil, then I suggest that you change them at the authorised service centre. 5-6k incl. labour at an a.s.s. sounds reasonable in my opinion
2. I was giving it a thought to raise my car from back equivalent to SX4 (just to improve ground clearance to some extent) How can that be done & with how much cost? Can't comment on this. One thing though - any fiddling with the ride height will affect the high-speed dynamics of the car.
The Roots Vibrasonic is a really good, low maintenace horn. With wiring, cutout, and installation it works out to around Rs. 1,300.
The Hella Redgrille is also a good horn, and retails at Rs.1250 (folks, correct me if there are cheaper options out there). However, there a lot of fake redgrills out there, and these may fail very quickly.
A third option is the Roots Windtone horn, which is excellent but needs to be fixed in a certain way so as to prevent water seepage into the horn.
Hey Rendezvous...sorry for the late responses. Usually the folks here are all over a thread the moment its published.
I've tried answering your queries in bold, in the quoted text above.
Cheers and all the best!
__________________
To win, you need a Finn" - Mika Hakkinen
Ice is offline   Reply With Quote
Old 6th March 2009, 11:10   #4 (permalink)
Hey RV do you ahve a detailed ownership report on your car here? I am planning to pick up a second hand Optra Royale from a frined and wanted to know major issues , FE and general upkeep of the car over a period of time.
__________________
The greatest mistake you can make in life is to be continually fearing you will make one.
wanderernomad is offline   Reply With Quote
Old 8th March 2009, 15:47   #5 (permalink)
mdesai_1981's Avatar
hi wanderernmad, i had an optraused for a year and half and had purchased a second hand model. the FE what u should expect is somehwere around 8~9kmpl for 1.6 vgis. and the maintainence is not tht high. regular service and thats it. its a tough car ad has no problems at all. only make sure its not an accident car and the condition of the car. waht i bought was a 13000km driven 1&1/2 yr driven car. got it serviced all fluids replaced including coolant and all. checked all the components and tht was it. small niggling issues were maintenence related tkc n enjoy. its a good car great ride quality and my top speed was 180km/h absolutely stable . tkc n cheers
__________________
Thanx and Regards;
Mihir Desai
mdesai_1981 is offline   Reply With Quote
Old 8th March 2009, 22:28   #6 (permalink)
@mdesai, thanks Mate. The car is clean and belongs to a very close friend. Done only about 15K Kms in the last 4 years.
__________________
Old 8th March 2009, 23:31   #7 (permalink)
that is great then go for it. but remember your optra will have a manual and it has got exactly waht you have to do at the end of 4 years or 40000kms. do that service and you'll be fine for a year. also if money is not a problem then u can put in mobil or castrol edge. both are good i've personally seen superb effects of them ;the engine noise and vibration level dropped by alomst 30~40% super silent car!
but its your call. enjoy the car. tkc
__________________
Thanx and Regards;
Mihir Desai
Old 17th March 2009, 02:57   #8 (permalink)
Thanks buddy....
1. I've optraised till 37k as of now in 4yrs. I don't see any oil leaking when the car is at halt. I don't either hear any thud noise. So what's the solution?
2. I agree but I don't want to make major changes just raise a bit from the back.
Old 15th October 2009, 17:40   #9 (permalink)
Hi rendezvous,
What did you do finally?
Even I was told of the same thing- "you cannot see the oil" was clarified to me very clearly. The car has done ~36000km. I don't think I should replace them- however, the cost is now 3.5k/ shocker
Any idea?
animdas is offline   Reply With Quote
Thread Tools
ICE under 23 K (excl HU) for Optra LT Royale swayam Ask the Gurus 8 2nd September 2007 00:50
chevrolet optra royale 1.6 1000kms xtr21 Long-Term Ownership Reviews 13 27th July 2006 15:41
Chevrolet Optra Royale Gopala Krishnan Sedans 7 17th March 2006 09:30
Chevrolet Optra Royale 1.6 LT Vs New Honda City ZX VTEC rendezvous Sedans 10 22nd December 2005 16:56
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
