Closed Thread
Old 27th February 2009, 16:24   #1
Default Old Honda City ...Help Increasing the ground Clearance.
Hi TBHPians,
I have a type II city and want the increase the ground clearance of it.
My silencer has been welded thrice so was wondering if 1 inch spacers and upgrade from 13 '' to 14 '' wheelbase would really help overcoming this problem. Want to know if any consequences for such upgrade .....heard ride becomes more bumpy.
Thanks & Regards,
Pras
prasannapatil is offline
Old 27th February 2009, 19:17   #2
Thanked: 103,716 Times
Hi Pras,
Are you sure that the culprit is ground clearance? The reason I ask is, the OHC's stock exhaust is known to have weak mounts. Once my car crossed 30K, it would require an annual weld / repair job at the time of service. No problems once I shifted over to an Automech exhaust though.
GTO is offline
Old 27th February 2009, 22:09   #3
Hi Pras,
Well when we are five in the car the silencer always touches on the speed breaker( kinda feel that it touches start to end). Day before yesterday I had a look of the car while washing at car washing centre. Saw the front drum was much lower and pretty much scratched. So decided to add some spacers to the shocks to avoid such bruising. What say sir?
Thanks & Regards,
Pras
Old 28th February 2009, 13:15   #4
Aha, that's because of the soft rear end:
1. How many kms has your OHC run? Beyond 50,000, the stock suspension is pretty much beyond its optimal life span. See if your car needs a suspension overhaul.
2. If the stock suspension is still good, upgrading to an after-market (firmer) setup is your only other option. This will affect your ride quality, but will improve the handling.
I haven't really had a problem with speedbreakers in my OHC. And the really nasty type, I attack diagonally (one wheel at a time).
GTO is offline
Old 28th February 2009, 13:55   #5
Shan2nu's Avatar
Thanked: 89 Times
Had the same prob until i got the shocks stiffened. U can get it done for around 4-5k.
Im pretty happy with the street spec setup which is neither too stiff nor too soft.
Shan2nu
Shan2nu is offline
Old 28th February 2009, 14:02   #6
sameel's Avatar
GTO sir thats the only way to do it. the diagonal approach
the firmer suspension set up will only make the ride suffer. but yes if you are hell bent on attacking corners in the ball park of 100kmph all the time then its a nice idea
and yes a tyre upgrade say from the normal 175/80 R13( not sure if its the right size for OHC. pardon me if its wrong!) to 185/80 R13 these tyres will increase the GC ( very slightly ) this might help!!
the best way is to approach the speed breakers slowly . thats why they are kept for in the first place!! lol.
sameel is offline
Old 28th February 2009, 14:14   #7
Shan2nu
Hi , can anyone tell me where to get the shocks stiffened up in mumbai ? How long do these stiffened suspensions last before they become soft again ?
Thanks !
pbp0us is offline
Old 28th February 2009, 16:19   #8
kailashnj's Avatar
Thanked: 281 Times
Shan2nu
Hi Shan2nu,
How did you get gt the shock stiffened. I am interested in doing the same for my Baleno. Kindly provide more details of the same.
kailash
kailashnj is offline
Old 28th February 2009, 16:32   #9
Shan2nu
Hey GTO
My OHC has done 62000 kms till date. My tyres are Good year 175/70 R13.
I feel the suspension are quite good ( One of the mechanic told me pressing the front of the several time should stiffened the the shocks ..He himself did that and said no need to change the shocks..well thats what his opinion was..). He also talked about rubber / metal spacers can be placed on the lower end on the shocks to increase the height of the car.
Hey Shan2nu where can i stiffen the shocks in mumbai? So that I can forget about adding any spacers.
Thanks ,
Pras
Old 28th February 2009, 16:43   #10
Shan2nu's Avatar
Thanked: 89 Times
You can contact viper or rocam, they might help you out.
I've been running my car with stiffened shocks for a year now and haven't seen any drop in stiffness.
From what iv heard, they replace the stock fluid with one that has a higher viscosity rating.
Shan2nu
Shan2nu is offline
Old 28th February 2009, 16:54   #11
WAGON_R's Avatar
Whats the exact process of stiffening? i believe the springs are stiffened in case of the cars.
once i mean shock absorbers overhaul guy. he said he can stiffen them by changing the oil in the struts. he mixes 2 types of oil.one is for softness and one is hard. he said if the hard quantity of oil is mixed more the suspensions are stiffened.
he was doing the same for one bike there.
WAGON_R is offline
Old 2nd March 2009, 11:08   #12
sushrutha's Avatar
Thanked: 325 Times
Some options for increasing the ground clearence are
1. Add spacers ( Handling will get effected)
2. Increase the tyre profile size from 175-70-R13 to 185-70-R13
3. Upgrade from 13" tyres to 14" tyres & Rims, but this will effect your Speedo & odo reading
sushrutha is offline
Old 2nd March 2009, 11:50   #13
lohithrao's Avatar
Thanked: 163 Times
I had got my OHC's shock stiffened to and had done about 24k kms on it before i sold it. i was very happy with it and no issues at all.
Just make sure that you get it done from the right guy.
I would recommend Fazal(FRK) in Bangalore for that.
lohithrao is offline
Old 11th April 2009, 22:13   #14
di1in's Avatar
Thanked: 92 Times
I upsized mine from the 13incher to a 15incher adn it's solved all my clearance problems - besides making it look good. I'd recommend an upsize from the 13" always - it makes the car look quirky.
di1in is offline
Old 12th April 2009, 01:37   #15
ankitahuja's Avatar
Thanked: 46 Times
Agreed, also because the 15"ers make the ride stiffer due to a lower profile. But do you also know how badly the suspension takes a beating!?
Stiffened shocks is a good way to improve the handling on the OHC. Does ANYONE have any idea who can do this effectively in NCR?
(Abhik, are you following?)
ankitahuja is offline
Closed Thread
Increasing the Ground Clearance cityvic Technical Stuff 48 3rd January 2018 12:52
Is the BUMP creating a problem to Honda's Ground clearance? deepanonline The Indian Car Scene 27 28th January 2010 23:58
Increasing the ground clearance of my Bolero? A.P.S.Grewal Technical Stuff 11 9th July 2008 21:03
