Old 26th February 2015, 18:10   #1381
csateesh's Avatar
Thanked: 122 Times
Default Re: All about Diesel engine oils
Originally Posted by Driving_Nomad View Post
I clearly remember it would take ~5 km for it reach there earlier. With the AC on, it only takes 2 km now.
It depends on the outside air temperature. In winters the car takes longer time + distance to reach the 'halfway mark'
Nothing to be worried. Enjoy the car!
Driving_Nomad - Guess a4anurag has indeed answered the query. Don't worry and enjoy the drive
Originally Posted by Mudcat View Post
@Driving_Nomad
I was also wanting the go for the Shell Helix HX7-10w40.
Any advise/suggestions are welcome.
Thanks Anurag! But Nitrous' post quoted below makes me think again.
However, the HX7 also complying with A3/B4, it definitely can be used on diesel engines.
What remains now is to check the manual as you mentioned.
@Mudcat and @Driving_nomad - Interesting to see the discussions about Engine oils for diesel hearts !!
Check for the CI specification. National Engine needs CI4 and above and the HX7 is CH4 and is inferior compared to the spec
The best brew for Diesel hearts if you are particular about Synthetic is Mobil Delvac 1 and if you are particular about Mineral oil I would recommend Mobil 1 15w-40 which is CI4 compliant
Check the history of API ratings from this site
csateesh is offline   Reply With Quote
Old 2nd March 2015, 08:46   #1382
Thanked: 24 Times
I visited the authorized Mobil Dealer a few days back. Mobil 1300 15w40 and Mobil 1400 15w40 are available readily. But Mobil Delvac MX 15w40 sounded like greek to him. I own a Dzire Tour Model. I suppose it is the same old Swift Engine. So I would not opt for synthetic engine oil.
Can you help me decide between Mobil 1300 and Mobil 1400?
Ashok.
Ashok Naik is offline   Reply With Quote
Old 2nd March 2015, 11:24   #1383
rakesh_r's Avatar
Thanked: 743 Times
Ashok.
Mobil1300-Mineral
Mobil Delvac MX-Mineral
Mobil Delvac 1-Full synthetic
Used all the three in my swift. Honestly I didn't feel any difference between the first and second( both were good). However I did find a noticeable difference with the Delvac 1 since it being full synthetic. Now I am using only Delvac 1 since I am happy with performance.
I cannot comment on the 1400 as I have not used it. Try to get the MX else go for the 1300 if you want to stick to minerals,no harm else the Delvac 1 it is.
rakesh_r is offline   (1) Thanks Reply With Quote
Old 2nd March 2015, 21:40   #1384
Thanked: 24 Times
Mobil1300-Mineral
Thanks Mr. Rakesh_R
Delvac MX is not available here. So I will go for Mobil 1300, as you say that both the minerals are equally good. My car has run 23,400 kms till date in 2 years. Is it the right moment to switch to synthetic?
I can spare 2000 Rs. more if that transforms into better mileage, less engine sound and better pick up for the swift Diesel.
And one more query-May be But are there any signs to differentiate genuine Mobil 1300 from fake ones?
I am purchasing the engine oil from the authorized Mobil Dealer-Spectrum Petro. Still I am always suspicious Runs in my genes. Sorry. Infact, I even do not put Diesel at the pump without touching and smelling the nozzle and being 1000% sure that I am using DIESEL only!!!
Do not ask how many fights we have every week due to my infatuation with suspicion.
Thanks in Advance,
Ashok.
Old 4th March 2015, 00:20   #1385
Driving_Nomad's Avatar
Thanked: 79 Times
Thanks Sateesh. Am a bit confused now. should/can I run with this oil for a 7 thousand km more and get it changed at the 75K service? Or can I run this till atleast 70K km (just because I've invested 😔 )? Or should I change it right away?
Driving_Nomad is offline   Reply With Quote
Old 12th March 2015, 07:44   #1386
csateesh's Avatar
Thanked: 122 Times
Driving_Nomad - The oil that you have used if I understand is a mineral one and pls. replace your oil in 5k kms if you use a mineral oil. Stretching it beyond 5k kms isn't advisable
There is no harm using a mineral oil but stick to the 5k interval would be the recommendation
HTH
Old 16th March 2015, 18:27   #1387
S_U_N's Avatar
Thanked: 383 Times
Although my car has petrol engine, I got the Mobil 15W40 diesel engine oil.
Is this wrong?
It does have API - SJ written on the back side along with other stuff which is for diesel.
Could not find much information on the Internet except this link:
http://www.rameshmarketing.com/produ...-TM-15W-40.php
S_U_N is offline   Reply With Quote
Old 16th March 2015, 19:12   #1388
Captain Slow's Avatar
Thanked: 664 Times
Is this wrong?
Attachment 1350252
Which car are you planing to use this on? If its for your cedia this oil is too thick!
Diesel engine oils tend to be a lot more thicker have a lot more Detergent content.
Captain Slow is offline   Reply With Quote
Old 17th March 2015, 08:31   #1389
S_U_N's Avatar
Thanked: 383 Times
Yes. This is for Cedia.
Old 17th March 2015, 08:34   #1390
dinu2506's Avatar
Thanked: 349 Times
I see the Mobil Delvac 1 listed in 99rpm.com. Anyone has experience buying from them? Are they reliable and trustworthy?
dinu2506 is offline   Reply With Quote
Old 17th March 2015, 10:00   #1391
Thanked: 664 Times
Dont! The oil is too thick, and diesel oil in a petrol engine is big NO!
They are fast and very prompt!
But when you are buying parts from them (Tata parts) expect delays.
One part which was ordered a month back still hasn't been shipped.
They emailed me saying they need more time
Captain Slow is offline   (1) Thanks Reply With Quote
Old 17th March 2015, 10:07   #1392
S_U_N's Avatar
Thanked: 383 Times
Can there be a difference in thickness between two 15W40 oils?
That is a multigrade oil just like the following Shell oil.
http://www.shell.com/global/products...-b2-10w40.html
I am still curious to know more.
Edit: Shell 10w40 is not available on India website. This one is a direct comparison in terms of the viscocity; http://www.shell.in/products-service...-b3-15w40.html
Old 17th March 2015, 11:34   #1393
dinu2506's Avatar
Thanked: 349 Times
So, basically, they should supply the oil pretty fast. I was more concerned about the genuineness. Since its a high priced oil and having heard of horror stories of spurious products, do you have any feedback on these lines?
Old 17th March 2015, 11:58   #1394
Thanked: 664 Times
15W 40 in a diesel grade will be quite thick!
During the first few minutes of start up this oil may not flow very well.
Cedia needs a 10W xx.
Read this.
Diesel engine oil has more additives per volume. The most prevalent are overbase detergent additives. This additive has several jobs, but the main ones are to neutralize acids and clean. When you put this extra additive load in a gasoline engine, the effects can be devastating to performance. The detergent will work as it is designed and try to clean the cylinder walls. This can have an adverse effect on the seal between the rings and liner, resulting in lost compression and efficiency.
Yes they do! Ordered gear box oils from them. Took 3-5 days shipped via Fedex!
Everything sold by them are 100% original. I can vouch for that.
Just that their shipping times with tata parts is very-very slow! ( I would blame Tata motors for this) not suppling the required parts
Views expressed here about 99rpm is as a customer. I am not affiliated with them in anyway.
Old 17th March 2015, 12:35   #1395
S_U_N's Avatar
Thanked: 383 Times
Read this.
I am looking into the 'detergent' part. However, for now, I do not know what it means when you state "15W 40 in a diesel grade".
Here is a picture from the Cedia manual.
Notice we can use many different viscosity and grades.
As a best practice, I always turn on the car a few minutes before I start driving and even after driving, I keep to very low speeds - say around 20 kmph in second gear for the first 1 KM or so. By that time, the needle is almost to the optimum mark.
Now, in the summer months, the minimum temperature here is around 16 deg C and that too at early mornings.
S_U_N is offline   (1) Thanks Reply With Quote
Skoda / VW Group Engine Oils VeyronSuperSprt Technical Stuff 177 24th May 2018 14:32
Engine oil fraud - should we still recycle used oils? Any other options? SS-Traveller Shifting gears 34 25th November 2014 22:47
Difference in diesel and petrol engine oils sans33 Technical Stuff 30 3rd August 2011 18:58
Camshaft failures in older sports cars in the US : reason : new gen. engine oils? issigonis Technical Stuff 1 7th November 2010 14:11
Diff Engine oils - which to select ? nicejits Technical Stuff 3 6th February 2008 11:52
