Old 5th March 2009, 14:45   #16
In the meantime it would be great if you guys can post some more suggestions.
brandon is offline   Reply With Quote
Old 29th March 2009, 01:30   #17
Sivia's Avatar
Thanked: 23 Times
I had the same problem with my petrol lancer , Whistle sound used to come from the speakers i.e whistle sound used to increase with acceleration . Fault was loose earth connection of my ICE .
Sivia is offline   Reply With Quote
Old 26th November 2009, 01:34   #18
Default Whistling sound in my Alto
Hey guys,
From past few days my alto whistles at higher RPM's (redlining RPM's). Once engine passes around 4.5K - 5K RPM's the exhaust starts to whistle..Is that normal or is there any problem...I recently installed a k&N conical filter, but the whistling sound used to come before I installed the k&n..
Please suggest.....
911turbo is offline   Reply With Quote
Old 26th November 2009, 05:39   #19
ghpk's Avatar
Thanked: 193 Times
Earlier i've seen a friend lancer who installed some nozzle at end of silencer which gave whistling sound at high speed.
Do you have any such attachment on silencer end ?
Old 26th November 2009, 06:22   #20
cvc2145's Avatar
Thanked: 16 Times
The whistling sounds are mostly from the intake, some people even do it on purpose to get that. But as you say it was there before the k&n, it is mostly due to a leak in the exhaust. High rpm = high pressure so if there's a leak somewhere, it might sound at high pressures.
Just get an auto guy to check your exhaust starting from the manifold upto the muffler tip while mildly revving the engine. Shouldn't be hard to solve it. If you can hear the whistling while revving, just look for its source.
cvc2145 is offline   Reply With Quote
Old 27th November 2009, 22:02   #21
Naa..I do not have anything at the end of my silencer... The soound usually comes in at high RPM's
Whistling sound from my baleno exhaust amith.2974 Technical Stuff 4 14th October 2009 13:50
Funny Whistling Sound in Scorpio gd1418 Technical Stuff 27 5th December 2008 12:09
Whistling Soung from Blower mobike008 Technical Stuff 9 21st February 2008 01:05
whistling sound Thomas T Technical Stuff 3 14th December 2007 10:15
Whistling noise from the engine Deeps Technical Stuff 10 24th November 2005 18:06
