Old 7th April 2009, 14:49   #31
Harrie's Avatar
Thanked: 25 Times
Got too carried away by the CFM thingy. Thought of it 5 mins back while having lunch. Will update you once I manage to get the SC in the car and spinning. Will be measuring the boost and temperatures at 6500 rpm before deciding anything.
Harrie is offline   Reply With Quote
Old 12th April 2009, 19:04   #32
Harrie's Avatar
Thanked: 25 Times
Update - The NA tuning for the ECU is done. The car is coming in for the SC install tomorrow. Will have to see how the SC can be installed.
To Do
1. Cast Aluminium / Iron housing for SC outlet
2. Fix the SC, piping etc., and measure boost pressure and intake temperatures first before actually routing the intake to the engine. This is because I am not sure if I have the M45 or M60 supercharger. Dont want to take a risk running too high a boost.
Keeping fingers crossed. If the SC boosts as expected and intake temperatures remain under control, things should look very good
Current target is 100 horses at the crank without a inter cooler. The ultimate target can be quite high if the SC turns out to be M60 instead of the M45 that I believe I have. Cant really make it out because this is a very old model and no spec sheets are available anywhere.
Old 12th April 2009, 20:19   #33
Ricky_63's Avatar
Thanked: 394 Times
Originally Posted by nitrous View Post
Infact, There's a supercharged OHC in chennai.
I've seen a setup in a swift and it looked awful. No change in fueling/ignition at all. Was running with a stock ECU.
About the Swift - did it work ?? With the stock ECU I mean !!
Old 16th April 2009, 17:29   #34
Harrie's Avatar
Thanked: 25 Times
Will be interesting to see how they did it.
I am more interested in this
Trust - Greddy - Super Charger kit - Nengun Performance
Old 16th April 2009, 20:51   #35
Ricky_63's Avatar
Thanked: 394 Times
Interesting...how much for the bolt on ? Any idea ?? Is this for the 1.6 or the 1.3 ??
Old 16th April 2009, 20:52   #36
vikram_d's Avatar
Thanked: 940 Times
Small thing to remember. That kit is for the M series engine.
Old 16th April 2009, 22:13   #37
iceman91's Avatar
Thanked: 22 Times
even if for m series it can be mated to our g series. slight work required.
iceman91 is offline   Reply With Quote
Old 23rd June 2009, 21:06   #38
amit_mechengg's Avatar
Thanked: 1,556 Times
any updates on this?
can someone tell me please how effective is the E-supercharger aka the electric supercharger?
someone has put it on sale too. i would call it a blower rather than supercharger.
one thing i wanted to know as how does the ECU calibrate itself with the increased air flow? the stock conditions dont permit calibration above certain % of airflow.
Old 16th October 2009, 11:16   #39
Harrie's Avatar
Thanked: 25 Times
Out with the supercharger... Turbo is installed and running great. Running 5.5 psi near the TB. Stock clutch, no port & polish. OWS turbo racing oil and OWS plugs. RD 0601 for fuel and spark. Using IOC premium so far and no knocking. Have not used the AC so far.
0-100 in 10s with a grandma launch.
I am lovin it
Esteem fuel pump(mpfi) in esteem-carb tank techn0l0gist Technical Stuff 0 13th June 2009 22:03
Getz CRDi - High Demand or NO Demand ??? undead The Indian Car Scene 118 1st April 2008 11:20
supercharging pulsar carazy Motorbikes 4 22nd June 2006 19:36
turbo v\s supercharging full rpm Technical Stuff 52 6th March 2006 14:29
Supercharging topend_hooligan Technical Stuff 0 18th February 2005 13:08
