Old 26th February 2014, 11:44   #256
GrammarNazi's Avatar
Thanked: 1,670 Times
Default Re: Fiat Palio MJD - Known Problems
Hi guys, the Cigarette-Lighter socket in my Linea stopped working after I pulled the phone charger abit (while trying to mount it as GPS on front 3 quarter glass) - the steel part is coming out 1.5", I feel some wire could've cut. Dunno if the fuse is fine, but nothing seems burnt/fused.
A friend says the wires could have got twisted resulting in a short.
Can it be done at a local garage/electrician (since nearest FASS is 15km from home and just up-down will take >2hrs) or will I NEED to go to FASS (since the center panel may have to be opened)?
Pls advise thanks in Adv!
(P.S. : I live in Ulsoor (Bangalore), so if anyone is aware a local garage pls do let me know.)
P.P.S. : The fuse (I'm checking F44) isn't coming out easily, may have to use pliers.
EDIT : BTW, There are no extra fuses or even pliers given! For a car thats never been serviced anywhere but the A.S.S. for 68k kms, this speaks volumes for how little the A.S.S. cares for customers!
Also, I'm said each fuse will cost Rs.40/- at the F.A.S.S. and the SAME fuse costs Rs.6/- outside!
EDIT :
Oops, I think I posted in the wrong thread :P Would be nice if mods pointed me to the right one.
GrammarNazi is offline   Reply With Quote
Old 26th February 2014, 12:11   #257
funkykar's Avatar
Thanked: 1,740 Times
Bhavin,
Any auto electrician should be able to resolve it. I would bet on local auto electricians than the one's at FASS.
funkykar is offline   (1) Thanks Reply With Quote
Old 20th March 2014, 10:29   #258
Black_Beast's Avatar
Thanked: 117 Times
Today while driving to office (just when close to office saw the Heat indication to be just above the mid).
Have parked the vehicle, checked inside bonnet. Coolant container was covered with Black color and i see smoke in the compartment. And see engine oil dripping on the floor.
Spoke with the SA from Fiat, he suggested to tow the car and not drive it any further.
Anyone faced this issue?
Black_Beast is offline   Reply With Quote
Old 20th March 2014, 11:26   #259
Thanked: 175 Times
Most likely a blown head gasket due to overheating, resulting in coolant mixing with engine oil, boiling and dripping from coolant container (some on hot engine parts resulting in smoke/ steam) and floor. Assuming the coolant level etc was ok and not the cause of overheating, most likely the cooling fan had stopped woking.
If it's just head gasket, should get sorted out in about or less than rs.10k. Hope the engine did not seize?
amit1234singla is offline   (2) Thanks Reply With Quote
Old 20th March 2014, 12:34   #260
Thanked: 117 Times
Oh it's cheap, but towing car to service center need to pay more 100 times of it.
Need to check on Fan, Wanted to check we end-up getting the engine sized if I start the engine?
Car is in basement, need to get it out for tow.
Old 20th March 2014, 12:48   #261
Thanked: 175 Times
I suggest this and please use extreme caution.
Let the car cool down considerably. Open the bonnet, fill coolant container with water till max mark only. Remove engine oil dipstick, check oil level, if low, add cheap but clean engine oil to bring the level to mid of max and min mark.
Try to start the car and if it starts, engine is not yet seized (it's highly likely it is not, as you turned it off yourself earlier). Check for any engine check light on dashboard. If none, slowly move the car out of basement. But do not try to drive longer as with the blown head gasket, oil and water is already mixed and will continue to get mixed. Car is bound to overheat after sometime.
After and if you are out of basement, tow the car to ASC. Again, be extremely careful, shut the car is there is anything abnormal.
EDIT - I said about rs.10k because you will need to change engine oil, filter and coolant (at least) in addition to fixing head gasket and fan issue (if any).
Old 22nd March 2014, 12:39   #262
Thanked: 117 Times
Thanks, I managed to push the car out of the basement with help from towing folks. Checked with the SA, he scared me that Engine overhaul is needed. And said 'back combustion' has occurred and he have seen smoke from DIP-Stick.
However, when I asked to show me that, he tried to heatup up the car engine for sometime and didn't see any smoke out of the DIP-Stick.
Noticed black smoke from the exhaust silencer in the back, is this normal when a engine is rev'd in idling?
And also he asked me to change 'Oil cooler', 'supply chain or some chain (forgot the name) - 13K and also to overhaul/change turbo compartment.
But still not clear why there was a leakage, is that oil leakage is because of 'oil cooler' not working? And the problem on 'back combustion'.
Old 4th May 2014, 20:35   #263
Thanked: 117 Times
I am noticing 'glowing' battery indicator in the console. When the car is on the Move. (like i have drove 10+kms and occasionally i notice battery indicator to glow). After turning the engine-off and turning it on, it goes off.
Any known issue on this? Also, AC compressor never cuts-off. Not sure if its a thermostat problem. Any reliable workshop in bangalore to check and repair this AC issue?
Old 8th May 2014, 16:04   #264
h14
h14's Avatar
Thanked: 1,720 Times
AC compressor running continously would mean either the thermostat has an issue or the gas is low. Eitherways you have to check with a AC mech.
h14 is offline   (2) Thanks Reply With Quote
Old 9th May 2014, 11:48   #265
bejoy's Avatar
Thanked: 437 Times
Heard good reviews about Wecool (seems good with Palios) near Garuda mall and Aditya Car AC (Kormangala and Jayanagar). Google maps will give the exact locations.
I too have issue with my 1.2 where the compressor is cutting off often. Need to get it checked.
bejoy is online now   (2) Thanks Reply With Quote
Old 9th May 2014, 12:26   #266
funkykar's Avatar
Whats the status of your MJD Black BEast? Where did you leave your Palio for the works? Was it in Bangalore? Was it just a head gasket or what?
funkykar is offline   Reply With Quote
Old 10th May 2014, 18:11   #267
Thanked: 117 Times
I have been to Aditya Car AC (koramangala) 2 years back to fit a third-party condenser (as mine was leaking) It was good service with them. At that time itself have noticed this issue with 'thermometer', the reading went on decreasing and haven't stopped. They were not able to locate where the 'thermistor' is located for this car. From then, i am manually turning-on/off the AC.
In recent visit to Vecto, they said the Dashboard has to be removed and only then they can fit. It would cost around 9K (labour alone was ~3.5K) Dropped the idea of getting it fixed in Vecto. Need to check with Aditya again.
If you have fixed, please do share the details
Black_Beast is offline   (1) Thanks Reply With Quote
Old 13th May 2014, 17:52   #268
h14
h14's Avatar
The AC freezing is a common issue in most of the Palio MJD's. Few of them had replaced with the thermostat of the Tata Safari and are happy with it. Maybe you can give it a try.
h14 is offline   (1) Thanks Reply With Quote
Old 13th May 2014, 20:18   #269
bejoy's Avatar
Thanked: 437 Times
Yes, for the thermistor replacement, the dashboard need to be dismantled. But there used to be some smart mechanics who did without much opening, basically they knew where it is inside. I had mine replaced at FASS; 10 years back for 1.9k including labor.
The system can be converted to a manual one with a electric thermostat, but need some expert. Not sure of anyone in Bangalore.
bejoy is online now   Reply With Quote
Old 14th July 2014, 23:21   #270
antorquetik's Avatar
Thanked: 37 Times
Hi Anand
Any idea if it is a one-one replacement?
Part number from the safari would help.
I have been facing this issue of compressor engaging and disengaging only at idle when the AC is on. While driving it works fine. so much so the RPM also shuttles by +- 50 due to rapid engagement and disengagement of compressor only at idle with AC on.
Had it been a faulty AC compressor clutch then the clutch would slip while driving at higher RPM, which is not the case here.
Any suggestions?
antorquetik is offline   Reply With Quote
Indica Vista - list of Known problems greenhorn Technical Stuff 1428 3rd June 2018 21:32
TATA - FIAT Palio Stile MJD : Crafted by FIAT specially for ME! funkykar Test-Drives & Initial Ownership Reports 179 25th March 2014 13:58
Swift VDI+ABS or Fiat Punto MJD or New Fabia 1.2 Diesel. Edit- Booked Fiat Punto MJD magnanimousdude Hatchbacks 59 27th October 2010 13:18
