Old 3rd June 2011, 21:52   #136
Thanked: 110 Times
Default Re: Fiat Palio MJD - Known Problems
Looks normal. The 2nd speed kicks in just crossing the half way mark. In your case the needle is still below the half way mark so the 'Jet' didnt start.
vijaycool is offline   (1) Thanks Reply With Quote
Old 3rd June 2011, 23:13   #137
funkykar's Avatar
Thanked: 1,743 Times
Perfect!
Just monitor the temp gauge for a few more days. Once a day check for traces of leakage. I presume you have cleaned all the spillage area already.
Possibly, the issue hid itself when the coolant was changed and maxed above the max levels. The Delhi heat might have unearthed it recently
funkykar is online now   (1) Thanks Reply With Quote
Old 4th June 2011, 01:07   #138
architect's Avatar
Thanked: 597 Times
Judging that you were driving on a day like today (with temperature around 35-38 in the evening) with no AC, I think the temperature is quite normal. Remember, you were driving in the city, where the poor radiator has to work in very demanding conditions, with practically no cool air to draw from the front. Either you are standing / crawling in the traffic jam, or you are taking in exhaust fumes of other cars.
And before you call that "Helicopter" fan a "monster" remember that's what gives this car a fantastic AC for its segment.
architect is offline   (1) Thanks Reply With Quote
Old 4th June 2011, 10:05   #139
ByDesign's Avatar
Thanked: 253 Times
I wonder if it does kick in after the halfway mark. Maybe it will later.
Originally Posted by funkykar View Post
Perfect!
Yeah will do.
Arch, when I say monstrous, I mean like how the Veyron has monstrous power. Here, its a good thing
ByDesign is offline   Reply With Quote
Old 22nd September 2011, 15:45   #140
Thanked: 56 Times
The digital CLOCK in my SDX has stopped working all of a sudden 2 days back.
I read the manual and checked the fuses 8,15 and 20 - all are fine.
Any idea as to what could be the problem?
ch.nathan is offline   Reply With Quote
Old 22nd September 2011, 16:58   #141
planet_rocker's Avatar
Thanked: 368 Times
flash a torch at an angle on the clock display - if you see the digits - clock is fine - just the bulb needs to be replaced.
to replace bulb - slowly pull out the inverted 'U' plastic cover (which houses the head lamp leveler in new palios) - take out the screw at the corner - slowly pull out the plastic cover around the dash board - unscrew the clock panel - replace bulb - check if it is working bright / dim (with head lights on) - fix the panel back - enjoy.
usually a regular push type small bulb is used - you can even change the colour of the illumination by changing the green plastic cover on the display with your choice.
take care.
planet_rocker is offline   (2) Thanks Reply With Quote
Old 22nd September 2011, 19:29   #142
Thanked: 56 Times
I did that immediately, and am able to see the digits. Even the clock is running - the 'colon' is blinking and I am also able to adjust the time. That's good news. Thankx planet_rocker. You really rock!!
The clock is on the left side of the cluster and headlamp leveller is on right side of the cluster. Are you sure they are connected to a single cover?
Old 22nd September 2011, 19:34   #143
Thanked: 368 Times
Glad that it helped You are welcome
Yes - single piece of black (or beige in some palios) plastic cover around the dash board - extends till top of the Head Unit area DIY
edit: head lamp leveler on the inverted U plastic cover which is fixed to the black / beige plastic cover
planet_rocker is offline   Reply With Quote
Old 22nd September 2011, 20:21   #144
Thanked: 56 Times
Just went down and took PICs.
Do you mean I have to remove this first?
And then the whole panel cover comes out?
Old 23rd September 2011, 11:22   #145
Thanked: 368 Times
Yes - click lock type - use a thin negative screw driver or something similar - once it pops out - there are screws behind it which keeps the Silver panel / plastic cover stuck to the main dashboard.
once you removed the screws (one in my car) - use the thin negative screw driver to pull out the silver plastic cover (same Click type) - once the panel is out you can easily access the bulb - 'twist' to take out the bulb along with the holder
All dash board bulbs are same (small, pin-type, push to lock / pull to unlock) buy atleast 5-6 keep them with you for future use.
Old 23rd September 2011, 11:43   #146
viper_711's Avatar
Thanked: 55 Times
Default Re: Noise from Rear Hatch Door
Originally Posted by Dud_Dodo View Post
I have this slight 'thud-thud' noise from the rear hatch door, only when I go over bad roads though. Mine has run just over 7800 Kms & is due for the second service which 'm planning to get done tomorrow. I'd pointed this out to Babu from Greentracks during the first service as well but they couldn't fix it ('m not sure they were able to locate the source as well).
Confused whether I should take her back to Greentracks or to Prerana (I bought it from them).
If any of you guys have had this noise issue & have been successful in fixing it, please guide.
P.S. 'm also planning to change the oil to Synthetic Oil during the service tomorrow, is this advisable now or should I wait longer?
Am replying to a very old post and you may have already solved the problem. My 1.6 Stile had a similar issue: the 'U' clamp that holds the lock and is fixed on the body is generally the culprit here. It was solved by removing it and re-fixing with a small thin piece of rubber packing. This was done 2 years back and the rear hatch has not rattled since!
viper_711 is offline   Reply With Quote
Old 3rd December 2011, 21:42   #147
Thanked: 56 Times
Originally Posted by Ice View Post
1. Rear rattling - Its the roof-mounted stop lamp!The plastic cladding that houses the lamp assembly is made of a quality plastic last used to make 5 rupee sunglasses for kids. It cracks after a few weeks of Bangalore-esque roads, and comes undone if you continue to drive over bad roads. The rattling also gets progressively worse.
FIX: Change the housing, not the lamp. Either get it done at Fiat/Tata service stations, or at a roadside mechanic after picking up the housing from a spare-parts store. Note: Change only the housing - the A.S.S. guys will try to convince you otherwise. The housing costs Rs. 450/. Note: Don't try pulling the housing off yourself if the rattling becomes unbearable. You can end up pulling off the main bolt that fixes the entire unit to the body. (Don't ask me how I know about this....)
Hey,
Any idea where I could get the plastic-housing, in Bangalore?
I have tried all T.A.S.S. and all of them are saying they can't sell the housing seperately!
Old 4th December 2011, 21:23   #148
Ice
Ice's Avatar
Thanked: 102 Times
Hey,
No idea. Sorry. I just ripped mine offf
Ice is offline   Reply With Quote
Old 4th December 2011, 22:05   #149
bottle's Avatar
Thanked: 138 Times
2. AC - Ice formation - Once the AC runs continuously for 45 minutes to an hour (especially on the highway), the cooling reduces drastically. Prerana told me that this was because of ice formation, and was part and parcel of the design. I tend to agree with him, because I had the same issue with my Petra's AC.
Fix: Nothing exotic, just irritating. Switch the compressor off every 30 minutes or so on the highway for a minute or so, and the ice melts.
Look forward to hearing from the rest of you!
I saw this ice formation on my car's A/C pipe when I opened the bonnet recently, wanted to confirm if this was normal since I don't remember noticing it before
bottle is offline   Reply With Quote
Old 5th December 2011, 12:04   #150
Ice
Ice's Avatar
Thanked: 102 Times
Bottle :
I can't comment on that. If the cooling and blower throw aren't affected, I wouldn't worry about it. The icing in my case affected the blower throw, and fan speed 3 would seem like 1, with minimal cooling because the ice was blocking the flow of air into the cabin. I don't know how to explain this from a technical point of view.
Indica Vista - list of Known problems greenhorn Technical Stuff 1428 3rd June 2018 21:32
TATA - FIAT Palio Stile MJD : Crafted by FIAT specially for ME! funkykar Test-Drives & Initial Ownership Reports 179 25th March 2014 13:58
Swift VDI+ABS or Fiat Punto MJD or New Fabia 1.2 Diesel. Edit- Booked Fiat Punto MJD magnanimousdude Hatchbacks 59 27th October 2010 13:18
