Old 11th August 2009, 13:10   #16
sunil.nv's Avatar
Thanked: 7 Times
Originally Posted by Jaggu View Post
Dont worry too much, that would be your clutch overworking. Can happen sometimes under heavy load or if one accidentally slipped the clutch to help the engine gather the rpm.
Or it can be as simple as new parts, paints of the car emitting smell due to excessive heat from the engine bay. Long drive + climb.
As long as the car is performing well, dont bother too much.
As much as possible try to maintain momentum and lower gears, before approaching steep climbs in order to avoid any stalling, gear changes etc in the middle.
Originally Posted by Ravveendrra View Post
Make sure that your handbrake (parking brake) is fully disengaged.
Cheers,
Hi Ravveendrra, I did check if that was the issue but the handbrake was fully disengaged.
regards,
Sunil
sunil.nv is offline   Reply With Quote
1 month old VW Jetta & Burning smell : Dealer says pay up for a new clutch! NikhilD Technical Stuff 33 20th July 2013 21:40
burning smell in car cabin harry2223 Technical Stuff 12 22nd May 2012 13:53
Bad Smell from Car - Suspect Dead Rodent inside FFE !!!! Mi10 Technical Stuff 8 10th August 2010 18:18
burning smell on swift micraft Technical Stuff 42 1st June 2009 12:11
NEW Swift Petrol Burning Smell cyneverdie Technical Stuff 3 11th February 2008 20:30
