Old 27th March 2010, 19:41   #76
Hi Guys,
Today i went to Him motors for the screeching noise issue and they say it's from the "self". They need to get the approval from "Lucas" to replace a part of "self" and my car needs to be at Him motors for 2 days. I told them to replace it but they said only some part of it would need replacement and this a standard procedure with Lucas. Also they told it's nothing serious and is covered under extended warranty.
I didn't have the time today and hence told them that i would come some other day.
vikasb is offline   Reply With Quote
Old 6th April 2010, 18:28   #77
Alton's Avatar
Thanked: 60 Times
Exclamation Gear changes with a Click - Palio MJD
Today I discovered an issue with my Palio MJD's Gear shift.When changing from 1 to 2 and all the way upto 5th gear,there is a Clicking sound coming from the base of the gear rod.There is no other issue like Grinding from the gears during the shift.The shift is smooth as earlier but with a click as it slots into position.
Just before this ,the car ran a marathon 1200 km within the city through heavy traffic for a full 3 day programme.It was driven by our company driver who is experienced and drives our CEO's XTrail and Corolla.He was all praise for the car.I am sure he did not abuse the car.
And today I find this issue.
Am a bit worried as the Basic Warranty expires this month April 2010.Extended Warranty is valid till August 2011.
The car has no bottom scraping incidents or bad pothole runs till date.
What could be the problem and will it come under Warranty-extended if possible?
What should I ask the TASS to look into? I fear that given their incompetence and ignorance towards Fiat cars ,they may simply either make a mole from an anthill or Viceversa!!!
Gurus ,please help me understand the problem.
Am planning to take my car to TASS in a couple of days.
Kindly Advise.
Alton is offline   Reply With Quote
Old 6th April 2010, 22:47   #78
architect's Avatar
Thanked: 598 Times
Most likely the gear bracket... many people have changed it due to shifting problems. But if the sound isn't noticeable, just ignore. I get a lot of whump sounds from the transmission too, though not from the gearbox.
architect is offline   Reply With Quote
Old 7th April 2010, 11:54   #79
Alton's Avatar
Thanked: 60 Times
The sound is quite noticeable especially with AC and no Music playing.Actually today I asked the man who drove it the previous days about the clicking sound.He said it came up just as he began parking it in reverse before he left on the last day.The next morning I had taken the car.And yes,he was aware of the Reverse lock system in the car.
Can the Gear bracket be replaced in Warranty? If not,how much would it cost with labour approx?
Thanks for the help Sir.
Old 8th April 2010, 23:50   #80
architect's Avatar
Thanked: 598 Times
With labour, I think about Rs 600/- it's a plastic part. Ask Bubby, he got it changed.
Old 10th April 2010, 21:44   #81
Alton's Avatar
Thanked: 60 Times
Thanks Architect Sir,
Scheduled a visit to ASC tomorrow,shall get it done .The Service Engineer has agreed to check and replace under Warranty if possible .If not I will have to pay Rs.680 + 75(service charge).
Old 11th April 2010, 00:10   #82
architect's Avatar
Thanked: 598 Times
But first make sure it is the bracket that's the problem.
And please don't call me Sir, most likely you are older than me. I'm only 29.
Old 13th April 2010, 17:43   #83
Alton's Avatar
Thanked: 60 Times
OK .Well,the problem seems much more than the Gear bracket.Autofin motors ,the ASC now says that gear bracket is OK but a small locking pin which sits between the Gears as they rotate and counter rotate when changed, has been out of alignment.This is the cause of Click sound .Secondly it cannot be rectified and the whole unit has to be changed.Now their issue is whether to change the whole Gear Box under Warranty or simply leave it alone.The ASC engineer says its OK as it does not affect gear changes and also on the long run shows no potential damage to Gear box.They have asked for time to decide on the issue.Should come out with something by this Saturday.
Thanks.
Old 13th May 2010, 15:11   #84
Alton's Avatar
Thanked: 60 Times
Unhappy New issue - Water in carpet
Thanks.
An update: Autofin motors replaced the Gear Bracket free of charge.
Now the gears slot in smoothly and there is no sound at all.
Now I have a new issue coming up soon after the last one.
Seems my car is turning against me for driving it through 90km a day parking it in the Hot Summer of Rural AP and not even pampering it with a cool shower scrub except a vacuum clean on the inside.
The Floor carpet on the left front passenger side and the Left Rear passenger side is soaked with water!.
The car was never hosed down since 2 months.Only a wet wipe followed by a dry wipe with newspaper on glass surface.
Initially I thought it to be a fallen water bottle or a leaking drain tube from AC.
But not so.More than a bucket full was sponged out from the two sides.Have also checked the underside of dashboard for any leaks with full AC.No sign of leakage.
A few pics of the drain plugs on the door
Have also checked for any loose beading on the door sills.No sign of water leakage .Also below the dashboard as seen in the pics.
Can the gurus please suggest any causes and correctives for this.
Should the carpet be changed? New carpet costs Rs.4300/ at TASS.Can I get the carpet in any accessory shop?
Kindly advise.
Old 14th May 2010, 00:09   #85
architect's Avatar
Thanked: 598 Times
It's the AC condensate drain pipe under the dashboard in the left side in the passenger seat foot well. This pipe either comes out of it's hole (from where it drains out below) or it gets clogged and water spurts into the passenger cabin. It happenned to me last summer. Just find it (it's deep inside on the left side under the dashboard), clean it and put it back well into the hole on the floor.
Your carpet is not ruined. Just dry it in the hot sun with the doors open and give the car a good vacuuming. I had severe flooding last summer and my carpet's not spoilt at all. The carpet is made of synthetic (nylon) fibre most likely, so don't think it will be spoilt.
Old 14th May 2010, 21:00   #86
Alton's Avatar
Thanked: 60 Times
Thanks Architect.Shall check as you pointed out.
One more thing,about the Second fan apart from the Radiator Fan,can the engine be switched off even when its running?i.e after a 60 sec idle .Its been coming on in these hot summer days more frequently sometimes booming out for 10-15 mins before it cuts off.I have been idling with AC off till the fan goes off wasting some precious diesel!.
Thanks and regards
Old 15th May 2010, 00:28   #87
architect's Avatar
Thanked: 598 Times
I think you can shut off after the regular turbo-idling for a minute. However, what I try to do is to switch off the AC 5-10 minutes before reaching my destination. Sometimes the fan shuts down by the time I have reached.
Old 16th May 2010, 12:28   #88
Alton's Avatar
Thanked: 60 Times
Thanks Architect for all the good advice.
Found the Water leak in carpet - the AC drain pipe.It was eaten out by a rodent from below the car.!Total cost of replacement - Rs.10 for a PVC pipe by a roadside Tractor mechanic.
Now on even I too shall switch off the AC just before I reach my place.
Thanks again.
Old 16th May 2010, 23:04   #89
architect's Avatar
Thanked: 598 Times
Glad to be of help. You can't imagine how foxed I was when I had water in the cabin the first time.
Old 18th May 2010, 11:16   #90
Thanked: 56 Times
Default Agreed !!
Originally Posted by Ice View Post
1. Rear rattling - Its the roof-mounted stop lamp!The plastic cladding that houses the lamp assembly is made of a quality plastic last used to make 5 rupee sunglasses for kids. It cracks after a few weeks of Bangalore-esque roads, and comes undone if you continue to drive over bad roads.
I agree with Ice.
The only thing I don't like about my SDX is the quality of interior plastics.
My 1.5 year old son was strong enough to break this stop lamp housing with one hand!!!
ch.nathan is offline   Reply With Quote
Indica Vista - list of Known problems greenhorn Technical Stuff 1428 3rd June 2018 21:32
TATA - FIAT Palio Stile MJD : Crafted by FIAT specially for ME! funkykar Test-Drives & Initial Ownership Reports 179 25th March 2014 13:58
Swift VDI+ABS or Fiat Punto MJD or New Fabia 1.2 Diesel. Edit- Booked Fiat Punto MJD magnanimousdude Hatchbacks 59 27th October 2010 13:18
