Old 31st January 2013, 17:54   #31
Thanked: 164 Times
Default Re: Symptoms of tyre puncture in tubeless tyres
Originally Posted by shineshine View Post
The third one used soap solution and then CLEAR WATER to immerse the tyre. Bingo! The puncture revealed.
It was in the area where the shoulder meets the base due to a nail. The bubbles were too small which was actually seen only on clear water rather than soap solution.
Why do you need a soap solution to check the puncture? Couldn't they directly immerse the tyre in clear water?
Regarding the machine spanner tightened nuts, I only faced the issue at the time of first puncture. The nuts were factory fitted and tightened to specified torque but I had a hell of a time to take that tyre out. After that, I started doing tyre rotations on my own. I use a long pipe with spanner to unscrew the nut. After rotations, all the nuts are hand tightened only.
shipnil is offline   Reply With Quote
Old 13th March 2013, 13:41   #32
tarunchoudhary's Avatar
I have been facing similar issues with my Brio.
- Heads Up - Honda recommends 29 psi in front and 26 psi at the rear. Apparently, this is suggested to make the back seat ride comfortable given the stiff rear suspension.
- I have been loosing 7-8 psi in two weeks in one of the front tyres, whereas all other 3 tyres gain 1-2 psi in a fortnight (how is that possible, I have no idea !!!). Guess I need to check for a punctured tyre/ valve leakage/ deformed rim.
Slightly off topic, but what do the tyre specialists here on the forum have to say about filling the tyres upto 30psi on all four for Brio? Will it impact FE, tyre wear & tear, ride quality? And if yes, then will it improve? I drive my Brio in the city only.
tarunchoudhary is offline   Reply With Quote
Old 13th March 2013, 16:06   #33
sgiitk's Avatar
Thanked: 3,881 Times
30 in front - no issue. In the rear 30 will make the car more skittish. That is all.
sgiitk is offline   (1) Thanks Reply With Quote
Old 27th March 2013, 18:25   #34
RajeswaranK7's Avatar
Thanked: 27 Times
I had a similar issue in my Fiesta. The left front tire was losing 10 psi over a week, so took it to a tyre shop nearby. The guys found a minor leak and were about to fix it by inserting the filler, but saw that the leak was from a old puncture fix. So they inserted a mushroom type plug after removing the old rubber fix. The tyre is holding air properly now. Please take the car to a shop nearby to diagnose the issue, as running with a differential pressure might cause uneven wear.
RajeswaranK7 is offline   Reply With Quote
Old 27th March 2013, 18:53   #35
Thanked: 14,594 Times
Maruti recommends 35 in Front and 33 in the Rear for the Ritz VDi. I fill in 37 and 35 respectively. Will this be a problem in any way?
Atleast till date I feel apart from slightly bouncy ride the handling is good. The car has done 83000 kms in 2.3 years and still counting! Does this pressure have any effect on suspension or the likes?
Anurag.
Old 28th March 2013, 10:42   #36
So, finally I decided to get over this tyre issue! Because I am going to hit the highway tomorrow for a 300 km drive.
Backdrop: Been loosing about 8-10 psi every fortnight in one of the tyres in my Brio with Alloys.
Went to the Honda service station (Patparganj, Prime Honda), as I suspected a alloy problem. But thankfully the alloy was fine. The service advisor suggested to check a puncture, as Honda cant treat a puncture in house!
A decent shop was closeby, the guy removed the tyre and used detergent water to detect a puncture (thats a first for me, but its quite effective, the seeping air just puffs up the soapy water at the place of incision). It was a 1.5cm long screw (yes, not a nail) which is now displaced from my tyre after staying there for a good 2 months.
Costed a mere Rs.50
Hope now the repaired tyre can hold good for the highway drive !
Old 23rd December 2013, 09:43   #37
My Ertiga is loosing 8 to 10 psi in 10 days from the left front tyre. Got it checked at a puncture shop but the guy was unable to find anything. Puncture repair guy told that it might be leaking air from the valve. So, I got the valve replaced at Rs 375 and drove back home. But the problem is not fixed. Tyre is still losing air. I have to refill air every week now. Any suggestions how to get it fixed?
ksaurabh21 is offline   Reply With Quote
Old 23rd December 2013, 12:31   #38
racer_m's Avatar
Thanked: 142 Times
1. Check for any dents on the rim, do you see any damage/bending/distortion of the rim near the wheel lip.
2. Jack up the wheel and rotate it freely. do you see the wheel moving in a straight line or wobbling/uneven play. may point to minor alignment issues or tyre not fitted properly.
racer_m is offline   (1) Thanks Reply With Quote
Old 23rd December 2013, 12:45   #39
Thanked: 389 Times
A small suggestion from me . Take a spray can , like the one you get with colin or they sort of bottle they use at hair cutting saloons (hope you get what I am trying to tell ). Fill it up with shampoo water or any other soap solution.
Spray it all over the wheel , on the rims , on the threads , valve etc . If there is any air leak you can spot it easily.
girimajiananth is offline   (3) Thanks Reply With Quote
Old 1st January 2014, 21:26   #40
Got the tyre checked at Maruti service center. They used the soap solution method. It was a hard to find leakage. Air was leaking for tyre side wall. There was no nail or scratches. They sent the tyre to goodyear folks for analysis. Hopefully, it should be replaced under warranty as my car is just 3 months old.
ksaurabh21 is offline   (1) Thanks Reply With Quote
Old 2nd January 2014, 09:54   #41
Thanked: 389 Times
Good that the MASS is taking care of it. All possibilities that you got a defective tyre. Are you using steel rim or alloy ? If possible check for any sharp cuts in the rim . I have heard heard that even rim bends can cause air leaks.
girimajiananth is offline   Reply With Quote
Old 4th November 2014, 20:50   #42
Waspune's Avatar
Thanked: 430 Times
Hi Everyone,
I have been riding vespa S for the past 6 months in Pune. My rear tyre has got 15 punctures , and front some 3-4 till date. I normally get the air checked once in a week. I have also gone through the manual and now i keep the advised pressure in both the tyres, but somehow i havent been able to stop this rear tyre puncture.
I have gone through all the reasons(in the thread), but I have got the tyre's valve replaced and there is not any problem in the tyre rim either. Everytime the puncture guys asks if i ride on punctures...but that is not true. Can anyone please advise me on this.
NOTE: I think I have spent more money in the rear tyre puncture than the tyre itself
Waspune is offline   Reply With Quote
Old 30th December 2014, 12:27   #43
Thanked: 129 Times
A question to the experts.
I have Yoko A drives, done around 19.5k Kms. Yesterday, on my way to Mysore, I suddenly felt that the car was making a lot of noise and thought something wrong with the fuel I had just filled at Shell. Drove for around 5-10 mins and then pulled over as the noise was progressively getting louder. The steering felt absolutely normal with NO VIBRATIONS or getting heavy. Hence I suspected something else.
The moment I stepped out, I saw that the front right side had a flat tyre, I mean the air was completely out. I don't think I drove for long after the air was deflated because the tyre was not very hot to hold. It was warm, but not hot. I replaced with the spare and then pulled over at a MRF retail shop to get the puncture attended. What then came as a shocker was that there was a small cut in the tyre(not on the side wall), probably 2-3 mm and when he checked for nails, there were only small glass fragments that popped out. He had no clue how this could have happened, but said I probably drove over a glass object, which then broke on impact and hence the small cut. He said a normal puncture fix would suffice, but I opted for a mushroom one and then used the same tyre for the remaining journey for around 250kms. The tyre is holding well so far.
The question though is, will a glass piece cause the tyre to cut? I had filled air(Nitrogen) last week at 33PSI so they were not running low on air. Is that tyre good to use? The shop guy was confident that the tyre has no issues and I did not find anything wrong on my visual inspection. If a glass piece can cause this, then driving over shattered window glasses, that we often see on roads is also a cause of worry? or is it not? Please advice.
ILTDrive is offline   Reply With Quote
Old 30th December 2014, 13:27   #44
Thanked: 158 Times
It can, did you drive over accident spot with glass pieces dropped all over? Its just your luck. May be small pieces stuck, and sub sequent heavy breaking it might caused the damage. Can you recall any tire locking during the journey. The gap might expanded after full air leaked.
Nitrogen shouldn't make any difference in your situation. Problem is you can't figure out if Air is leaked while you are driving, till it goes very low.
No issue as long as patch is done properly. I am using tyre more than 15K kms after Mushroom patch.
RaguHolla is offline   (1) Thanks Reply With Quote
Old 30th December 2014, 14:00   #45
Thanked: 129 Times
It was a early morning drive, no broken glasses anywhere but couple of construction sites that I drove over, thinking I may have gone over something at those places. No sudden brakes either.
Thanks, this does give a little confidence. Will check the tyre regularly for anything suspicious.
Sidewall puncture in tubeless tyre naveendhyani Tyre & Alloy wheel Section 112 15th July 2018 17:07
DIY Guide: How to temporarily repair a Tubeless tyre puncture! iraghava Tyre & Alloy wheel Section 225 11th June 2018 08:32
Hydraulic Jack, 12V Compressor, Tool Kit & Tubeless Tyre Puncture Repair Kit @ 2300Rs prateek99 Modifications & Accessories 52 22nd June 2016 01:40
500Km with a Tubeless Tyre puncture - Had no Clue! d_himan Tyre & Alloy wheel Section 31 8th October 2013 17:44
Tubeless tyre - nail puncture arunnn Technical Stuff 29 8th December 2012 21:29
