Old 24th August 2009, 17:09   #16
Rehaan's Avatar
Thanked: 25,043 Times
Originally Posted by karizma_devil View Post
between would M-seal work to make the headlamps water proof ?? ( Palio s10)
Its possible - but m-seal becomes rock hard when it dries, i'd imagine that the silicon sealant would do a much better job, as it dries to become rubbery and flexible. Better for a proper seal i would imagine.
cya
R
Old 30th August 2009, 09:30   #17
Thanked: 7 Times
Default Videos on dismantling the head light
Hi There,
Below are the "web Links" (not questions as they appear to be) to detailed Videos on how to disassemble a head lamp the proper way & do a projector lamps Mod.
How to create custom LED eagle eye rings for your car | Video Wonder How To
How to build HID projector headlights | Video Wonder How To
drkumarmp is offline   Reply With Quote
Old 30th August 2009, 23:00   #18
dr chill's Avatar
the silicon with the gun will cost less than Rs 500 at the hardwares stores.Just make sure you scrape the old glue from your lights (as much as possible) puts the silicon glue lavishly in the groove (only) put the lights together and tie it up with a rope tightly for the night.. the next morning you shud have the light ready for fitting!
dr chill is offline   Reply With Quote
DIY: Skoda Fabia Foglamp installation! aayushnair DIY - Do it yourself 11 6th December 2015 09:59
Octi RS Eleanor Style FogLamp Mounting HAFI Modifications & Accessories 11 20th March 2009 14:39
The Rear Foglamp on Indicas greenhorn Technical Stuff 14 25th July 2008 13:32
Replacement headlight assembly for Zen aalaap Modifications & Accessories 18 15th November 2005 12:25
