Old 26th April 2012, 13:34   #976
adityamunshi's Avatar
Default Re: All about Diesel engine oils
Just bought a 7.5L bucket of Elf Performance 3d API-CI for 1650/-. Looks good, will post report after trying it out today.
adityamunshi is offline   Reply With Quote
Old 12th May 2012, 23:32   #977
Thanked: 43 Times
Brought Mobil Delvac MX 10 litres for 2800/- API Of course.
MRP is 3150/-
brought it from Akshaya Lubricants on 80 Feet Road Rajajinagar.
I've been using Shell Helix HX6 diesel till date, i'll post review of the Mobil Delvac MX when compared to shell soon.
Crazy4.Cars is offline   Reply With Quote
Old 18th May 2012, 15:21   #978
panky12345's Avatar
Thanked: 127 Times
Originally Posted by Crazy4.Cars View Post
MRP is 3150/-
Just bought a can of 5 L for 1180/- here in Delhi..
Old 18th May 2012, 15:46   #979
blackfire_9's Avatar
Thanked: 187 Times
Hey,
Could you share the updates on how has your experience been so far with the Delvac. And specifically, a comparison between Shell Helix HX6 vs the Delvac.
Drive safe.
MRP is 3150/-
Old 18th May 2012, 22:09   #980
Thanked: 43 Times
Oops huge difference, i got it for 1400 for 5 litres.
Are you sure it is Mobil Delvac MX? what was the MRP on the 5Litre Can?
Originally Posted by blackfire_9 View Post
Hey,
Drive safe.
Right let me very honest, i have used the car for 600Km after the oil change now, Zero difference in performance whats so ever.
Both the Oils are Brilliant. NVH levels are low, Car is smooth, Pick up and turbo kick is awesome.
May be i'll feel the difference between shell and mobil post 2000 or 3000km, i'll keep you posted.
Old 19th May 2012, 10:47   #981
panky12345's Avatar
Thanked: 127 Times
Oh yes! Its Delvac MX.. MRP stands @ 1565/-.
Old 19th May 2012, 12:40   #982
DRIV3R's Avatar
Thanked: 1,156 Times
Bought Mobil Delvac 1 5L can for 3750 INR. MRP was 4400 INR. Initial price quoted was 4k, Nov 2011 import. (grey can, not the old black ones)
DRIV3R is offline   Reply With Quote
Old 19th May 2012, 15:55   #983
Vdrive's Avatar
Thanked: 16 Times
Heard Gulf TD max is a good oil. I'm currently running on Mobil Delvac mx. I too was using Shell Helix HX6 Diesel before Delvac mx. As Crazy4 said, there wasn't any noticeable difference post change to mx. Will switch over to Gulf oil next time.
Vdrive is offline   Reply With Quote
Old 19th May 2012, 20:46   #984
Thanked: 84 Times
My faith in Mobil Delvac MX/Delvac 1 was reaffirmed today when I inspected the innards of my 130,000 kms run TATA Safari while changing its sump gasket.
Here's a view of the oil sump and spanking clean oil strainer.My Safari has exclusively run on Delvac MX and Delvac 1.No Sludge,no nothing
rb2399 is offline   (4) Thanks Reply With Quote
Old 20th May 2012, 11:41   #985
souravc's Avatar
Thanked: 427 Times
Pardon my ignorance but isn't cleaning up the sludge one of the functions of the engine oil ? Shouldn't that reflect on the strainer and the oil sump ?
souravc is offline   Reply With Quote
Old 21st May 2012, 00:14   #986
Thanked: 1,028 Times
Delvac MX is mineral and Delvac 1 is synthetic.
So if both perform equally well, why pay for Delvac 1 which costs almost 4 times of MX? I am really getting skeptical these days about the mythology behind synthetic oils...
Good questions, really.
Honestly, I have not seen a used oil strainer or oil sump, I will try to check mine next time.
anandpadhye is offline   Reply With Quote
Old 21st May 2012, 06:37   #987
headers's Avatar
Thanked: 459 Times
I use Delvac MX mineral oil and am a happy loyal customer of Mobil.
The Oil filter filters the oil and it is a good practise, though not mandatory, to change the oil filter alongwith the engine oil change!
headers is offline   (1) Thanks Reply With Quote
Old 21st May 2012, 10:09   #988
Yesterday I bought 3 litres of mobil delvac 1 for 2100/- for my swift diesel, but mine was a June 2011 import and the same black can. Which shop did you buy it from.
teefosi is offline   Reply With Quote
Old 21st May 2012, 10:14   #989
sgiitk's Avatar
Thanked: 3,794 Times
Infractions: 0/1 (5)
I agree totally. An automotive engine does not really require a synthetic oil. A good (API-SL or SM) mineral (not even semi-synth) is all that is required. These a petrol grades so look for the diesel equivalents (top or top -1 rating!).
sgiitk is offline   (1) Thanks Reply With Quote
Old 21st May 2012, 10:24   #990
But for a city like Delhi where you are always in a stop n go traffic with cars mostly running on 1st or 2nd gear and lot more gear changes, won't a synthetic oil be better for engine life and extended drain intervals.
Skoda / VW Group Engine Oils VeyronSuperSprt Technical Stuff 156 17th December 2017 22:42
Engine oil fraud - should we still recycle used oils? Any other options? SS-Traveller Shifting gears 34 25th November 2014 22:47
Difference in diesel and petrol engine oils sans33 Technical Stuff 30 3rd August 2011 18:58
Camshaft failures in older sports cars in the US : reason : new gen. engine oils? issigonis Technical Stuff 1 7th November 2010 14:11
Diff Engine oils - which to select ? nicejits Technical Stuff 3 6th February 2008 11:52
