Old 2nd January 2012, 16:23   #916
Thanked: 175 Times
Default Re: All about Diesel engine oils
Please find the attached pdf.
Price-1000rs/litre.I know .But one look at the demo,you would really yearn to try it out.Drain interval upto 20000km.By the way i even changed the gear oil to a lifetime one.
Thanks for sharing the details. From the PDF you attached, this seems to be a semi-synthetic diesel engine oil meeting API CJ4 specification. This is for the first time I have seen an API CJ4 oil in India. It's quite common in the states though. Price is on higher side but then this oil must be a direct import I guess.
I'd not recommend you to do 20k km's on it though. Please change at max 12.5k km's or one year. It's not the oil quality but environment and driving conditions which mandate early oil changes in India when compared to west.
BTW, why did you not go for Mobil Delvac 1 5w40? A fully synthetic diesel engine oil, with similar viscosity index and wider temp range at less price. Not questioning your choice, just wanting to understand the perspective!
amit1234singla is offline   (1) Thanks Reply With Quote
Old 2nd January 2012, 16:33   #917
rakesh_r's Avatar
Thanked: 747 Times
I completely agree with you and yes i will be changing the oil 15k/1 year whichever applicable.Yes the oil is a direct import from the states.One of my friend is a dealer/supplier.This oil behaves in a completely different manner as compared to the conventional "Semi/synthetic oil".As i mentioned earlier you have to see the demo in person as this oil was compared with Mobil Delvac super 1300(supplied by me) and Mobil 1.I have posted a link below that best describes the comparo,the test was done in a similar fashion.As per the manufacturer the oil works its way right in to the metal(please dont ask me how),which makes the surface more slippery.
TeamSwift • View topic - What i learned in auto class today
rakesh_r is online now   Reply With Quote
Old 13th January 2012, 00:43   #918
richie4u's Avatar
Thanked: 183 Times
Hi all,
I have a query with regards to engine oil change for my Safari Dicor. I recently went to bosch service center here in Goa as I want to try their service just for an oil change cause I have heard a lot of good stuff about the place.So I asked the Service advisor regarding the oil change and he gave me two options:
1) Bosch 15W40-Mineral oil (approx Rs. 325/ltr)
2) Mobil Delvac 1 5W40 -Synthetic Oil (approx 850/ ltr)
According to him the interval for oil change for the mineral oil will be between 5-6K and 10-12K for the synthetic. Well so my query now is for which oil do I go?
Bosch sounds interesting cause its light on the budget and also I dont mind changing after 5k kms. But is it good for the Safari's Dicor engine?
Also what is the difference between the 15W40 and 5W40 w.r.t. the grades, what is the major difference?
richie4u is offline   Reply With Quote
Old 13th January 2012, 01:05   #919
TRAUMASURG's Avatar
Originally Posted by richie4u View Post
Hi all,
Ideally,you should follow the manufacturer recommendation as in the owner's manual.Diesel engines need heavy grade oil and this is especially true in warm/hot climates.If you are in colder climate during winter use lighter grade oil i.e 5w40,10w40
15w40 is usual oil grade recommended in diesel engines.Diesel engines are less clean than gasoline engines(newer diesels are much cleaner) and one should change oil frequently i.e 5k km along with a quality oil filter.I will not waste extra money for synthetic unless your car manufacturer recommends as in the owner's manual.
TRAUMASURG is offline   Reply With Quote
Old 21st January 2012, 11:11   #920
archat68's Avatar
Thanked: 290 Times
Hi all,
If you stick to mineral oil, try the Gulf Max TD 15W-40. It is a API - CI4 oil so will suit the Safari Dicor too. I think TATA recommends lower grade oil, you will be using a better oil. The sweet point is that the oil is cheap, cost Rs. 850 for 4 liter.
I use it in my Swift D. Maruti recommends oil change at 10K KM, I change every 8K KM.
BTW what's the current market price of Mobil Delvac 1?
archat68 is offline   Reply With Quote
Old 21st January 2012, 12:36   #921
Thanked: 32 Times
I'll try and find out the price for Delvac 1.
the MRP of Mobil Delvac MX (15W-40)on can of 5L(06/2011 Mfd) was 1565/-. & 1 got 5+1L for 1700/- that I bought last week. Had about 2L left from last time as Sierra gulps 7.5 L in one go without a burp .
Digvj is offline   Reply With Quote
Old 22nd January 2012, 23:18   #922
Thanked: 43 Times
hey folks,
Anyone has used Shell Helix HX6 Diesel 15w-40?
it is API CH4
I'm using this oil for the last 5000km on my DDiS engine, i must say this oil is very good. Quite engine, good performance and not felt the need to top up the oil till date.
Anyone else that uses this oil?
Crazy4.Cars is offline   Reply With Quote
Old 23rd January 2012, 19:09   #923
blackfire_9's Avatar
Thanked: 187 Times
I have, & that too on an Indica. It performs great, however it doesn't clean all that well as say the Delvac. This might be because the Devac is primarily meant for heavy vehicles where the drain intervals are longer & the detergent properties have to be a little better in engine oils formulated for use in such vehicles then.
Also try the Rimula series from Shell, they are worth a shot especially if you liked the HX6.
Originally Posted by Crazy4.Cars View Post
hey folks,
it is API CH4
Old 23rd January 2012, 20:16   #924
Thanked: 43 Times
Great thanks for the information, i picked up a 4litre packing of HX6 last time, i used 3 litres for an oil change, the car has crossed 5000km since the oil was changed, there is no need for a top up oil level is perfect, now i plan to change the oil at 9000km (not 10000 what MSIL recommend) so i'm wondering do i buy 2* 1litre packs of HX6 again and fill up 3 litres? or do i go ahead and buy a fresh 5 litre packing of Mobil Delvac MX 15w-40 and keep aside the old 1 litre of HX6, i dont think mixing the oil will work.
Old 23rd January 2012, 20:57   #925
Thanked: 187 Times
I won't suggest mixing the oil. However, let me say this again, the only con with the HX6 when compared to Delvac was the better cleaning properties of the latter. So choose wisely
Old 24th January 2012, 08:41   #926
sagarpadaki's Avatar
Thanked: 1,337 Times
The shell rimula has almost equal if not better cleaning properties as that of delvac mx.
sagarpadaki is online now   Reply With Quote
Old 24th January 2012, 08:49   #927
condor's Avatar
Thanked: 4,908 Times
blackfire_9 : the only con with the HX6 when compared to Delvac was the better cleaning properties of the latter.
sagarpadaki (All about Diesel engine oils): The shell rimula has almost equal if not better cleaning properties as that of delvac mx.
Guys, so how do both of you substantiate your comments ?
Not what you feel, but what is the method of comparing the properties / ability of the two oils ?
condor is online now   (1) Thanks Reply With Quote
Old 24th January 2012, 09:37   #928
Thanked: 201 Times
Default Please suggest a suitable oil for W124 E250 Diesel
Car : Mercedes W124 E250 Diesel.
The requirements from the manual are as follows. Kindly suggest a suitable oil. Currently I am running on Mobil Delvac.
I read somewhere that for older engines, it is better to use thicker oils to prevent oil seepages.
At the moment, I am facing oil seepages of few drops per day - not worrysome now since I can live with it until the problem becomes bigger. I monitor the oil level daily and there is no preceptible fall.
Ravindra M is offline   Reply With Quote
Old 24th January 2012, 10:12   #929
condor's Avatar
Default Re: Please suggest a suitable oil for W124 E250 Diesel
@Ravindra, what does the manual say - 15w40 ? 10w30 ?
There's a wide range of oils available in the market - from CF to CI, so you should be able to get the right oil.
I dont know about oil seepage & thinner oils, but I felt a difference (a little more rough) when I move to higher rated oils than what was recommended for my Sumo. So planning to go back to lower rated oils (like CF).
Old 24th January 2012, 10:37   #930
Thanked: 201 Times
There's a wide range of oils available in the market - from CF to CI, so you should be able to get the right oil.I don't know about oil seepage & thinner oils, but I felt a difference (a little more rough) when I move to higher rated oils than what was recommended for my Sumo. So planning to go back to lower rated oils (like CF).
@Condor : Thanks for the reply. The manual leaves it to us to choose the SAE grade depending on the average ambient temperatures.
My mechanic asked to use fully synthetic without any specific reasons. However this is old gen engine and I would like to stick to the recommended oils. It is also mentioned that oils as per CCMC specifications are recommended over API specifications. I am not expert in this matter, but I was not able to find CCMC specs oil in Indian market. Any help in this matter would be highly appreciated. Thanks in advance.
Skoda / VW Group Engine Oils VeyronSuperSprt Technical Stuff 177 24th May 2018 14:32
Engine oil fraud - should we still recycle used oils? Any other options? SS-Traveller Shifting gears 34 25th November 2014 22:47
Difference in diesel and petrol engine oils sans33 Technical Stuff 30 3rd August 2011 18:58
Camshaft failures in older sports cars in the US : reason : new gen. engine oils? issigonis Technical Stuff 1 7th November 2010 14:11
Diff Engine oils - which to select ? nicejits Technical Stuff 3 6th February 2008 11:52
