Old 25th February 2009, 02:27   #16
56landmaster's Avatar
Its okay, driving around with E-brake will do nothing too severe, since you drove only 5 Km
56landmaster is offline   Reply With Quote
Old 25th February 2009, 03:10   #17
Thanked: 146 Times
This should be in the driving typo thread!
And next time, NK, make sure to fully engage the hand brake. If you were able to drive with the hand break on, then it seems that they were not fully engaged.
This is one way to make sure that you do not do this again, since you will certainly feel a good amount of resistance, a very good amount.
HappyWheels is offline   Reply With Quote
Old 25th February 2009, 03:32   #18
If you drove 5 kms then probably it was partially engaged. So dont worry, no immediate damage will be there except fo the reduction of some of the brake pedals life.
furobiker is offline   Reply With Quote
Old 25th February 2009, 04:22   #19
Thanked: 33 Times
Originally Posted by Raccoon View Post
Dudes, tyres will not be affected due to this. The brake pads that are engaged (not all four pads... but may vary depending on the car) will of course take a big beating.
Engine life will suffer to some extent.
Definitely not something not to worrry about... in the sense, try whatever way you can to not forget to disengage the parking brakes in future. For me it has become an infalliable habit to check the parking brake before taking off.
I stand corrected... No damage to tyres indeed.
By the way I almost decided to putting up some post-its on my windshield to remind me to disengage handbrakes.
And this was after I had drive 25 kms on handbrakes
amohit is offline   Reply With Quote
Old 25th February 2009, 10:43   #20
ASHISHPALLOD's Avatar
Thanked: 286 Times
Originally Posted by ramie2400 View Post
you realised after 5kms and not after 50kms
Yes, this happened with my friend.
We were going to some place in 118NE. It was my friend's car.
He was driving and was telling us that car not pulling well.
We checked engine bay etc. Of course, not found any problem.
After about 50 km, we stopped for chai paani. Friend checked the rear tyres. Hot stuff.
Aahaa, got problem. No no no, not handbrake but assumed that brake pads are locked.
Jack put on, seperated tyre, and found that brake pads are in active condition.
Tried to pull brakepads to free condition with help of screw driver and what not but invain.
At last, friend checked the handbrakes and all are relieved.
ASHISHPALLOD is offline   Reply With Quote
Old 25th February 2009, 10:51   #21
suprateep's Avatar
the only damage that happens - will happen to the brake pads. If you drove moderately over a smallish distance i.e. around 5 kms - expect no damages to either the engine or the tyres. However with a heavy foot - the engine could have been affected over a longish travel distance. Don't worry about the tyres. No damage done here.
suprateep is offline   Reply With Quote
Old 25th February 2009, 10:56   #22
KSM-Vtec's Avatar
Thanked: 440 Times
50kms..well sometimes the most obvious reasons are overlooked..so true isint it?
KSM-Vtec is offline   Reply With Quote
Old 25th February 2009, 11:02   #23
mail4loys's Avatar
While i was travelling from Bangalore to Hyderabad my car was hit by a rock which rolled down to the middle of the road. The rock had badly damaged the right rear wheel and hammed and locked the rear brakes. It was around 1AM and nobody were around, so changed the wheels from stepny and drove back to bangalore with one wheel breaks locked. I drove for 70Kms that way. Next day the damage the damage was assesed to be Break Bads, Wheel cover melted and break oil.
mail4loys is offline   Reply With Quote
Old 25th February 2009, 11:22   #24
Thanked: 139 Times
As others have said, 5 km is not too much to worry about. Nearly all of us may have done this for some distance sometime. However, did you not notice the drag and the noise. Perhaps your mind was on something else (also may have happened to nearly all of us sometime).
vasudeva is offline   Reply With Quote
Old 25th February 2009, 11:25   #25
sj_koova's Avatar
Thanked: 176 Times
My car doesn't move a bit with handbrakes on!
May be because I fully engage the handbrake every time I put it on.
sj_koova is offline   Reply With Quote
Old 25th February 2009, 22:44   #26
Thanked: 660 Times
actually its always a good idea to check the instrument cluster before talking off and shutting.
Please!! those are not show piece in your car.
Old 26th February 2009, 09:16   #27
Guys,
Thanks for all your inputs. I would be careful the next time around. I think one of the members asked if I didn't hear any noise. As I mentioned in my OP, I did feel some resistance and noise, but since I am a new driver, I thought I wasn't driving properly.
NK@Hyd is offline   Reply With Quote
Old 26th February 2009, 09:48   #28
sj_koova's Avatar
Thanked: 176 Times
Originally Posted by NK@Hyd View Post
Guys,
Also try to engage the handbrake fully every time. This will give you a chance to know you are on handbrake when the car doesn't move.
Old 26th February 2009, 10:03   #29
KSM-Vtec's Avatar
Thanked: 440 Times
ya thats a good way of keeping track of the same.
Old 26th February 2009, 13:27   #30
WAGON_R's Avatar
if your car moves even with handbrake on that means you havent enganed the brakes fully. so dont worry they havent wore out.
my wagon R wont move even a bit when my handbrake is engaged. i think you should take a couple od seconds and engage the brakes completely.
WAGON_R is offline   Reply With Quote
Car towed away by traffic cop with the handbrake engaged!! Chewbacca Technical Stuff 20 17th July 2014 18:02
Drove a Formula car, Clio Cup car & more @ Sepang! Michelin Pilot Experience 2013 Rehaan Int'l Motorsport 16 25th September 2013 16:36
Accidently put water in Brake Fluid - Punto Diesel punto_ Technical Stuff 21 26th August 2011 10:33
Doing a handbrake turn to avoid an accident in an ABS vehicle? gopinathann Street Experiences 9 7th April 2008 01:30
Bill of materials for a handbrake assembly? ag501 Technical Stuff 0 29th November 2007 22:35
