Old 20th May 2011, 07:19   #721
Thanked: 100 Times
Default Re: All about Diesel engine oils
ESP stands for "Emission System Protection" and these oils are CJ-4 compliant which mandates Sulphated Ash (ASTM D874) <= 1.0%.These oils are meant for Vehicles fitted with Diesel Particulate Filters(DPFs),EGRs & Diesel Oxidation Catalysts (DOCs).
source:Mobil Delvac 1 ESP 5W-40.
All the API specs are backward compatible meaning you can safely use API CI-4 oil in an engine that needs API CG-4 and above.
rb2399 is offline   Reply With Quote
Old 20th May 2011, 09:32   #722
condor's Avatar
Thanked: 4,907 Times
Originally Posted by greenhorn View Post
.. he used CRB turbo in his indica... it was performing pretty nicely.
@Greenie, why should a commercial vehicle oil not work well in a passenger vehicle ? An oil meant for commercial vehicles should logically be able to take more 'abuse'.
But then, such oils are priced lower, and may not be that refined.
Old 20th May 2011, 13:30   #723
csateesh's Avatar
Thanked: 122 Times
Originally Posted by Peter View Post
I got to see the barrel , it was indeed Mobil Delvac 1,
I think the same was mentioned in the Service receipt as well..though I do not have a copy of it now
@ Peter - Good to hear that Maruti provides a choice to their customers
Talk about setting trends..
This is indeed the best brew you can get for your MJD.
csateesh is offline   Reply With Quote
Old 20th May 2011, 14:24   #724
sgiitk's Avatar
Thanked: 3,884 Times
They say competition improves the breed, may be one can add service as well. I hope all dealerships start offering you a choice of the fluids to be used.
sgiitk is online now   Reply With Quote
Old 20th May 2011, 22:08   #725
ph03n!x's Avatar
Thanked: 120 Times
Originally Posted by satish_tns View Post
I came accross mobil delvac 1 5w40 and mobil delvac 1 ESP 5w40. What is the difference between these 2. Does anyone know what ESP means or stands for.
Also read through few info that states that CI and CJ spec oils are better for modern diesel engines with EGR (Exhaust gas recirculation). EGR puts the oil to more strain and CI and CJ spec oils does better than CG or CH spec oil on diesel engine with EGR (Engines meeting BS4). So here is the question. If the manufacturer's required engine oil spec is CG-4 (taking swift D as eg. as I have this car), can we use oil meeting CH and more like CI and CJ ? Will there be good effects or bad effects in using an engine oil which is higher in spec than the manufacturer's req?
The API website will usually mention if a specific service category is also compatible with the preceding ones. Here is what we have for API CJ-4:
API CJ-4 oils exceed the performance criteria of API CI-4 with CI-4 PLUS, CI-4, CH-4, CG-4 and CF-4 and can effectively lubricate engines calling for those API Service Categories. When using
CJ-4 oil with higher than 15 ppm sulfur fuel, consult the engine manufacturer for service interval.
Btw, where did you see the ESP version of Delvac 1? I would like to grab one if it is out here!
ph03n!x is offline   Reply With Quote
Old 21st May 2011, 10:53   #726
satish_tns's Avatar
Thanked: 112 Times
Hi all, I came across 'Mobil 1 Turbo Diesel 5w40' that meets or exceeds the specifications: API CJ-4, CI-4 PLUS/CI-4/CH-4/CG-4/ SM/SL/SJ.
Do we have this in India? Is this only for trucks or can we use this on our diesel cars?
How is this oil when compared with Mobil Delvac 1 ?
satish_tns is online now   Reply With Quote
Old 22nd May 2011, 12:06   #727
Vdrive's Avatar
Thanked: 18 Times
Here's the link. But I don't think it is available in India. Here we get only after it is outdated in developed countries.
Mobil 1 Turbo Diesel Truck 5W-40
Vdrive is offline   Reply With Quote
Old 31st May 2011, 13:40   #728
csateesh's Avatar
Thanked: 122 Times
Mobil Delvac 1 is the best brew that is available for diesel motors in India.
Getting others may not be easy. Mobil folks still think the market in India isn't that big for premium oils
Old 9th June 2011, 12:57   #729
Ketan's Avatar
Thanked: 180 Times
My 10L Delo 400 helped me thru last two services. Any idea about Delo 400 avaialble in market? what rate/price?
I may go back to Delvec Mx if I cant finde Delo 400 in market. If I get Delo 400, its surely going to be 2008/2009 mfg. Is it a good idea to use Delo 400 that was sealed for 3+ years?
Ketan is offline   Reply With Quote
Old 13th June 2011, 01:21   #730
Though I'd update this thread since it helped me choose my next oil change - Mobil Delvac 1.
After tramping around JC road and Kalasipalayam road I located what should the "official" Mobil distributor - Speed-A-Way, just off JC road near the BBMP parking lot; Branch Manager - M. Anand; Address - No 1, Susheela Road, 1st Cross; Tel- 41496502. Approx Location as per Google maps (sorry, couldn't get a GPS fix in the rain) - J C Road, bangalore - Google Maps
It should be on the "3rd cross road" behind the HP petrol pump - don't try taking your car down this road! There are 2 Speed-a-way offices on this road, the actual outlet is bang on the road with the Mobil + speed-a-way sign.
Price - Rs. 4270/- for a 5L can, actual MRP sign says 4400. Availability - there were 5 new boxes of 5x5L, mine was the first to be opened. Date of import was listed as Oct 2010. This was my only point of concern but after speaking to many shops on my walk and getting fobbed off with various prices and complaints of unavailability I think these people were solidly reliable.
Cheers,
Goincrazy
goincrazy is offline   (1) Thanks Reply With Quote
Old 13th June 2011, 14:01   #731
Thanked: 30 Times
Infractions: 0/1 (5)
Just changed from Mobil1 supersyn to Castrol maganatec 10w-40 today for my Fiesta diesel. It costs Rs.1100 for 3l can. As only 3ltr can is available. I bought 2 cans(6ltr) and have the rest in reserve.
Before that i have checked with Ford SA, he told me that they usually fill normal castrol engine oils and they don't go for any semi or super synthetic oils as per manual. And used to fill synthetic only on ford mondeo. I just wondered that they don't even follow any spec as per manual.
Kindly let me know if "Castrol magnatec 10w-40 not a bad choice for Fiesta diesel which completed 58K odo.
Jebs is offline   Reply With Quote
Old 13th June 2011, 14:29   #732
Thanked: 525 Times
I am having a hard time sourcing Mobil Delvac 1 5w40, the dealer has Mobil 1 5w50 fully synthetic which he claims can be used for both petrol and diesel engines.
For a DDIS engine, would Mobil 1 0w50 be ok? I checked with Maruti and they fill Shell oil if you ask for synthetic, I think those oils are similar, i.e not a special Diesel oil but basically synthetic oil mainly designed for petrol but meeting the specs for diesel.
chncar is offline   Reply With Quote
Old 13th June 2011, 15:28   #733
Thanked: 30 Times
Hi chncar,
Me too had a hard time to find Mobil Delvac 1. Only R13 is available it seems. Hence, I gotta go for Castrol magnatec.
Old 13th June 2011, 19:19   #734
Soccerfan's Avatar
Thanked: 56 Times
Shifted to Delvac1 last saturday. Immediate effect is that the engine noise has gone down a bit. other than that i couldnt feel any difference. Will drive for some more and will update.
Soccerfan is offline   Reply With Quote
Old 14th June 2011, 12:12   #735
Thanked: 525 Times
Does anyone have contacts of Mobil retailers/distributors in Chennai who stock Delvac 1? Any help would be appreciated.
Skoda / VW Group Engine Oils VeyronSuperSprt Technical Stuff 177 24th May 2018 14:32
Engine oil fraud - should we still recycle used oils? Any other options? SS-Traveller Shifting gears 34 25th November 2014 22:47
Difference in diesel and petrol engine oils sans33 Technical Stuff 30 3rd August 2011 18:58
Camshaft failures in older sports cars in the US : reason : new gen. engine oils? issigonis Technical Stuff 1 7th November 2010 14:11
Diff Engine oils - which to select ? nicejits Technical Stuff 3 6th February 2008 11:52
