Old 25th March 2009, 18:07   #16
Hashim's Avatar
Thanked: 32 Times
Problem appeared again so cleaning distributor did not worked.
@slipstream: you should get the fuel tank cleaned (as it is without fuel for long), fuel pump and pipe line checked and carb. tuned. Car should start in petrol without any problem. Also remember that 1000 has mechanical fuel pump so petrol takes some time to reach engine when switching to petrol from LPG. Solution is to press accelerator pedal about 7 times quickly and then give the self. If it does not start then repeat.
Hashim is offline   Reply With Quote
Old 25th March 2009, 20:04   #17
ask77's Avatar
cars having mechanical fuel pumps on lpg kits should have them replaced with electrical ones because the mechanical fuel pumps keep on running while the engine is in operation even though no fuel is pumped this leads to fuel pump failure. Electric fuel pumps on the other hand are switched on only when the car is switched to petrol mode . Also electric fuel pumps can be switched on while the engine is not running because they work using the battery.
ask77 is offline   Reply With Quote
Engine choking in petrol mode, works fine in CNG mode fast lane Technical Stuff 12 28th August 2016 13:04
Problem with LPG mode in WagonR Duo rajesh1868 Technical Stuff 4 9th June 2009 14:57
Palio 1.2 fitted with LPG Kit - Petrol level keeps coming down in LPG Mode shineshine Technical Stuff 9 10th May 2009 04:52
Starting trouble and Musical Car COUGAR Technical Stuff 3 4th January 2007 05:48
Dark liquid dripping ... from exhaust and starting trouble .. new ZEN gchandra Technical Stuff 3 21st October 2005 09:17
