Old 11th August 2009, 23:03   #196
Jaggu's Avatar
Thanked: 8,100 Times
If you are very particular you can do a flush, otherwise drain the old oil completely and replace the filter before you fill the new oil. There is no written rule that one should flush the engine before regular interval oil change. Critical factor is how well the old oil is drained out.
Old 11th August 2009, 23:47   #197
greenhorn's Avatar
Thanked: 1,492 Times
dooont do the flush! unless your engine has built up a LOT of dirt inside, let it be.
if you want, after draining the old oil, run the engine with a bit of the new oil, then drain that off, and then fill the new oil again - this time the required quantity.
my engine sounded horrible after the flush. dont do it unless you absolutely need to. have heard it damages the seals etc
Old 12th August 2009, 00:16   #198
Raccoon's Avatar
Thanked: 105 Times
Originally Posted by Ketan View Post
Thank you Raccoon,
As its specifically made for gearbox, I will go for it. I have recently bought Delo 400 10l bucket and once I have the gear oil, I should be ready for the next service..
I was using Delvec MX, Can someone tell me if I need to do a tank flush? I dont have much idea about it, I'm just going to tell GreenTrack guys to do it for me, but let me know if I have to instruct them something specific or take some special care while moving from one oil brand to another..
Delo and flush?? Dude, don't even consider flushing esp. since you are going to use Delo! Stay away from flushing even otherwise... LOL!!
Old 12th August 2009, 00:19   #199
greenhorn's Avatar
what i meant was, instead of using flush, use a little quantity of the new oil, and follow the same procedure !
just in case he was switching oil brands. This is advice i got elsewhere in this forum, not sure where
Old 12th August 2009, 02:11   #200
ph03n!x's Avatar
Thanked: 119 Times
Getz CRDi owners- what engine oil do you use? Read good things about Mobile Delvac MX, any first-hand experiences?
ph03n!x is offline   Reply With Quote
Old 12th August 2009, 12:00   #201
Jaggu's Avatar
Hello when i said flush is not compulsory, it doesnt mean it will do harm! If done properly it will only do good and add some more life to the new oil. As far as harming seals and all are concerned, this happens mostly in very old engines where a sudden change of oil grade or flush happens.
If somebody does a flush job at 20k kms interval nothing harmful will happen!
ph03n!x: Go with Delvac MX its a good oil and should work well, people have tried in Crdi engines like verna and had good results.
Old 12th August 2009, 12:12   #202
sgiitk's Avatar
Thanked: 3,814 Times
Originally Posted by nitrous View Post
These Public Oil companies like IOC,BP,etc don't care about grades or quality.
Definitely not for the enthusiast.
Cannot agree more. Even though grades below API-SJ are now history mostly they are marketing obsolete stuff. I remember the recent ad by BP stating that they now have API-SG!
Also, if you check the so called Maruti Genuine Oil of IOC is only API-SC, while I think Maruti specifies SF/SG! Their Servo is mostly API-SF with the Hyundai & one high end label as SJ.
Old 12th August 2009, 13:44   #203
greenhorn's Avatar
I've read the reverse. Flush on new engine not good, flush on old engine okay
Old 13th August 2009, 10:15   #204
Jaggu's Avatar
New engine as in how many kms? 20k kms is not new in my books. also post the details please.
Old 13th August 2009, 10:42   #205
parimal_g's Avatar
Thanked: 174 Times
It is not advisable to use flush frequently,it removes the carbon and makes your car harsh and increases engine noise and use only reputed flush which are recomanded by manufacturer.
parimal_g is offline   Reply With Quote
Old 13th August 2009, 10:48   #206
Jaggu's Avatar
Ok how many kms is ok then, 20 k kms? i have been using flush every 10k kms and ask BHPians who have heard my car, how the lawn mover engine sounds
3M, OWS are two of the good brands i have come across.
Old 13th August 2009, 11:04   #207
Thanked: 397 Times
Ok gurus I have a question here my safari is back from 2nd service and it is OEM Castrol GTX 15W40 ,
I did an intermediate Oil change at 6500 KM in march as i felt 15K for oil change is too long and at that time Bardhal oil additive was sold to me ( yes that is emotional atyachar so don't ask me why i fell for it) but now after oil change ( without bardhal ) I feel that it was better then plain Castro GTX 15W40. Is there any substance to my observation or it is purley psychological.
amitk26 is offline   Reply With Quote
Old 13th August 2009, 11:08   #208
DieselFan's Avatar
Thanked: 234 Times
I did a flush at 30 k kms and the engine became more peppier (Higher torque /power at wide RPM bands of 1500 to 2500). There was no increase in the noise levels observed. I used an MGA(Some German make I forget the name) flush recommended by the service manager and it worked well. I was charged 800 Rs for material+labour.
DieselFan is offline   Reply With Quote
Old 13th August 2009, 12:31   #209
Jaggu's Avatar
Yes it might help your engine to be a lil more smooth and that maybe the reason why Tata pushes it. Dealer happy and Owner also happy
Old 13th August 2009, 13:20   #210
greenhorn's Avatar
Yahoo! Groups
here's the post I was talking about
Note: he is usually always right
Skoda / VW Group Engine Oils VeyronSuperSprt Technical Stuff 159 23rd February 2018 18:37
Engine oil fraud - should we still recycle used oils? Any other options? SS-Traveller Shifting gears 34 25th November 2014 22:47
Difference in diesel and petrol engine oils sans33 Technical Stuff 30 3rd August 2011 18:58
Camshaft failures in older sports cars in the US : reason : new gen. engine oils? issigonis Technical Stuff 1 7th November 2010 14:11
Diff Engine oils - which to select ? nicejits Technical Stuff 3 6th February 2008 11:52
