Old 28th February 2009, 15:24   #1
Default Fiat siena 1999 model - Higher RPM's while driving
I recently bought a Fiat Siena 1999 model which has run 64 k kms and i have been coming across a strange problem .. The Engine revvs on by it self when the car is in standstill and also on when on an average speed of 60 kmph,when i take away the accelerator to reduce the speed , the engine gives a jerk jerk all the time , but when i do press the clutch it doesnt happen . .i guess this might be cuz of
1 - Has the clutch plate worn out ?
2 - Why the higher RPM's even at standstill ? Is it due to the ECU ?
Can any one of you help me to solve this issue ?
wolverinchandru is offline   Reply With Quote
Old 2nd March 2009, 17:22   #2
planet_rocker's Avatar
Thanked: 366 Times
Idle rpm problem occurs mainly due to Faulty ICV or dirty throttle body. another reason for this is due to faulty lamba sensor / throttle body.
i think you need to go through this:
Cleaning Your Inlet Control Valve - The FIAT Forum
Refer these threads as well:
http://www.team-bhp.com/forum/techni...ight=palio+RPM
http://www.team-bhp.com/forum/techni...ight=palio+RPM (FIAT Adventure issues)
http://www.team-bhp.com/forum/techni...ight=palio+RPM (RPM shoots up when clutch depressed)
planet_rocker is offline   Reply With Quote
Fiat Uno With a Siena / Siena Weekend 1.6 Engine moralfibre Modifications & Accessories 9 1st August 2008 14:20
RX 135 1999 Model Refurbish Suggestions Lovelydude77 Motorbikes 8 24th April 2008 17:15
M800, 1999 Model, Just 6600KM Driven rkbharat Long-Term Ownership Reviews 8 11th October 2007 13:54
Swift : Cold Engine, with higher RPM manjubp Technical Stuff 7 15th December 2006 14:15
