Old 18th November 2009, 11:48   #31
wildon's Avatar
Thanked: 1,061 Times
You need to get this part to sort out this reverse gear issue
Name: Key Synchronizer (5 & R Hub and Sleeve Assy)
Item : MB501-17243
Picture:Name:  Part.JPG
Edit:- One of the International user having the repair document for the same. As soon i get in my email i'll upload the same here.
wildon is offline   Reply With Quote
Old 18th November 2009, 12:16   #32
longhorn's Avatar
Thanked: 337 Times
As long as Hyundai acknowledge that there is a problem as fix it proactively things should be ok. But it somehow distracts from the new car experience. It would be very unfortunate if someone gets stuck in the middle of nowhere due to this.
longhorn is offline   Reply With Quote
Old 22nd November 2009, 22:13   #33
vijayk's Avatar
Thanked: 64 Times
I have a 11 months old i10 kappa. I am also now facing the reverse gear issue for last two months. It is not properly engaged. I need to pull it hard to slot it whenever I don't find space to move the car bit forward with first gear.
If I move the car bit forward with first gear and then engage the reverse, it will be fine.
My third service is due next month and I will escalate it during that time.
vijayk is offline   Reply With Quote
Old 23rd November 2009, 02:21   #34
Thanked: 1,646 Times
Thumbs up
I think, the problem you are having is a different one. The reverse gear after forwarding is a known issue with many cars. The problem which is being discussed here is the gear getting stuck on reverse. You'll have no other option, but to drive the car on reverse, if the problem happens.
amalji is offline   Reply With Quote
Bullet Std 350- stuck gear topedgemonk Motorbikes 3 21st June 2015 14:26
Hyundai i20 stuck in reverse gear liquidmetal99 Technical Stuff 17 29th April 2012 14:22
Swift reverse gear sound abhi1881 Technical Stuff 27 31st May 2011 00:38
How to remove stuck gear knob from an M800 Joe-Ker Technical Stuff 10 29th March 2011 21:48
Wagon R left wheel stuck, not moving in any gear rrahul_2778 Technical Stuff 5 23rd November 2009 23:21
