Old 15th March 2009, 14:39   #1
greenhorn's Avatar
Thanked: 1,312 Times
Default How to dismantle a Headlight/Foglamp Assembly
Without a heat gun or a microwave? Because I dont have either
Any other options ? I'd love to add some DIY angeleyes, but this is a show stopper.
Any tips ?
greenhorn is online now   Reply With Quote
Old 15th March 2009, 15:02   #2
Thanked: 3,507 Times
Great that you din't have a microwave! If you had heated the lamp assy in a microwave, the reflective coating would have caused it to spark! The oven they refer to is the non microwave type.
Use sharp knife, stanley type or swiss army ones, to cut through the resin.
Old 15th March 2009, 15:13   #3
greenhorn's Avatar
but then how do you put it back ?
I'm thinking of using the heating element of a very old bread toaster We have
Old 15th March 2009, 15:20   #4
To put it back use RTV silicone, preferably the the type they use to bond windshield to the car. Cutting wouldn't work it is pretty hard, heating is the only non damaging solution.
You have a hairdryer? You can use that too.
Old 15th March 2009, 15:33   #5
greenhorn's Avatar
tried with a gas stove. maybe I didnt heat it enough, or maybe the seal is too thick. I give up. Maybe I'll see if i can get a hot air gun. any ideas where i could buy/borrow/pay for the services of a hot air gun in tvm/ get the thing dismantled professionally in Tvm ?
Old 15th March 2009, 16:25   #6
WasavaTyres's Avatar
Thanked: 239 Times
microwave imagine what'd have happened if you'd popped the assembly inside it. Heatgun would be available at most hardware stores.
WasavaTyres is offline   Reply With Quote
Old 15th March 2009, 16:29   #7
greenhorn's Avatar
but a lot of people use a microwave. i think bhpian nikhilv12 used a microwave sucessfully on his indica and swift HL's
Old 22nd August 2009, 07:10   #8
How to create custom LED eagle eye rings for your car | Video Wonder How To
How to build HID projector headlights | Video Wonder How To
drkumarmp is offline   Reply With Quote
Old 23rd August 2009, 19:02   #9
Thanked: 381 Times
You can use microwave if and only if there is no metal or metallic film inside. Remember microwave is high energy RF and any metal will cause sparking and damage to your oven.
I don't think hair dryer will work either because heat is too less .
Just a wild idea try using a blow pipe ( from mouth) in a spirit lamp / kerosene lamp like goldsmiths have.
You can procure the spirit lamp / bunsen burner from any scientific store at your place which sell stuff to school and colleges. I have not seen old style kerosene lamp for many years now but must be sold in villages still.
amitk26 is offline   Reply With Quote
Old 24th August 2009, 11:06   #10
dr chill's Avatar
i did mine with hot water ,because i cudn't find an oven big enough for the OHC lights.It's usually done in plain industrial oven and not microwave oven.Its simple just put your headlights in a bucket and pour hot water and VOILA it done.slowly pull the headlight apart.
How to dismantle a Headlight/Foglamp Assembly-30092007064.jpg
How to dismantle a Headlight/Foglamp Assembly-30092007068.jpg
dr chill is offline   Reply With Quote
Old 24th August 2009, 11:09   #11
greenhorn's Avatar
@ dr chill - thanks, will try that out!
how to put them back together ?
Old 24th August 2009, 11:19   #12
dr chill's Avatar
Silicon was used.i don't know the exact name but any hardware store shud have it.it comes with a gun/dispenser. thats what i used in mine
Old 24th August 2009, 11:20   #13
ASHISHPALLOD's Avatar
Thanked: 285 Times
fewiquick-chutki me chipkaye.
just a suggestion, not tried out.
mostly, silicon gun is used at garages.
ASHISHPALLOD is offline   Reply With Quote
Old 24th August 2009, 12:30   #14
karizma_devil's Avatar
Thanked: 16 Times
I have seen fevi-quick damage the glass surface.
I guess silicon gun gun is the best solution.
between would M-seal work to make the headlamps water proof ?? ( Palio s10)
karizma_devil is offline   Reply With Quote
Old 24th August 2009, 15:04   #15
planet_rocker's Avatar
Thanked: 365 Times
@ KD - i know what you have in mind - try this link as well General: Water vapour in palio head lights. - The FIAT Forum
Guys - sorry for going Off-Topic. :
planet_rocker is offline   Reply With Quote
DIY: Skoda Fabia Foglamp installation! aayushnair DIY - Do it yourself 11 6th December 2015 09:59
Octi RS Eleanor Style FogLamp Mounting HAFI Modifications & Accessories 11 20th March 2009 14:39
The Rear Foglamp on Indicas greenhorn Technical Stuff 14 25th July 2008 13:32
Replacement headlight assembly for Zen aalaap Modifications & Accessories 18 15th November 2005 12:25
