Old 10th May 2005, 16:01   #1
tsk1979's Avatar
Thanked: 16,421 Times
Default Battery or started/solenoid
My Indica(42000 done) sometimes refuses to start. The starter motor goes just half turn, like what happens with a weak battery. But it happens very rarely. typically once a week. One mechanic says battery is gone. Other says if battery problem then it should manifest itself mostly in mornings so starter/solenoid gone and starter motor overhaul has to be done. anybody else faced such a problem? It comes occaisonally, once it came when car had been parked for 4 hours, another time it came in morning. And once it came when car had been parked for just 30 minutes. Push starting starts the car.
Old 10th May 2005, 16:07   #2
Thanked: 11,028 Times
judging by the mileage it sounds like the battery. Go to the battery wallah and check the voltage- that should confim it.
Old 10th May 2005, 16:18   #3
amitverma's Avatar
its the starter motor problem
faced it in my palio.
amitverma is offline   Reply With Quote
Starter motor solenoid lock - Causes? tsk1979 Technical Stuff 6 27th April 2017 21:01
Accent Viva Crdi: Purge Control Solenoid Valves - Rs.16.5k! EDIT: Fixin it DIY style! AbhiJ DIY - Do it yourself 64 11th December 2014 13:38
Fabia Starter Motor; Solenoid Switch jnpai Technical Stuff 3 18th September 2011 21:44
Starter/Solenoid problem M800 shipnil Technical Stuff 4 18th May 2009 17:10
Using a battery tender to revive discharged battery xxaarraa Technical Stuff 2 14th May 2008 19:56
