Old 18th December 2009, 10:14   #226
sudharma's Avatar
Default Front Engine Front wheel drive
Nope, even the base 3 series is RWD.
Any one remember the Indian Front Engine ( Longitudnal) Front wheel drive Vehicle? Not the 3-wheeled Bajaj with the 2-stroke, 2 cylinder water cooled engine mounted on the front wheel.
sudharma is offline   Reply With Quote
Old 18th December 2009, 16:42   #227
kannan666's Avatar
Thanked: 69 Times
The good ol Matador / Tempo ?
kannan666 is offline   Reply With Quote
Old 10th February 2010, 16:45   #228
vamsi.kona's Avatar
Thanked: 132 Times
I have a very basic question. Can any one elucidate the difference between AWD and 4WD, or are they same. TQ
vamsi.kona is offline   Reply With Quote
Old 10th February 2010, 17:35   #229
Forged_Piston's Avatar
Basically in an AWD vehicle, all four wheels of the vehicles are powered by the engine at all times.Where as in a 4wd format, u have the option of powering just the back wheels or all of the wheels.
Forged_Piston is offline   Reply With Quote
Old 11th February 2010, 13:44   #230
Thanked: 57 Times
I have one more query, is it true they say RWD cars are more prone to over steering? and FWD cars are prone to under steering? Or the other way around? Some one at office was discussing this and i was over hearing the conversation Now i am curious!
rjalihal is offline   Reply With Quote
Old 11th February 2010, 14:17   #231
good.car-ma's Avatar
Thanked: 25 Times
I dont know if this has been covered earlier in this thread but isnt it easier to pull off a drift in a FWD using e-brake than one in an RWD using the loss of traction method?
If this has been mentioned earlier pls do ignore..
good.car-ma is offline   Reply With Quote
Old 11th February 2010, 14:29   #232
Shan2nu's Avatar
Thanked: 87 Times
There is no thumb rule as such. It also depends on how the car has been setup.
Our innova is RWD, but i tends to understeer when pushed beyond the limits of traction. So RWD doesn't always mean oversteer.
Shan2nu
Old 15th February 2010, 19:09   #233
shyn's Avatar
Thanked: 2,440 Times
correct me if i'm wrong
1.hand-brake in FWD cars locks the rear wheels.
2.pedal brake in FWD cars stops the diving(front)wheels.
3.it is opposite in RWD cars,hence the drifts.
shyn is offline   (1) Thanks Reply With Quote
Old 15th February 2010, 19:36   #234
Scorcher's Avatar
Thanked: 4,758 Times
1. Not sure, but guess you are right since i've seen people doing static burnouts in FWD cars.
2. Pedal Brake should stop all the wheels at once.
3. Correcto, Hence the drifts(Note, the 'Proper' drifts are done by using the throttle and steering control mainly and Hand-Brake is used only for slight manouvering)
Scorcher is online now   Reply With Quote
Old 21st February 2010, 15:27   #235
DicKy's Avatar
Thanked: 607 Times
Fuel efficiency conscious buyers may prefer FWD and don't care about where the power goes.
But still don't we Indians even have a choice of a RWD car(under 14 lacs),something like the mark x.The only affordable RWD sedan is the amby after which one has to shell out >30 lacs for a german.
DicKy is offline   Reply With Quote
Old 21st February 2010, 16:45   #236
Thanked: 528 Times
There is another type, which is like a 'part time AWD' like in CRV, Captiva etc. These are primarily 2WD and only when there is a slip in any of the powered wheels, part of the power is divertd to the other wheels which are otherwise non powered. Manufacturers simply label them as 'AWD'.
Guna is offline   Reply With Quote
Old 21st February 2010, 17:42   #237
Scorcher's Avatar
That is in case your cant see anything other than German. You can buy Camry - 20 something lakhs, Ambassador - 5 to 7 Lakhs, Tata Nano - 1.8 to 2 Lakh Talk about practicality, will you
Old 21st February 2010, 18:47   #238
racerdabba's Avatar
Thanked: 121 Times
When did camry become an RWD???!!!
racerdabba is offline   Reply With Quote
Old 22nd February 2010, 12:23   #239
Thanked: 89,125 Times
The Camry is a FWD sedan.
Old 22nd February 2010, 16:49   #240
Scorcher's Avatar
Oops. My bad. Thanks for the correction bro. I have no first hand experience with the camry. I was so told by a friend who own one, he was also in a conception that he has a RWD car(He drives a RR Sport and the Camry has only been chauffeured) until i corrected him now. Thanks again.
From a 4 Wheel drive to a rear wheel drive. My Contessa kittigadu Test-Drives & Initial Ownership Reports 16 7th November 2011 14:28
How do front wheel drives and Rear wheel drives behave in a skid adrian Technical Stuff 10 29th June 2011 17:51
Front wheel drive Vs Rear wheel drive ivar1951 The Indian Car Scene 2 17th March 2010 15:08
Rear wheel drive or Front wheel drive : What is your choice ? adrian Technical Stuff 1 25th January 2010 16:26
Cons & Pros of putting 17" front and 18" rear Wheel in Honda Unicorn sreerama Motorbikes 11 8th December 2008 19:31
