Thread Tools
Old 10th May 2005, 01:30   #1 (permalink)
RJK
RJK's Avatar
Post Vibrations under hard braking
Just some time back while returning home I noticed vibrations in the steering wheel when I braked from around 100k's. At low speeds its absolutely not there but around 90-100 I definitely felt it. No problems in turns or whatsoever. The only thing that comes to my mind is probably the alignment/balancing which was done around 3-4months back. What else could it be ?
__________________
'94 Mazda MX-6
My first car with my own money.
RJK is offline   Reply With Quote
Old 10th May 2005, 01:34   #2 (permalink)
speedsatya's Avatar
it could also be due to your front discs being worn out unevenly.does your brake pedal also vibrate?????
speedsatya is offline   Reply With Quote
Old 10th May 2005, 01:40   #3 (permalink)
RJK
RJK's Avatar
No..brake pedal doesn't vibrate. The disc looks absolutely alright but then who knows. The car only today completed 30k kms. Isn't that too early for discs to wear out ?
__________________
'94 Mazda MX-6
Old 10th May 2005, 01:48   #4 (permalink)
merve_extreme's Avatar
Must be due to braking on an uneven road surface.
__________________
No one has done more to improve the automobile than the one who invented it ----- Mercedes Benz
merve_extreme is offline   Reply With Quote
Old 10th May 2005, 01:49   #5 (permalink)
revtech's Avatar
RJK
wear and tear of brakes totally depends on how it was used and whether you usually use engine breaking.if you do your brakes should last longer but breaking hard often does cause some wearing off pretty soon.
as satya said just get the front discs checked.
Rev
__________________
Revin Beyond Limits !!
revtech is offline   Reply With Quote
Old 10th May 2005, 01:55   #6 (permalink)
speedsatya's Avatar
if your brake pedal doesnt vibrate on braking ,then it is something to do with the alignment/balancing or the steering system.
Old 10th May 2005, 11:27   #7 (permalink)
cheatingdeath's Avatar
its alignment and balancing problem...if your car drifts left or right while you a re breaking ... thenget you break liners checked... i strongly feel its to do with balancing..
__________________
YoUr CaR DoEs NoT HaVe a BrAiN, So iT's DoUbLy ImPoRtAnT YoU UsE YoUrS.
cheatingdeath is offline   Reply With Quote
Old 10th May 2005, 12:02   #8 (permalink)
Shan2nu's Avatar
Tie Rod problem, had the same prob on the Vtec, got the tie rods changed and it's perfectly ok now.
Get them checked, they must have stiffened up.
Shan2nu
__________________
VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE
Old 10th May 2005, 12:33   #9 (permalink)
RJK, before you try anything, just get them rebalanced and realligned. will cost you some 300-400rs. If the problem persists, then look at other possibilities :-)
Rahul
rahulmd is offline   Reply With Quote
Old 10th May 2005, 13:15   #10 (permalink)
Team-BHP Moderator
normally_crazy's Avatar
It could either be
1) the Balancing and Alignment of tyres
2) braking on uneven surfaces
other than these 2 reasons i cant think of anything. Could be the tie rod as Shan says but first check out the 2 possibilties and proceed further as Rahul says.
btw - is it natural for the tie-rod to stiffen up at 30K kms ?
but before trying anything i sugest take another trial run on the same stretch or a similar stretch and check whether it happens again
cheers
normally_crazy is offline   Reply With Quote
Old 10th May 2005, 13:46   #11 (permalink)
Team-BHP Moderator
Jaggu's Avatar
how is the tyre condition, over wear/uneven wear also can contribute
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 10th May 2005, 15:02   #12 (permalink)
artofzen's Avatar
My zen makes a screeching sound when i stop the car in a downward slope..it is as if the brakes wont hold .wat might be the reason?
__________________
Corum..
artofzen is offline   Reply With Quote
Old 10th May 2005, 15:11   #13 (permalink)
drifter's Avatar
Screeching sound indicates worn out brake pads. If the pads have been recently replaced, there might be some foreign particle stuck in between the disk and the calipers...a simple brake service should solve that.
Not unless it has been damaged by debris from the road...i had a problem with the tie rod on my indica when a rock hit it after which it had a major bend right in the center. There were vibrations...but they were coming right from when i started the car.
Drifter
__________________
Slow Everything Down And Feel Like God - Tata Safari
drifter is offline   Reply With Quote
Old 10th May 2005, 17:05   #14 (permalink)
Shan2nu's Avatar
Well, i got mine changed at 40K. They had bcome rock hard.
In my case, the problem started when ever i had to brake hard from 140kmph. It was fine before that. Now, i can brake from even 170kmph with any problems.
If it's a wheel balancing problem, it should occur even when the car is accelerating or cruising at high speeds. Allignment usually makes the car drift to one side, it doesn't make it vibrate.
Shan2nu
__________________
Old 21st July 2005, 02:16   #15 (permalink)
turbo_c's Avatar
I fixed a similar problem on my Esteem by getting the Front rotors ground on a lathe and also getting the wheels balanced... it used to shudder quite badly before that, but now, no traces of any problems !
turbo_c is offline   Reply With Quote
Thread Tools
Hard braking in CVT!!! funkydevil Technical Stuff 30 5th February 2008 15:50
Vibrations in car breezydrive Technical Stuff 36 12th December 2007 22:10
Scorpio Vibrations rb2399 Technical Stuff 5 17th April 2007 06:42
Vibrations after upsize Knight Rider Tyre & Alloy wheel Section 14 21st June 2006 20:56
vibrations in zen 97 carb. heavy_foot Technical Stuff 11 30th May 2005 11:01
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
