Old 3rd January 2011, 20:48   #511
Jaggu's Avatar
Thanked: 7,675 Times
Default Re: All about Diesel engine oils
Just post a query in mobil site, they will get in touch and guide you to a shop. Give it a day or two for them to respond.
Old 3rd January 2011, 21:21   #512
condor's Avatar
Thanked: 4,420 Times
Default ELF/ Total Performance 15W40
Originally Posted by Eddy View Post
What are the other diesel engine oils (mineral) with CI rating ?
Check ELF / TOTAL
Info on web-page:
ELF PERFORMANCE 3D NEW 15W40
Specifications :
API CI 4/ CH 4/CF 4/ SL,
ACEA E3/A3/B3/B4, MB 228.3/229.1
MAN 3275, Volvo VDS 3, Cummins 20076/72/71,
CAT ECF – I-A, Renault VI – RD/RD2 life.
... recommended for all the commercial vehicles and tractors manufactured by TATA, Ashok Leyland, Mahindra, Eicher, Volvo, MAN, Mercedes etc.
Old 3rd January 2011, 21:40   #513
comfortablynumb's Avatar
Thanked: 917 Times
The 15k (3rd free) service for my mHawk Scorpio is coming up soon, and I'm planning for an oil change using Mobil Delvac Mx. Just wanted to know if any forum members have used this oil in a mHawk Scorpio and what the results were.
Cheers,
Vikram
comfortablynumb is offline   Reply With Quote
Old 4th January 2011, 06:35   #514
Thanked: 84 Times
Its oil change time. Delo has shut shop in India and Mobil Delvac MX is not available anywhere. Car has run 90,000 kms.
There are lot many options nowadays,to list a few:
*Motul Tekma Mega (15W-40/API CI-4)
*Petronas Urania Supremo (15W-40/API CI-4)
*Shell Rimula R4 (15W-40/API CI-4)
*Valvoline all fleet gold (15W-40/API CI-4)
*Castrol GTX Diesel (15W-40/API CI-4)
*Elf Performance Victory (15W-40/API CI-4)
*IOC Servo pride Supreme/Futura-D (15W-40/API CI-4)
rb2399 is offline   Reply With Quote
Old 4th January 2011, 19:41   #515
diesel_maniac's Avatar
Just bought a 5Ltr pack of Mobil Delvac MX for Rs.1300/- from Noida. If you can manage to pick it up from Noida, I can PM you the details. Ichanged the Oil at 5K service interval as I was not sure if the *** had used a diesel specific engine oil at the time of first service.
Does anybody know what grade of Diesel engine oil does Toyota uses/ recommend for use in Innova.
regards
Jasvinder
diesel_maniac is offline   Reply With Quote
Old 5th January 2011, 22:28   #516
sumannandy's Avatar
Thanked: 212 Times
Castrol GTX Diesel was API CH4 till September 2010. Not sure if they have upgraded it recently.
sumannandy is offline   Reply With Quote
Old 5th January 2011, 22:37   #517
rajivanoj's Avatar
Thanked: 45 Times
I am going to get Mobil Delvac MX tomorrow, for Rs.170+ / litre, i think i am saving Rs. 400-500 for 5 litres, since i am going to get in loose, from bulk barrel. (I think its 40 litres),
I can rely that shop , since it is not owned by private party, its run by lorry owners association, so that its much cheaper than other shops.
rajivanoj is offline   Reply With Quote
Old 5th January 2011, 22:37   #518
Eddy's Avatar
Thanked: 4,781 Times
Thanks Condor
@sumannandy: GTX diesel was API CI4 till about two years ago. It was actually downgraded to its present config of CH4
Eddy is offline   Reply With Quote
Old 6th January 2011, 06:32   #519
Thanked: 84 Times
Oh,my bad :(
Here's a CI-4 oil from Castrol India:
Castrol India - Tection Global
Only problem is it comes in 210 ltr barrel.
Old 12th January 2011, 14:20   #520
regards
Jasvinder
Its available for 1160/- at Kotla...
Eddy- Mobil Delvac MX is available at Kotla because I have recently bought. If you need help let me know.
teefosi is offline   Reply With Quote
Old 12th January 2011, 19:21   #521
Need some advice from experts out here on oil for swift diesel. my car has done 50000 kms and is due for service. since beginnning the car has been serviced at MSM and the oil changes were done at 10000kms interval. but last 2 oil changes were done at 5000kms interval.
engine flushing has been done once ard 35000kms and got the EGR cleaned recently.
After going through this thread most people are suggesting mobil delvac mx and the change interval at 5000 kms. also how often should I get engine flushing done. should i do it at every oil change.
How beneficial or effective is engine oil additive and fuel additive? Kindly suggest.
Old 12th January 2011, 19:40   #522
sagarpadaki's Avatar
Thanked: 1,271 Times
Use Delvac MX.Change oil every 5K kms.Do flushing every 10k Kms.This should be more than sufficient
No idea about oil and fuel additive
sagarpadaki is online now   Reply With Quote
Old 12th January 2011, 20:23   #523
condor's Avatar
Engine Flush : is not required too often - even once in 50k should be fine. 10k is too frequent & is not required.
Reg additivies, check on the forum for:
Oil addivites: check for Bardahl
Fuel additivies: check for System-D & Elf EMDFA.
I have tried both, and use them regularly (not continuously).
Old 13th January 2011, 00:27   #524
so how often do you suggest i should use oil and fuel additive. and since you have used it whats the change or benefit did you notice.
I have also checked the thread on fuel and oil additives but the opinion is divided, some have got good results after adding fuel additives, that it keeps the injectors clean etc but on the other hand they say manual decarbonising is the best. and for oil additives they say its just a marketing gimmick and most of the additives are already present in the oil.
so i am very confused
Old 13th January 2011, 13:09   #525
condor's Avatar
@teefosi, to discuss about additives, pls post in those threads.
If you are confused, I suggest you try it out yourself. Oil additive - it's one time (with each oil change). Fuel additives - initially use it regularly (a few tanks continuously), after that you can do 1 in 3 tanks or so.
Skoda / VW Group Engine Oils VeyronSuperSprt Technical Stuff 156 17th December 2017 22:42
Engine oil fraud - should we still recycle used oils? Any other options? SS-Traveller Shifting gears 34 25th November 2014 22:47
Difference in diesel and petrol engine oils sans33 Technical Stuff 30 3rd August 2011 18:58
Camshaft failures in older sports cars in the US : reason : new gen. engine oils? issigonis Technical Stuff 1 7th November 2010 14:11
Diff Engine oils - which to select ? nicejits Technical Stuff 3 6th February 2008 11:52
