Old 30th September 2013, 16:44   #31
paragsachania's Avatar
Thanked: 12,364 Times
Default Re: Brakes Catch Fire / Brake Bed in procedure / Brake Shudder : Solved
Originally Posted by ankan.m.blr View Post
By bent rotor disc, do you imply the front disc brakes? (The rear are drum type). Did you change them in Bangalore? How much did it cost? Sorry I have asked so many questions.
Exactly sir. I meant the front only. When I got them replaced in Oct 2011 with the ODO at 147,000kms, I paid 550 for the Rotor. I have heard the price has increased now.
paragsachania is online now   (1) Thanks Reply With Quote
Old 30th September 2013, 16:47   #32
ankan.m.blr's Avatar
Thanked: 520 Times
Thanks a lot! Did you have them changed in Bangalore only .
ankan.m.blr is online now   Reply With Quote
Old 30th September 2013, 16:55   #33
Yes, its a simple task lasting 30 minutes or even lesser with proper set of equipment. Any ASC will do that. But remember that you don't get confused between Wobble at high speeds and shudder at high speeds (Only during braking). Its for the latter that you start looking at Discs as the culprit. The price of 550 INR was for the WagonR.
Old 30th September 2013, 17:32   #34
Thanked: 520 Times
I really appreciate the info you gave. Back with questions again
Did you change discs only in both front tires? Or did you also change brake pad & brake shoe to go with the new disc.
Old 30th September 2013, 18:29   #35
I changed the disc only for one wheel (Left Hand side) and I didn't change the pads. My brake pads usually last (Read efficiency and not life) anywhere between 60k-70k.
Also, there is no linkage between Changing pads and Rotors. They were independent activities based on symptoms I explained.
Brake Shoe is for rear wheels for car equipped with Drum Brakes. Hence Shoes are synonymous with Drum Brakes while pads tag along with Disc Brake systems.
Hope I am clear now.
Old 4th October 2013, 13:42   #36
Thanked: 520 Times
Well it turned out to be a hub deflection (front left). MASS changed the hub under extended warranty. Final bill = Rs. 19.00/-
ankan.m.blr is online now   (1) Thanks Reply With Quote
Why does a car catch fire? ssengo Technical Stuff 40 19th February 2012 08:40
Problem: MPFI Esteem Engine Shudder turbo_c Technical Stuff 22 11th September 2011 21:41
After Nano its R8 to catch fire kraft.wagen The International Automotive Scene 24 24th October 2010 05:07
Even Ascari KZ1's M5 engine can catch fire... 1Day The International Automotive Scene 0 25th October 2006 20:44
The new highways..shudder tsk1979 Street Experiences 24 31st March 2005 03:38
