Old 26th July 2010, 17:41   #16
dr.faramroze's Avatar
Thanked: 13 Times
As you said above, there is a leakage even after replacing the radiator. The leak is only after return drive back home. No leakage when engine cold. There is a small outlet kind of pipe located on the crossmember or bottom of the radiator which shows drops od spillage. Does it mean the radiator is faulty or leaky?
dr.faramroze is offline   Reply With Quote
Old 26th July 2010, 18:33   #17
Thanked: 49 Times
You have blown your head gasket. Stop making unnecessary repairs and get the head gasket replaced.
CrackedHead is offline   Reply With Quote
Old 26th July 2010, 22:03   #18
Thanked: 660 Times
what is the state of temp of your engine.
Leakage from bottom of radiator means, the hose is not fitted properly.
replace the hose along with the clamp.
Old 27th July 2010, 11:33   #19
Thanked: 13 Times
With 100% water (tested on pure distilled water since there was total coolant leakage) the temperature rose to half and therafter the fan started.With pure undiluted coolant the temperature rose to 25% mark. Also there is no leakage if pure coolant and full AC is used.
My mechanic is reluctant to replace the thermostat switch after continously pressurising him. I have never faced any overheating problems in my Maruti 84, 92, 97, 2007, Tata Indica V2 LSi and Xeta 1.4.
There are conclusions from various online and offline sources about the head gasket been blown off. There is no acceleration loss, very good fuel returns and no such engine related problems. The pickup on AC is also very good, much better than my 2007 MPFI. I have increased the timing after I bought the car, when it was cold and started the AC to tune idle timing, changed the timing belt, water pump, oil seals and the radiator. Will get the hoses changed today or tomorrow.
Old 3rd August 2010, 13:25   #20
Thanked: 13 Times
MASS Kataria at Vapi, fixed the overheating problem in seconds, the distributor timing was highly advanced, adjusted and the car is perfect now. Then I searched on Google and I read articles explaining how improper ignition timing esp. on MPFI, can cause engine overheating. Thank you SirAlec for your technical support and help. Thank you All.
Fiat Palio Stile Multijet: 196,000 km, 9 years & 8 months up! EDIT: Sold to a Palio lover! architect Long-Term Ownership Reviews 540 23rd December 2017 21:33
Skoda Rapid(ly) Overhauled - Suspension & Brakes Turbo Head Technical Stuff 65 14th January 2016 23:54
Maruti Swift 1.3L DDIS engine overhauled at only 78,000 kms! manver786 Technical Stuff 20 16th November 2014 07:19
Kizashi partly revealed-Can Maruti (suzuki) pull it off in the D-segment? sidindica The Indian Car Scene 126 3rd December 2010 17:01
Gypsy - Overhauled!! rmonie 4x4 Vehicles 70 4th October 2010 00:06
