Old 17th March 2009, 08:51   #16
Shashank.A's Avatar
Here is the thread that I started to get the right choice, unfortunately there was no conclusion, finally I went with one that more local mechanics recommended.
http://www.team-bhp.com/forum/techni...eo-clutch.html
Shashank.A is offline   Reply With Quote
Old 17th March 2009, 10:20   #17
sgiitk's Avatar
Thanked: 3,884 Times
I would normally stick with the OEM. If MS is now giving valeo then that is it!
Old 17th March 2009, 12:22   #18
Shashank.A's Avatar
There is no definition of OEM here, as both the companies are supplying to Maruti. I guess the best bet would be to check with MASS.
Old 17th March 2009, 12:56   #19
gaurav.28ch
Posts: n/a
I had changed my Esteem's clutch. MASS charges are Clucth+pressure plates - Rs. 2000 and Rs. 1000 for clutch bearing. Labour charges are around Rs. 800 at MASS.
Is this a clutch plate Problem???? The Stig Technical Stuff 15 2nd April 2012 09:29
Clutch Plate change for Matiz SCH Technical Stuff 4 10th May 2009 08:04
Bullet Mag-wheels (size = 19") and 4-plate clutch assembly for sale wanderlustindia Shifting gears 0 27th December 2007 17:15
New WagonR Vxi or Zen Estilo Vxi?? ramki067 Hatchbacks 22 20th December 2006 16:32
Is my clutch plate damaged? johy Technical Stuff 15 25th April 2006 07:20
