Old 1st September 2010, 10:11   #451
ph03n!x's Avatar
Thanked: 118 Times
Originally Posted by crazy_driver View Post
I have done about 30K in my getz crdi in the first year . Was using mineral oil till now (changed at every 5K). Now planning to switch to fully synthentic oil. Problem is the grade. i checked with Mobil1 distributor and they have grades of 5W50 and 0W40. My service people have been using 10W30 mineral oil till now. 10W30 is specified in my getz manual for the array of temperatures mentioned. I want to know whether any of the mobil1 grades can be used on my engine? I have gone through many of the threads, also went to car bible for a detailed study but couldnt decide . So please help.
Hold the thought on 5W50 / 0W40 /10W30 - did you check the API Service Category of the synthetic oil? The Getz CRDi needs API CH or higher category engine oil, which should of course meet the SAE viscosity rating. When looking for synthetics for my Getz CRDi, I found that not many synthetics are CH rated - most are CF or CG at best. And that's why I settled with Mobile Delvac MX, a mineral oil, rated API CI+.
ph03n!x is offline   Reply With Quote
Old 2nd September 2010, 11:51   #452
Ohh i didnt know that. Thanks for the help. May be I should start thinking about the mineral oil again.
By the way, I am also trying to get a K & N filter. I checked their site and came up with the part number - (33-2094) http://www.knfilters.com/search/product.aspx?Prod=33-2094. Can anyone help me on this whether this is the intended part or if this is available in bangalore.
crazy_driver is offline   Reply With Quote
Old 2nd September 2010, 14:54   #453
@ph03n!x - Which is the grade that you used for Mobile Delvac MX. is it 15W40? I only found this grade on net. Is this okay for the getz crdi?
Old 2nd September 2010, 16:38   #454
Thanked: 388 Times
Originally Posted by Rahulk76 View Post
Has anyone tried Petronas Urania ? Every wholeseller shop is brandishing this oil
http://www.mymesra.com.my/microsite/...premo_CI_4.pdf
Seems promising..
FIAT is using it officially , I posted sometime back on this thread.
learnt here that Selenia is bought over by petronas.
I saw a 210 liter barrel in Tata-Fiat workshop it was shipped from Patalganga
so probably reliance is manufacturing it as per the given specs and Petronas just procures and markets.
amitk26 is offline   Reply With Quote
Old 2nd September 2010, 17:54   #455
ph03n!x's Avatar
Thanked: 118 Times
By the way, I am also trying to get a K & N filter. I checked their site and came up with the part number - (33-2094) 33-2094 - K&N Replacement Filters, Replacement Air Filter. Can anyone help me on this whether this is the intended part or if this is available in bangalore.
Will check the part number and post an update a while later (the box is in my garage, in the next street).
Yes, 15W40 it is. And for my running environment it is perfectly fine. In fact it should be find for most of our country's environment, except for those in the hills or regions where temperature drops quite low.
Old 3rd September 2010, 14:16   #456
Also the air filter cannot be different for diesel and petrol right?
Old 3rd September 2010, 15:16   #457
Can somebody give me the price for 1 litre mobil1 delvac mx?
Old 3rd September 2010, 15:20   #458
ph03n!x's Avatar
Thanked: 118 Times
It is indeed the part number you mentioned, though not sure if there is any difference between Petrol and Diesel Getz's filters.
Old 3rd September 2010, 15:36   #459
condor's Avatar
Thanked: 4,420 Times
crazy_driver : Can somebody give me the price for 1 litre mobil1 delvac mx?
MRP is 240 a liter. Minimum I have heard is about 205 a litre.
Note, it is Mobil Delvac MX. Mobil1 is a synth oil.
Old 3rd September 2010, 16:29   #460
Thank you guys. Much valued info. Big help.
Old 3rd September 2010, 22:23   #461
sagarpadaki's Avatar
Thanked: 1,271 Times
Condor,where can i get the delvac MX in bangalore?any trusted shops?
Old 5th September 2010, 03:53   #462
tush's Avatar
Got the OIL and OIL Filter changed for my DDIS last week at 16k km.
Got 4, 1 liter packs of Delvac MX = Rs.950/-
This could have been much cheaper had I got it from the Distributor. But then didnt had enough time as the distributor is far from
where I stay.
The car feels rejuvenated and much eager when peddled.
This experience is getting better and better at every OIL change.
Also saw how the OIL and OIL Filter is changed. I know its mentioned in the manual. Not sure may be would take it as a DIY the next time for fun. The only concern being draining the existing OIL.
Had a bad experience at the service this time.
The SA didnt feel happy from the expressions he showed when I informed him that I just needed OIL and OIL Filter changed and the car washed and vacuumed.
The buggers scratched the left side of the cars front bumper.
This I realized because I stayed there and went inside to give them the OIL packages that I got. And also I wanted to see how its
done.
To calm me down they used some rubbing compounds and have reduced the bad effect and also waved off washing charges as the car was not washed properly due to heavy rush.
Car given at 8:30am and returned at around 1:30pm.
tush is offline   Reply With Quote
Old 5th September 2010, 07:18   #463
rakesh_r's Avatar
Thanked: 703 Times
My swift vdi will go for first service within two weeks.Can i use mobil delvac mx right from first service?
rakesh_r is offline   Reply With Quote
Old 5th September 2010, 14:27   #464
tush's Avatar
Yes, sure you can. I don't see any problem. I have been using Delvac from my first service.
Old 5th September 2010, 14:30   #465
tush's Avatar
MRP is 248/- on the 1 liter pack that I have. Packed 1/2010.
The dealer said, new stock will be higher priced.
Skoda / VW Group Engine Oils VeyronSuperSprt Technical Stuff 156 17th December 2017 22:42
Engine oil fraud - should we still recycle used oils? Any other options? SS-Traveller Shifting gears 34 25th November 2014 22:47
Difference in diesel and petrol engine oils sans33 Technical Stuff 30 3rd August 2011 18:58
Camshaft failures in older sports cars in the US : reason : new gen. engine oils? issigonis Technical Stuff 1 7th November 2010 14:11
Diff Engine oils - which to select ? nicejits Technical Stuff 3 6th February 2008 11:52
