Old 2nd April 2017, 17:24   #1681
Thanked: 609 Times
Default Re: All about Diesel engine oils
Originally Posted by pcpranav View Post
...I went ahead with Castrol GTX Diesel (15w40 CH4), 7.5 Ltr can @ Rs.2400 (MRP was 2640 IIRC).
I drove for ~150 KM till now, and while its too early to comment, I can say didnt get the 'new oil feeling' (i.e. smoothness).
In my case this time, apart from the brand change, I did go lower from CI4+ to CH4. (For Xylo, MM did recommend CH4). Lets see for few days and later revert with my observations.
Though I have never used fully synthetic all these 1.7 Lac KMs, next I would like to try Mobil Delvac 1 (5w40).
Query:
- any negative impact you can think, in my case ?
- can anyone help, where can I get Mobil Delvac 1, preferably around Borivali / Thane / Vashi.
regards,
Pranav
I have driven 600+ KM with GTX, and engine doesnt feel very smooth, and could feel a bit of hesitation when pulling the vehicle on slightly higher RPM. No doubt, Rimula R4 was better than this.
Also, my order for Mobil Delvac 1 (5w40 CI4+ FS) from 99rpm.com has arrived. Actually I had ordered 2 x 5 Ltr packs, instead they have send 10 x 1 Ltr packs, its ok for me. As also mentioned by another user, the stuff is manufactured in Dec'15 and imported in Feb'16. For my upcoming long trip, I plan to replace oil with this one.
pcpranav is offline   Reply With Quote
Old 4th April 2017, 18:09   #1682
Kestrel5915's Avatar
Thanked: 63 Times
I know, from both personal and professional experience, that the 2 things that practically matter the most are:
1. Using the oil grade recommended by the car/engine maker
2. Changing the oil at or lesser than intervals recommended by the car/engine maker.
Other thing that should be done is using oils from standard brands like Exxon Mobil (best), Shell, etc.
All other debates about mineral, synthetic, higher grades, etc is basically for theoretical purposes, with very less practical impact.
These discussions should be read with a pinch of salt.
Kestrel5915 is offline   (2) Thanks Reply With Quote
Old 7th April 2017, 15:21   #1683
scorpian's Avatar
Thanked: 235 Times
Infractions: 0/1 (5)
I am looking at options for engine oil for my upcoming sx4 purchase happening in a few days.
I would be using the vehicle mainly in city and occasionally for highway trips ranging about 600 kilometres in a day.i intend to buy the oil myself and replaced in front of me.
I am thinking of Mobil Delvac 1, is this a good optin? Any other recommendations guys?
scorpian is offline   Reply With Quote
Old 7th April 2017, 16:21   #1684
sagarpadaki's Avatar
Thanked: 1,337 Times
If you want to maintain a drain interval of 15,000 kms then Delvac 1 is a very good option
sagarpadaki is online now   Reply With Quote
Old 7th April 2017, 16:28   #1685
cpbopanna's Avatar
Thanked: 798 Times
I assume you are referring to an SX4 Diesel. In that case, please use Mobil 1 0w/40. The DDiS 200 is too light an engine to warrant the use of Mobil Delvac 1, which is basically for heavy duty engines.
I am just sharing my experience over 5 years and 90,000 km. And yes, please change the oil every 10,000 km, not 15,000 km.
I had even gone upto 20,000 km on a petrol Swift; however the same is not recommended for a diesel engine!
cpbopanna is offline   Reply With Quote
Old 7th April 2017, 17:00   #1686
Thanked: 14,602 Times
No sir. The 1.3L MJD loves Mobil Delvac 1.
Many of my friends use it too and I'm getting one for my Swift ZDi too.
IMHO it is one of the best engine oils for the 1.3L MJD.
Old 7th April 2017, 17:13   #1687
cpbopanna's Avatar
Thanked: 798 Times
I use Mobil Delvac 1 in my 2.5 liter NEF CRDe Mahindra Thar!
Regarding your choice to use the same in the 1.3 liter DDiS 200(/190), may I just say 'to each his own'?
Old 8th April 2017, 01:04   #1688
DRIV3R's Avatar
Thanked: 1,433 Times
Absolutely echo your thoughts. Its the best the 1.3 MJD can get. Been using it in both our MJDs for many thousands of kms. Great NVH and life.
DRIV3R is offline   Reply With Quote
Old 9th April 2017, 10:59   #1689
Thanked: 609 Times
what is the drain interval you prefer, under which driving conditions ?
as posted earlier, I have got the Delvac-1 and today going to replace it.
Old 9th April 2017, 11:03   #1690
cpbopanna's Avatar
Thanked: 798 Times
I generally stick to 10,000 km or 1 year, whichever comes earlier.
Keeps the engine sounding like new!
Old 9th April 2017, 11:12   #1691
JMaruru's Avatar
Thanked: 107 Times
Question Re: Mobil Delvac 1 in B'lore?
Where does one source 'Mobil Delvac 1' in B'lore? I require around 3.1 liters for my swift VDi.
JMaruru is online now   Reply With Quote
Old 17th April 2017, 14:59   #1692
Thanked: 302 Times
I have a n Elantra .I switched over to the synthetic oil about 3 months back.
Since then am finding smoke from my exhaust in the morning when the engine is idling.
It usually stops after about 15 seconds of idling
Is it something to do about synthetic oil.
Company provided oil during the servicing
gajadonga is offline   Reply With Quote
Old 17th April 2017, 15:27   #1693
Default Re: Mobil Delvac 1 in B'lore?
Buy 3 litres from 99rpm.
If you want to buy from brick and mortar shops then JK automobiles on JC road or RSS and Co. on Rajkumar road are two places that i have purchased from .
sagarpadaki is online now   (1) Thanks Reply With Quote
Old 17th April 2017, 15:42   #1694
JMaruru's Avatar
Thanked: 107 Times
Unhappy Re: Mobil Delvac 1 in B'lore?
I checked out '99rpm', and it is NOT available there. So, had to go to 'JK Auto' on JC Road. Bought 3 cans of one liter each. Having filled that in my swift VDi, they checked the oil level and the service guys thought it to be less and topped it off with 10W40 of SHU.
Now, I have this uneasy feeling of what might be happening to the engine with this mix. Next time for sure, have to buy a liter more or go for synthetic oils which come in 3.5L/4L cans.
Old 17th April 2017, 16:07   #1695
rakesh_r's Avatar
Thanked: 743 Times
It's available for sure. You need to check under TATA.
rakesh_r is offline   (1) Thanks Reply With Quote
Skoda / VW Group Engine Oils VeyronSuperSprt Technical Stuff 177 24th May 2018 14:32
Engine oil fraud - should we still recycle used oils? Any other options? SS-Traveller Shifting gears 34 25th November 2014 22:47
Difference in diesel and petrol engine oils sans33 Technical Stuff 30 3rd August 2011 18:58
Camshaft failures in older sports cars in the US : reason : new gen. engine oils? issigonis Technical Stuff 1 7th November 2010 14:11
Diff Engine oils - which to select ? nicejits Technical Stuff 3 6th February 2008 11:52
